Old 11-19-2003, 07:02 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
radiator coolant overflow reservior?
Did stock 67-72 350's have overflow tubes for the radiator that went into reserviors containing coolant, or is ther only a tube for overflowing to the ground?
sactoC10 is offline   Reply With Quote
Old 11-19-2003, 07:34 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Nope, they spewed out on the ground. That is what the little hole is for in the inner fender, for the tube to run through. I have seen people use an extra windshield washer tank for an overflow, it works quite well.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-19-2003, 08:04 PM   #3
sactoC10
71 DELUX
sactoC10's Avatar
what for
What is the advantage of having a reservoir on these old trucks? In newer vehicles you fill the reservoir, but there is no "SUCTION" type think going on with these old ones...so why do that?
And wouldn't hot coolant melt one of these old washer fluid reservoirs? I am asking because the truck I am parting out does not have a reservoir, but the truck I drive...with the "mystery hose" does have a reservoir.
Think I'll remove it, very ugly.
Old 11-19-2003, 08:16 PM   #4
Firefighter
Yes, these old trucks will suck it back in if not then the radiator would collapse due to the expansion and contraction and it doesn't get hot enough to melt the tank. So the advantage of having one would be not having to add coolant all of the time after it spews out on the ground.
Yellville, Ar. USA
Old 11-19-2003, 09:13 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
There is a overflow option on these truck's that mounted the overflow tank on the driver's side core support. Someone had pic's as this topic was discussed not long ago when I had a similar question...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-19-2003, 09:18 PM   #6
JimKshortstep4x4
Talking
We use a washer bottle on the truck and drop it into the "teacup"
part of the fender where it is virtually out of sight. The radiator will suck the fluid back if you have the right radiator cap on it, (it has to be good for vacuum and pressure).
Jim
Old 11-19-2003, 09:30 PM   #7
dtlilly
dtlilly's Avatar
I use an old antifreeze jug stuck down next to the battery. It doesn't suck back, but it saves your fluid, and the environment
dtlilly is offline   Reply With Quote
Old 11-19-2003, 10:47 PM   #8
jhow66
jhow66's Avatar
Got one on both of my trucks --72 chevy & 65 GMC step-you can purchase a kit that has everything you need for $13.00. (what I payed for mine). You get bottle, hose, bottle holder with mounting bracket and rad. cap. Works just like the late models.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-19-2003, 11:11 PM   #9
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Where did you get this $13 kit? I was just going to let mine go to an extra washer tank. If there is a kit that comes with everything for $13 I would like to see it if possible.
BtnkBndt is offline   Reply With Quote
Old 11-19-2003, 11:16 PM   #10
jhow66
jhow66's Avatar
Bought mine from my parts store.(local) Autozone,Advance etc. should have the samething as I have seen them but don't know their price but should still be less then $20. Check it out.
Old 11-19-2003, 11:28 PM   #11
Andy4639
Old member
Andy4639's Avatar
Cool Overflow
I got this from the junk yard off a older monty carlo. It works great and for $5.00
Any tank will work though.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-19-2003, 11:30 PM   #12
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
I'll check into it on my way to the house right now.
Thanks again
Old 11-19-2003, 11:37 PM   #13
dtlilly
dtlilly's Avatar
Thanks, I will too. It should look more classy than a dirty coolant jug
Old 11-20-2003, 12:15 AM   #14
sactoC10
71 DELUX
sactoC10's Avatar
I checked mine when I got home, and I too have some sort of replacement or aftermarket coolant collector mounted near the battery.
Thanks...this helps much.
Old 11-20-2003, 12:50 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Here is a pic of the dealer installed puke tank.
On mine, i used an extra washer bottel mounted on the other fender...kinda ballances everything out.
Old 11-20-2003, 01:00 AM   #16
gonebad2
Merciless Butcher
gonebad2's Avatar
Coolant Tank
Here's what I'm using. Got it from Jegs. Haven't hooked it up yet so I can't tell you how well it works. Anyone else use one of these octagon aluminum ones?
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-20-2003, 01:04 AM   #17
jorgensensc
jorgensensc's Avatar
I thought the C20's and C30's had an actual factory installed overflow. Similar to the one from JEG's, only longer. I could have sworn I saw one on ebay also. I knew I should have bought it for $5.00
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-20-2003, 01:26 AM   #18
Longhorn Man
Nope.Nothing was stock nor stock option.
Maybe on 72...but even then, I don't think so.
Old 11-20-2003, 11:51 AM   #19
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Got this at Schlepp Boys for 9.99. It'll do for now, still want the original washer bottle look. I'll pick one up at the next swap meet this spring if H&H is there.
Didn't come with a new cap, came with a neoprene washer you're supposed to add to your existing cap on a non-closed system. What cap are you guys using?
Old 11-20-2003, 02:00 PM   #20
JQ-72
JQ-72's Avatar
You could get a coolant recovery system as a dealer installed option in 1972. Here is a picture of one:
Joshua
JQ-72 is offline   Reply With Quote
Old 11-20-2003, 02:03 PM   #21
sactoC10
71 DELUX
sactoC10's Avatar
Well my cap to the reservoir is broken, so I should probably get one of these aftermarket deals, since mine si not sealing at this point. Hard to determine a universal cap I guess, or do you mean the radiator cap? I am noting the reservoir cap.
Old 11-20-2003, 08:07 PM   #22
jhow66
jhow66's Avatar
Got mine mounted in the same place as in JQ-72's picture--you must have a big block as I see the power steering rev. & washer are in the same place as mine. sactoC10 we are taling about the rad. cap. Just buy one for a closed system. Any kind of cap will work on the bottle.
Old 11-20-2003, 11:02 PM   #23
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
I have one in a 72 that has one that looks factory but there is nothing listed in the glove box it is on right side inner fender.
There is a number on the side I will try to get pcs. here is the number. I would like to know if it is.
15531513
2
Gary 70 Jimmy is offline   Reply With Quote
Old 11-20-2003, 11:55 PM   #24
Longhorn Man
It would not be listed in the glove box, it was a dealer installed item.
Old 11-21-2003, 04:57 PM   #25
racedvl
racedvl's Avatar
I took one out of a Caprice, once again, it was one of them $5 deals. Works great!
racedvl is offline   Reply With Quote
