Old 05-08-2013, 09:46 AM   #1
nobolt
nobolt's Avatar
Custom Camper question
i now understand that some '71-'72 chevys as well as GMC's had "Custom Camper" door emblems.
if a chevy has the door emblems, what is the correct emblem for the fenders? "Custom/30" or "CustomCamper/30"?
thanks guys!
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 05-08-2013, 09:43 PM   #2
Re: Custom Camper question
Only '72 Chevys had the Custom Camper door scripts. The fenders will have whatever trim level the truck is...Custom,Custom Deluxe,Cheyenne,or Cheyenne Super. The Custom Camper/20 & 30 door badges were 69-71. In '69 Chevy offered a Custom Camper/10 as well.
Old 05-08-2013, 09:57 PM   #3
ClassicTVMan1981X
And... the 1967-68 models had a 1966-style logo on the front fenders, only with "Custom Camper" where the tonnage designator would be.
~Ben
ClassicTVMan1981X is offline   Reply With Quote
Old 05-08-2013, 10:57 PM   #4
nobolt
nobolt's Avatar
thanks Tim,
i guess i will keep my door scripts to use on the '72. i cobbled them together from 3 emblem lots. i was going to sell them to a GMC owner but i think i'll use them.
Dave
Old 05-08-2013, 11:40 PM   #5
SS Tim
SS Tim's Avatar
~Ben
Just to be clear on Chevrolets.
67-68 "Custom Camper" fender emblem
69-71 "CustomCamper/XX" 10-30 fender emblem
72 "Custom Camper" door script
SS Tim is offline   Reply With Quote
Old 05-09-2013, 11:09 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tim - the pic of the 72 emblem above doesn't appear to show the correct location as seen here. I'm researching placement now getting ready to add these emblems on my K20. The factory manual doesn't give great info for hole location relative to the edge of the door. Pete
Old 05-09-2013, 11:27 PM   #7
leddzepp
Moderator
leddzepp's Avatar
I have seen and removed them in various locations on the door.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-09-2013, 11:41 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
LOL! Maybe that's because the GM schematic isn't exactly clear on distance from door edge. I haven't seen one installed as close to the door edge above in combing through pics though.
Old 05-10-2013, 01:46 AM   #9
SS Tim
SS Tim's Avatar
Actually it is very clear where the emblems are to be located. The problem is that you are not using the same reference system.
The emblems are not located off an "edge" but are referenced from specific locations. This is done using a common Cartesian coordinate system. To keep things simple on these drawings it is a location aft and up from fixed "0" locations. Unfortunately these reference points are not common knowledge. But you can, through diligence, locate production hole/s to use as local reference.
In this case it is very clear where the driver's side emblem ends and the passenger side starts.
They are both 0.38" AFT of station 50.
As your good luck would have it the upper (belt) door molding has a hole at station 50.
So all you really need to do is make a layout template for the pin holes using the factory spacing and vertical differences from a fixed waterline reference, 35 in this case.
Then position it using the hole at 50 as you fore and aft locator.
Can't help you with the waterline 35 as to exact location but if I were to guess I would say it is very close to 6.06" up from that very same molding hole at 50. The molding is down 1.06" from 30. Convention says this is likely an inch based system so 35 is probably 5" above 30 as projected.
Since the emblems are down 1.27- 1.41" from the 35 waterline it locates comfortably in the radius above the door panel where we expect to see it as in the pictures.
Hope this helps, if needed or to donate dog food please contact me.
Old 05-10-2013, 08:38 AM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Wow Tim that's a huge help. Thanks! Here's another I had saved, which shows a more remote location from the edge. Pete
Old 05-10-2013, 08:40 AM   #11
Yup. Maybe some seen were added in an improper location. OR...perhaps those are from Janesville. You know how they are with their emblem locations
Old 05-10-2013, 03:10 PM   #12
SS Tim
SS Tim's Avatar
Both are very possible. Dealer added emblems would have been surely possible and owner additions as well. But I suspect many more were peeled off than added.
A plant variation is a very real and likely possibility. Several of my pictures were of known Freemont "Z" assembled trucks. If you find a forward emblem location, try and determine the assembly plant for us.
Old 05-10-2013, 03:25 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here are the SPIDs for the green and blue trucks both OEM CC badged C20s. Fremont trucks?
Old 05-10-2013, 03:27 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
No Flint trucks....
Old 05-10-2013, 03:29 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
My truck is a Flint truck - now what should I do Any more Flint examples?
Old 05-10-2013, 03:35 PM   #16
leddzepp
Moderator
leddzepp's Avatar
Dealer installed makes sense to me. I know I have pulled these emblems off of trucks other than 72, and they weren't GMC's. The different locations would support this as well. I have also encountered them with barrel nuts used for attachment, as well as 5/16 thread cutting nuts.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-10-2013, 04:08 PM   #17
jocko
jocko's Avatar
good info here! my key check for making sure of proper location on the 72 emblem is that the one closest to the edge is always visible in plain view when you open the door, the post nut sticks thru the door skin and is easily attached in the door jamb area. Not so with the other 3 attach points, have to access from inside the door itself.
Old 05-10-2013, 04:44 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I've got 4-5 sets of emblems and will see what the mix is between barrel nuts and speed nuts. If the camper nameplate is listed on the SPID I would assume the emblem was factory installed....
Old 05-10-2013, 04:59 PM   #19
SS Tim
SS Tim's Avatar
OK two Flint built trucks that are known Z81. Lets call them "long". Does anyone else have "long" mounted emblems on a known Z81 (on SPID) truck and what plant?
Old 05-10-2013, 05:24 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a former Tim (Special-k) truck - if this was an original CC where was this one built?
Old 05-10-2013, 05:44 PM   #21
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Long Flint truck owned by member thelonerife - we may be on to something:
Old 05-10-2013, 05:53 PM   #22
SS Tim
SS Tim's Avatar
Good question, If I have it I cannot find Special-Ks Highlander K20 SPID at the moment.
Old 05-10-2013, 07:25 PM   #23
jocko
jocko's Avatar
mine are fremont and are not "long". Interesting. Tim, have you ever lived in Janesville or Flint? They may not let you move back....
Old 05-10-2013, 08:03 PM   #24
SS Tim
SS Tim's Avatar
Yes I know both yours and Billy's are in the collage above.
Don't think I have ever been to Janesville or Flint...
Old 05-10-2013, 08:48 PM   #25
MusicMan70
MusicMan70's Avatar
How about Cartesia!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
