Old 05-12-2013, 10:23 PM   #1
ol'blazer
ol'blazer's Avatar
cheapest way to make my truck quieter?
so this weekend i was doing repairs on the floorpan in my truck and when i tore up the old carpet i found this mess of the stock stuff and two layers of old carpet!
whats the cheapest way to kill the sound in my truck?
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 05-13-2013, 12:55 AM   #2
Squareforceone
Squareforceone's Avatar
Re: cheapest way to make my truck quieter?
peal and seel
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 05-13-2013, 01:25 AM   #3
cochino12
It followed me home?
cochino12's Avatar
New stereo and speakers!!! Best way to kill the sound
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-13-2013, 04:01 AM   #4
Remon.
Remon.'s Avatar
Go for some bitumen stuff like peel n seal or other self sticking thick stuff. Additionally I added a layer of heat insulation and a layer of 1/4" undercarpet.
Remon. is offline   Reply With Quote
Old 05-13-2013, 05:54 AM   #5
Skunksmash
Skunksmash's Avatar
There is a Canadian company that makes something like dynamat called B-quiet. Its cheaper and it works just about as well. Worked on my truck.
Skunksmash is offline   Reply With Quote
Old 05-13-2013, 07:02 PM   #6
donut
donut's Avatar
Cheapest way to kill the sound?
Toss the keys on the counter and leave them there. (quiet and cheap)
How much sound are we trying to kill? Flowmasters and turndowns under the truck and trying to make it as quiet as a new Caddy? Wind noise? Nagging other?
Seriously, I used peel and seal type stuff, repaired sheetmetal (includes any cracked welds etc) new weather strip, made sure doors and glass were aligned properly. A lot of little noises can add up to a lot of racket.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-13-2013, 08:07 PM   #7
Rufton
Does that peel and seal stuff lead to trapped moisture and corrosion after some years?
Rufton is offline   Reply With Quote
Old 05-13-2013, 08:48 PM   #8
CHROMAHOLIC
CHROMAHOLIC's Avatar
Here' the cheapest way I know.....sorry couldn't resist, lol
CHROMAHOLIC is offline   Reply With Quote
Old 05-13-2013, 09:28 PM   #9
tinydb84
tinydb84's Avatar
Mass loaded vinyl is what you need. Google it
David
Instagram: myfabguy
Old 05-13-2013, 10:51 PM   #10
ol'blazer
ol'blazer's Avatar
Originally Posted by Squareforceone View Post
peal and seel
I thought about peal and seal, what worried me about it is on a hot summer day ill smell tar?
Tyler
1980 2wd blazer
Old 05-13-2013, 10:55 PM   #11
ol'blazer
ol'blazer's Avatar
I know she's always gonna be a loud ride, but I want to dampen the sound a little..
Tyler
1980 2wd blazer
Old 05-14-2013, 05:28 AM   #12
donut
donut's Avatar
I used peal and seal on the '73. Initially, I smelled tar, but over time it did dissipate. (think fresh paved road)
I tip I also read from someone is to stick a chunk inside the outer door skin, it did dampen a lot of the noise from the door.
Basically in my truck, I tried to repair everything I could. Even a torn shifter boot was replaced. New flooring helped a ton. Even putting in a new rubber floor mat instead of carpet was a big help over nothing. I do feel the pain, in that truck, the driver floorboards were 3 layers thick.
Truck wasn't real quiet, then again I wasn't trying for that. But it was far better than what I had. It was good enough that I was dealing with a whistle in the heater when I sold it.
Old 05-14-2013, 10:13 PM   #13
ol'blazer
ol'blazer's Avatar
thats exactly what i mean, i know this old trucks never gonna be "quiet" but i want to kill the sound as best i can without breaking the bank
Tyler
1980 2wd blazer
Old 05-14-2013, 10:28 PM   #14
Redcap
If it is too loud, you are too old.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 05-15-2013, 02:40 AM   #15
Remon.
Remon.'s Avatar
Be careful with sound deadener:
http://www.thedailyswarm.com/headlin...eeds-insanity/
Old 05-15-2013, 04:41 AM   #16
Skunksmash
Skunksmash's Avatar
I have used peal and seal on my truck, but I took it off. Actual sound deadener works a whole lot better. Such as the B-quiet I mentioned. Any buytl based rubber with aluminum backing. I noticed a huge difference in sound reduction from the peel and seal and the B-quiet. But to anwser the OP, there really isn't a "cheap" way out on this one. I've calculated it all up, and my single cab needs about $1,000 so be properly "deadened".
You cover the gutted interior in dynamat or b-quiet or something, and then you lay down your foam, then your vinyl, then your carpet. You combine all 3 for the greatest effect. That starts adding up quick. But if you don't do at least the vibration damper stuff (like dynamat) you're not going to get very far. After having used that roofing stuff before (like peel and seal) personally I wouldn't waste my time with it again. Just my opinion.
Old 05-15-2013, 06:39 PM   #17
tinydb84
tinydb84's Avatar
This is what I will be doing but I think you could probably do it quite a bit cheaper than $1000. I'm hoping to do it for around 300-400.
David
Instagram: myfabguy
Old 05-15-2013, 09:51 PM   #18
zaccaglin
zaccaglin's Avatar
Cheapest way to make it quiter is not not run it and flinstone it! Gas is too expensive anyways.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 05-16-2013, 12:38 AM   #19
dieseldawg142
dieseldawg142's Avatar
$3-$400 is totally doable. in my crew i used 100 sqf of fatmat ($150), 1/8" closed cell foam ($30), & 100 sqf of mass loaded vinyl ($170). firewall to back wall & all 4 doors. also put 3 coats of por 15 on the cab floor ($40)
dieseldawg142 is offline   Reply With Quote
Old 05-16-2013, 04:17 AM   #20
Q.8
Q.8's Avatar
can i ask is the mass loaded vinyl work as heat shield? or just for sound?
there is many products in ebay and good prices also..
can any one lead us to some thing kill heat and sound with out any smeel or some thing?
thanks all guys and thanks old blazer
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks
--c30 1966 frame off 5 years restoration ; Finished;
Chevy suburban 1958 restoration ( In progress )
85 c10 "back to original project <Finished> "
81 c10 "back to original ( later) "
85 c10 cattleman edition lifted ( finished)>
K1500 1989 full restoration ( soon )
S10 1991 in progress
Q.8 is offline   Reply With Quote
Old 05-16-2013, 08:50 AM   #21
king-918
king-918's Avatar
peal and seel
X2 and add some mass loaded vinyl
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-16-2013, 11:51 AM   #22
SigFTW
I'm going to use Peel and seal too.
SigFTW is offline   Reply With Quote
Old 05-17-2013, 03:59 AM   #23
Skunksmash
Skunksmash's Avatar
Don't forget roof, pillars, and underneath the bottom of the cab and the outside of the firewall. Done with a quality company like Cascade Audio or Sound Deadener Showdown, it gets expensive fast. Most people don't want to stop at just sound, they like to throw down some of that ceramic based lizard skin (or the like) for reduced heat inside the cab as well.
Old 05-17-2013, 12:08 PM   #24
dieseldawg142
i did do my pillars, but not my roof, no headliner (custom deluxe). another $20-$30 worth of dampner would cover that. putting mlv or sound deadner on the roof would be pretty useless, not a lot of sound hitting your truck from above. the best gains are by making a "tub" of dampner & deadner from the windows down. personaly i would not spray anything under my truck, (second skin, lizard skin, rust proofer, etc.). on a street truck maybe, but not on a 4by. water & mud will eventually get under it. with 3 feet of air under my truck, heat has never been an issue, even with a big block
fatmat
closed cell foam to de-couple
mlv
fatmat & mlv in doors
i found the best gains were doing the doors, rear pillars & cab back wall. seat of the ears test, i'd say i cut noise by about 70% compared to before (absolutely nothin')
Old 05-17-2013, 02:52 PM   #25
ol'blazer
ol'blazer's Avatar
fatmat
Attachment 1108433
Attachment 1108434
mlv
Attachment 1108435
Attachment 1108439
I like what you did, can I have info on what products you used and how layred them?
Tyler
1980 2wd blazer
