Old 06-03-2013, 01:37 PM   #1
Katrina/10
Katrina/10's Avatar
Project: Scott's IFS into 51 GMC
Truck already has a V8 engine, auto trans, and power steering with stock frame and axles. I intend to do this without removing any drive train or sheet metal.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-03-2013, 06:29 PM   #2
Russell Ashley
Russell Ashley's Avatar
Re: Project: Scott's IFS into 51 GMC
Post lots of pics as you go. I have a TF but the installation should be similar.
Russell Ashley is offline   Reply With Quote
Old 06-03-2013, 06:46 PM   #3
Katrina/10
Katrina/10's Avatar
Are you interested in buying a suspension system? This one is a bolt-in, i'm not sure if Scott's makes one of these for a 55-59. They should have a weld-in.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-03-2013, 08:14 PM   #4
Root2812
Root2812's Avatar
I applaud your desire to get this done without removing extra things but you may want to reconsider not removing the fenders. You can leave the hood on the truck and remove the radiator support and both inner and outer fenders all as one unit fairly easy. That labor will save you a lot of fighting in a tight space and you'll wish you had done it when you scratch the paint.
If you don't mind me asking, What did you have to give for the bolt in from Scotts?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 06-04-2013, 08:29 AM   #5
Russell Ashley
It's definitely in my plans. I just wish I had the $$ I have spent on a disk brake kit, power steering kit, king pins and bushings, spring bushings, etc. back. It would go a long way toward a decent suspension.
Your truck is a beauty, BTW.
Old 06-04-2013, 09:57 AM   #6
Scottshotrods
We do have a bolt in ifs for the 55-59 chevy truck as well
Justin
Scottshotrods is offline   Reply With Quote
Old 06-04-2013, 11:02 AM   #7
Katrina/10
Katrina/10's Avatar
Justin
Hi, Justin, I finally got time to post the some pics, more to come.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-07-2013, 09:26 AM   #8
Katrina/10
Katrina/10's Avatar
Removed the old front axle.
Marked the center.
Removed exhaust manifolds, now I have to get this old engine mount out of the way.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-07-2013, 01:07 PM   #9
Dan in Pasadena
Dan in Pasadena's Avatar
Justin
Just curious - up to now I have intended to do a dropped axle, Posie's Super Sliders, etc - How much does your ifs lower the truck from stock?
Dan in Pasadena is offline   Reply With Quote
Old 06-07-2013, 01:23 PM   #10
Scottshotrods
Dan- Good question there and one of the best things we can offer our customers is.We can build you any drop you are after in our crossmember.
1.If you want to drop your truck down one inch we can do it
2.If you want your truck to sit stock we can do it
3.If you want your truck to have a 2-3-4-5-6- or lower we can do it
Hopefully this gives you a idea on what we can offer you
If you have more questions let us know and you can call us at the shop at (805)485-0382 if you would like to
Justin
Old 06-07-2013, 05:52 PM   #11
Dan in Pasadena
Wow Justin, that's a pretty impressive option. The only IFS I truly considered instead of a dropped axle etc, was the No Limit Wide Ride. Feature for feature and gauge of metal, would you say you're head-to-head with them?....or better?
Old 06-07-2013, 06:01 PM   #12
Scottshotrods
There are alot of options with all ifs kits on the market.As I tell all of our customers and all who call us.Is do your search and homework call up all the Manufactures who make there products in HOUSE and not over the water.Ask them questions on there parts and see what they have to say.Like I will call us at the shop and you can speak to one of us on the phone and you can see for yourself on what we have to offer.
Justin
Old 06-10-2013, 08:06 AM   #13
Katrina/10
Katrina/10's Avatar
The crossmember fit perfectly between the frame rails, without cutting anything.
The engine is supported by a jack.
The steering shaft is connected to the rack, looks like it will not need a center joint.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-10-2013, 04:22 PM   #14
_Ogre
_Ogre's Avatar
hey, that's cheating.
i had to cut, box and weld
looks good
shop air compressor timer
Old 06-10-2013, 06:07 PM   #15
Katrina/10
Katrina/10's Avatar
It was nice since the crossmember was all one piece, the only thing you have to do is put it in place and attach the control arms. That makes it pretty easy. And nothing protrudes into the engine compartment, so no cutting the inner fenders up. looks like it's gong to work well.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-22-2013, 08:24 AM   #16
Katrina/10
Katrina/10's Avatar
Made some more progress but the sway bar doesn't fit. The radiator support crossmember is too low to install the sway bar bushings and brackets.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-22-2013, 01:54 PM   #17
focusedontheprize
focusedontheprize's Avatar
You are doing a great job on top of not removing anything. Keep the pictures coming.
focusedontheprize is offline   Reply With Quote
Old 06-22-2013, 09:40 PM   #18
Katrina/10
Katrina/10's Avatar
As you can see, the crossmember and steering are mounted. I did lower the crossmember 1 inch so I would not have to cut the frame for a rack notch. The crossmember is a bolt-in, but I welded it also. So I would say it is possible to install this suspension without removing any drive train or body parts, and cut nothing!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-29-2013, 03:34 PM   #19
Katrina/10
Katrina/10's Avatar
Got a new sway bar from Scott's, it all fits now. It mounts in front of the radiator support to the two rivet holes where the spring shackle is in front of the frame.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-29-2013, 11:30 PM   #20
oldman3
oldman3's Avatar
Sway bars looks good in that location, nice fix...Jim
oldman3 is offline   Reply With Quote
Old 06-30-2013, 06:36 PM   #21
solidaxel
solidaxel's Avatar
Another good looking GMC!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-30-2013, 07:09 PM   #22
Katrina/10
Katrina/10's Avatar
Thank you very much! It's coming along.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-30-2013, 10:31 PM   #23
mknittle
mknittle's Avatar
Looks good Gary it will be well worth it. I like the GMCs.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-13-2013, 12:19 PM   #24
Denee007
Denee007's Avatar
Hi Gary! I'm on board here! That IFS looks great! I wish I had known about it back a while. I didn't know these came to where one can have a desired height like Justin described You're write-up is great with excellent photos! I think I'll just live with what I have and make a decision a year or so from now~ and look seriously at the IFS system you're showing! BEAUTIFUL truck!
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 07-14-2013, 08:53 AM   #25
Red Foreman
Red Foreman's Avatar
Real nice work on the front end, you made it look easy!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
