go cyclones
Weird oil in np205
Ive been hearing a weird low whine when i let off my accerator. I checked the oil level and first found it to be way over filled and second i found the below oil. It has the viscosity of 10 weight, has a slight pinkish hue, and smells vaguely like 80w90. Thoughts? Im guessing it was filled with trans fluid after draining gear oil. Also would having it too full cause it to whine? The whining is in 2hi havent tried 4hi or low yet.
Thanks |
What?
Re: Weird oil in np205
Looks like ATF?
I've heard people like to use ATF in manual transmissions, but personally I wouldn't put that kind of oil in my MT. Or someone could have used Motul MC oil? I know guys that run Motul in their HD transmission, and it looks and fits your description of what you have.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
go cyclones
Sorry I meant it was in my transfer case.
Posted via Mobile Device |
What?
Do you have an automatic trans in that truck?
go cyclones
700r4
What?
I'd then be concerned that your ATF from the transmission is getting into your Tcase.
#7 | ||
"I ain't nobody, dork."
Yup... Unless it's a divorced unit, I'd check to make sure the tranny isn't leaking into the T-case.
Later model T-cases use ATF in them. But the ol' NP205 is a gear oil only T-case as far as I know. I've had 3 of them in different rigs, and they all used 80w90wt gear oil. Gary
go cyclones
Does this mean I have a bad seal in the transfer case or the transmission? The transmission has less than 500 miles on it.
#9 | ||
Are they mated together? With an adapter? The 700R4 and the 205 never came mounted together in a factory rig.
Gary
go cyclones
They are mated together, I got the trans from bowtie. Ill get some pictures when I get home.
#11 | ||
Just an observation... the NP205 is a cast iron monstrosity that is bomb proof. There is no chain inside... it's all gear driven. It has a tendency to buck a little in low gear and sounds like a gravel crusher. One of the main reasons cats building mud trucks and pullers use the NP205's is for their strength and durability.
Nowthen... mate that heavy cast iron T-case to a light duty 700R4, and it might be a little much for that tranny. I don't know of any apllications where the NP205 came behind an auto tranny. GM used the NP203 and NP208 behind the slush boxes of the day. The NP205 found itself behind the big granny low 4 speeds. Through my experiences with GM truck T-cases... that's what I have seen and used. I would hate to see a crack in the tranny where it is mated to the NP205 and letting ATF in the T-case. Gary
![]() Join Date: May 2007
There are seals in the trans to transfer case adapter. Very common to leak, especially after being disturbed, such as installing a new trans. If you have tranny fluid in your 205, and it was over full, I would bet money they are bad.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
go cyclones
Does anyone have some exploded views ofmthe seals? I very well could have missed these seals when installing the transmission.
#14 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
I agree..... mine developed bad seals and I had to occasionally add ATF to the trans and drain the excess from the t-case.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#15 |
What?
Check out this thread, and the latest few posts to it.
They are discussing the seals you are asking about. http://67-72chevytrucks.com/vboard/s...84#post6157184
#16 | ||
![]() Quote:
The 203 was used for a while when the thinking that full time 4WD was a good idea. Those trucks ate front driveshafts and gas like crazy. The 208 came after the 203 but 1 tons of the same era used the 205 behind the TH400. Searching for a round pattern 32 spline 205 and a 32 spline 203 teaches you stuff ![]() |
#17 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Jaydub I have my case and adapter out on the bench right now.. Let me know what if any pictures you may need of the seals as I just replaced mine..
part number for the seals is national 471424
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#18 |
Just for your information: I have a 1988 V30 CC. I bought it new in 88. The NP205 transfer case was filled with ATF at the factory. The owners manual calls for ATF in all 1988 transfer cases, NP208 and NP205. Why? Maybe it is to make things simpler. But this does not make sence because the SM465 transmission calls for 80W90. Anyway, I replaced the ATF with 80W90 and it has been good now for over 25 years.... And by the way, if your NP205 is equiped with a PTO unit, it is a verry good idea to overfill the transfer case as to allow a oil level to reach inside of the PTO unit. The normal fill level is below the PTO outlet. This is ok if neutral in transfer case is not used, but the neutral position is used, such as with PTO use, it is possible that the PTO unit and the matching transfer case gear will not get enough lubercation.
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers. Last edited by V30 mongo; 07-05-2013 at 11:58 AM. |
#19 | |
go cyclones
Thanks Posted via Mobile Device |
#20 | ||
Good info here. I learned something new as well. Never new the 205 was ever mated to an auto tranny from the factory.
![]() Gary
#21 | |
![]() Join Date: Feb 2007
The seal in question is a double lipped one but the part number escapes me. I'll remember it a month after you figure it out ![]()
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#22 | ||
Not to derail too much... but I heered through the interwebs that there was an aluminum case NP205 that came out in some MOPAR trucks in the 70's. Anybody hear of one of those animals?
Gary
#23 |
go cyclones
So i checked the fluid levels in my tranny and transfer case today. The tranny was fine the TC was uber full. I drained over gallon out of the fill hole. It had to be full to the brim. What i did manage to catch i put in a bottle to see if any metal would settle out. I didnt find any metal but there was a heavier fluid that looked like bacon grease. Could have been rusty water?
Anyway still bearing that whine from the transfer case when i let my foot of the accelerator at 25+ mph. |
#24 |
What?
That looks like ATF, with 80/90 at the bottom.
Fill the Tcase with 80/90, for a road trip and then check or drain the Tcase lube. Then check the fluid level on your transmission to see if it went down, if it did then you know it found it's way into the Tcase.
#25 |
I had the same thing happen to my NP205 after having my truck in storage for a couple of years. When I went to get it out of storage I changed all the fluids and antifreeze but who changes their transfer case oil in a situation like that? Well got the truck started and headed out on the 800 mile trip to my new home and the truck started smoking big time after about a hour driving. It took a little while to finally pull the 205 fill plug and out came the same nasty looking stuff. What had happened was the TH350 had finally transferred enough fluid for it to start coming out of the vent at the top of the 205 case and drip onto the exhaust. After connecting the dots all I did was keep my eye on the trans fluid level for the rest of the trip and kept the oil drain pan handy when I checked the NP205 at gas stops. The trip would have been boring if I didn't have those extra chores, right?
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
