Old 07-05-2013, 10:10 PM   #1
greyno3
greyno3's Avatar
Can the frame be fixed
Brother crashed the
'72 C/20. Bent the front frame horn. Is it costly to straighten this out?
greyno3 is offline   Reply With Quote
Old 07-05-2013, 10:14 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Can the frame be fixed
Took a pretty hard lick to move those rails that far. A good collision repair shop should be able to pull them back in place. No clue how much it would cost.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-05-2013, 10:50 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
Ouch, that was a hard hit!
I had a 95 chevy frame straightened. It was a rear end accident and was probably about 5 degree bend behind the cab, Cost me $250. Yours may cost quite a bit more with that much damage. Check with a body collision shop as gary said. Most of them do frame repair.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-06-2013, 12:11 AM   #4
Mustard72
Mustard72's Avatar
Brothers...
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 07-06-2013, 12:17 AM   #5
69chevy lwb
69chevy lwb's Avatar
Most body shops can do it but that more than likely is bent farther back than that too and there hard to straighten especially new trucks with exotic metals in the frames I have done a couple new trucks I'm not sure what they charged but we had to do full on collision repair it might be cheap if you tear everything off for them
69chevy lwb is offline   Reply With Quote
Old 07-06-2013, 12:50 AM   #6
junkyard
Here where I'm at in Calif. I could get that straightened and squared for less than $500.
Be as good as new, maybe better.
junkyard is offline   Reply With Quote
Old 07-06-2013, 01:23 AM   #7
greyno3
greyno3's Avatar
I'll take a couple pics from the other side of the core support and add them here.
Old 07-06-2013, 09:32 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
May check with wes at classic heartbeat in olympia he maybe able to help you out..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-06-2013, 12:58 PM   #9
hugger6933
Too bad your not in AR my frame machine will be empty monday morning that looks to be an easy one, bent only from the crossmember forward. The main thing about most of those places ,and I have been to a lot of them before I bought my own machine is that they won't work on your truck while your there. there is always something else pressing that needs to get out or that was promised to a customer or whatever. They don't want you to see actually how long it takes to pull the frame back around. The biggest thing to your job would be the tie down. I belive that it would be a simple pull to get it back around into the shape it needs to be to hang the sheetmetal and have you riding again. I would not start to talk about a price for that since pricing seems to be all over the place in different parts of the country what I think may be good in one spot might be high to somebody else and what they think is cheap may be hiway robbery on down the road just a little bit.But back to the important thing at hand, the truck. It can and should be, if you want, to be saved. Jim
hugger6933 is offline   Reply With Quote
Old 07-06-2013, 01:51 PM   #10
Tinkermc
can be fixed at a reasonable cost.
Tinkermc is offline   Reply With Quote
Old 07-06-2013, 03:09 PM   #11
Hardesty454
Hardesty454's Avatar
Probably around $500 to straighten that out.. Good news is I have the fenders and core support for sale that you need!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 07-06-2013, 04:25 PM   #12
greyno3
greyno3's Avatar
I have all the parts to fix it ...but the swaybar brackets. They are riveted in and one side broke off. You can see how far the swaybar bushing moved to the right.
I live about a mile away from a frame guy that's been there's for 40+years. Have to stop and talk with him about this.
Old 07-06-2013, 04:32 PM   #13
Hardesty454
Really worst case I see frames for sale all the time for 3-500.
Rob
Old 07-07-2013, 11:38 AM   #14
greyno3
greyno3's Avatar
Wish I could get this frame for $100.00. Got other parts from the seller. Nowhere to do a frame swap.
http://spokane.craigslist.org/pts/3841462969.html
Old 07-07-2013, 01:06 PM   #15
Hardesty454
There's always room. You just have to remember how to play Tetris.
If it were me I'd jump over to the regional section and ask if anyone has some extra room and hands to help. You'd be surprised what strangers will do to help out with.
Rob
Old 07-07-2013, 05:06 PM   #16
greyno3
greyno3's Avatar
Got the rusty core support off and here's some pics. Not as bad as it looks. I'll check out your advice. Thanks everyone for your input.
Old 07-07-2013, 05:52 PM   #17
desertnick69
desertnick69's Avatar
That's a heck of a deal.
desertnick69 is offline   Reply With Quote
Old 07-07-2013, 08:04 PM   #18
rsavage
rsavage's Avatar
I don't profess to be an expert, but that frame has really been moved sideways Had to be kinked under the front cab mounts or just behind the a arms?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-07-2013, 01:21 PM   #19
greyno3
greyno3's Avatar
Got her back this morning. $175.00 to bend the frame back ...plus a free front and alighnment after I get it together. What a deal this was!!!
Old 09-07-2013, 01:23 PM   #20
greyno3
greyno3's Avatar
Could use a heater core housing w/o AC. I might gave to fix this one. Blower motor was smashed into the case.
Old 09-07-2013, 03:24 PM   #21
67c10rustbuket
Looks good, they can do wonders on a frame straightening table.
Dan <---(my name)
Old 09-07-2013, 05:54 PM   #22
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Hey man if you need any help gettin it back together Id be glad to help (no expert by far at aligning panels but im in spokane as well!).
Glad ya got it back straight for a decent price!
John
1999 Toyota Tacoma 4x4
Old 09-08-2013, 11:59 AM   #23
Katrina/10
Katrina/10's Avatar
Wow, I didn't think it would straighten out that well!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-08-2013, 02:39 PM   #24
Tinkermc
I wouldn't say I told ya so, but I do believe that was very reasonable. Good time to switch rusty core support that you described.
Old 09-08-2013, 07:15 PM   #25
hugger6933
Looking at the pics I'd say the damage was mostly all contained in front of the front crossmember as I had thought in the first pic when you first posted. I am very glad for you that you found someone in your area that cares enough about you and your old truck to get it going again at a reasonable price. the front alginment with the deal after you complete the build with not only help your truck driver better but give you assurance that it was done right,but by that time you will have already had that because all of the sheetmetal and the bolts will have lined up properly. Jim
