Old 07-21-2013, 10:08 AM   #1
alabama mike
alabama mike's Avatar
What makes a custom cab?
I have a couple of C-10's ones a 65, the other is a 66, the 65 is a big back window and has custom can emblems on the side of the cab, I always thought all factory custom cabs had the big back window, I see quite a few trucks on the road with the custom cab emblems but with small back windows, I just took it for granted that that was an owner add, But yesterday I was talking to a local guy that owners a carlot called hotrods and harleys, he specializes in customs and bikes, he said that the big back window was an option to itself and you could get a custom cab either way. is that true, and if so just what makes a custom cab, custom?
Disabled Vet, Desert Shield/Desert Storm Veteran
"Proud to have served"
1965 C-10, 1965 C-60, 1966 C-10, 1975 C-20, 1986 M1009 Blazer, 1987 GMC 1/2 ton suburban, 1995 1500 Suburban 4x4, 2001 2500 Suburban 8.1L
alabama mike is offline   Reply With Quote
Old 07-21-2013, 10:42 AM   #2
cortcomp
cortcomp's Avatar
Re: What makes a custom cab?
He is correct, i have a custom cab with the SBW (just changed it to BBW). I think the BBW was called the panoramic view option? I THINK custom cab included the trim pieces on the pillars, two tone paint, seat padding, and steering wheel with horn ring? I'm sure there are other little things, there are a couple threads about factory options and details that you can get lost in reading for most of the day, pretty interesting stuff.
If you search for the 66 glovebox codes, we went through a lot of the options you would see on the sticker in the glove box (custom group (2 of those) panoramic view, etc, etc)
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-21-2013, 11:35 AM   #3
chevyrestoguy
chevyrestoguy's Avatar
The Custom Cabs also had the chrome windshield moulding and rear window trim.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-21-2013, 06:49 PM   #4
cortcomp
cortcomp's Avatar
I thought the rear window trip chrome was aftermarket? Not really chrome but chrome colored plastic coating on the lock bead? I do have the stainless around the windshield though, that seems legit.
Old 07-22-2013, 11:25 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by alabama mike View Post
...he said that the big back window was an option to itself and you could get a custom cab either way. is that true, and if so just what makes a custom cab, custom?
Yes, the Deluxe option was independent of the standard rear window or the panoramic rear window.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-22-2013, 11:38 AM   #6
alabama mike
learn something new everyday, My 66 is a small back window, with 2 tone paint, painted bumpers and grill, my 65 is a big back window 2 tone paint with chrome bumpers and aluminum grill. and your right my 65 has chrome around the windshield, but the 66 doesn't. Thank for the info, all these years I was thinking folks had been adding those cab emblems.
Old 07-22-2013, 11:51 AM   #7
1963c-10
1963c-10's Avatar
Your correct. The chrome bead in the rear glass channel is aftermarket. In 1960 & I believe 1961, there was a stainless strip that ran across the back of the cab connecting the sail panels together.
1964 Short bed trailer
Old 07-22-2013, 12:24 PM   #8
JWheeler331
JWheeler331's Avatar
Not to hijack the thread but how do the Pillar "Custom" cab trim attach? Anyone have any pictures of the back of the trip pieces? Mine is not a custom cab I do like the trim and have thought about putting it on mine.
JWheeler331 is offline   Reply With Quote
Old 07-22-2013, 01:46 PM   #9
cortcomp
cortcomp's Avatar
There is a thin piece of metal, about 5 inches by 1/2 inch, that screws, upright, to the rear side of the panel, then you slide the custom trim on to that, and secure it with screws in the door side, and i THINK the tail that wraps around? So the thin strip bracket and two screws are hidden
Old 07-22-2013, 01:57 PM   #10
JWheeler331
Thanks.
Old 07-22-2013, 02:22 PM   #11
1963c-10
1963c-10's Avatar
Correct. 3 screws in the door jamb and one on the back of the cab where it wraps. The retainer pad that mounts on the side of the cab is held on by two screws also.
Old 07-22-2013, 10:18 PM   #12
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 07-22-2013, 10:44 PM   #13
1963c-10
1963c-10's Avatar
nicely optioned truck
Old 07-23-2013, 12:56 AM   #14
rustbucket66
I just sold a 64 cab that was a BBW but was not a custom cab, just a plain Jane work truck. The only options it really had was the deluxe heater and big back window. BBW's were not always custom cab trucks.
rustbucket66 is offline   Reply With Quote
Old 07-23-2013, 06:30 AM   #15
aerotruk63
aerotruk63's Avatar
Blank 1966 Order Form. Lists the RPO ( Regular Production Order ) codes for building your truck the way you wanted. Notice there is no custom cab option.
1963 Chevrolet Truck Data Book information. The Salesman would use this book to explain to customers the different options available.
Old 07-23-2013, 06:48 AM   #16
jbgroby
jbgroby's Avatar
I didn't know rear shocks were an option. On my '60 they had them.
jbgroby is offline   Reply With Quote
Old 07-23-2013, 06:54 AM   #17
bonehead
bonehead's Avatar
[QUOTE=aerotruk63;6185987]Blank 1966 Order Form. Lists the RPO ( Regular Production Order ) codes for building your truck the way you wanted. Notice there is no custom cab option.
Could you send me a pdf scan of this 1966 order form. I would like to be able to enlarge it enough that I could read all of it. thanks )bone(
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 07-23-2013, 12:06 PM   #18
sodly
sodly's Avatar
I 2nd that emotion! I'd like to read this in detail, too.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 07-23-2013, 02:38 PM   #19
theastronaut
theastronaut's Avatar
Mine would seem to be a "Custom Cab" but it just had all of the options normally associated with a "Custom Cab" truck even there was never such an option.
Has the Z61 and Z62 Custom Group options, B98AA Side Trim Moulding, V37EA Chrome Bumpers F/R (includes chrome hubcaps), and A10AA Panoramic Cab.
This was posted by collins10672 in another thread:
Originally Posted by collins10672 View Post
the z61 is the custom cab package which includes aluminum grill,stainless steel windshield trim,custom cab plates,stainless trim on dash knobs,deluxe horn ring,and tutone white door panels.the z62 is the custom comfort package which includes passenger door lock,passenger side sunvisor,driver and passenger armrests,deluxe seat with full depth foam and heavy duty springs,and heavy duty cab insulation including heavy duty undercoating.v37 is the chrome front and rear bumpers which also included matching chrome hubcaps.custom cab trucks were normally stamped on the kick panel i.d. plate with the z61 trim code,but when they also included the custom comfort package the z61 was supeceded with the z62 trim code.your truck is saddle metallic and white tutone.i hope this helps and btw i am so jealous,just kidding that is a super project and i can't wait to see you work some of your magic on it like you did the blue 65.
theastronaut is offline   Reply With Quote
Old 07-23-2013, 04:29 PM   #20
1963c-10
1963c-10's Avatar
They probably used a different shock from stock as the truck was ordered w/auxillary springs which gave 500lbs more carrying weight on each side.
Old 07-23-2013, 08:51 PM   #21
rideblue00
rideblue00's Avatar
I would also like a scan of that 66 from too if possible.
rideblue00 is offline   Reply With Quote
Old 07-24-2013, 03:28 PM   #22
aerotruk63
aerotruk63's Avatar
I have a PDF scanner but I don't know how to download it to my laptop. Does JPEG as well and downloads fine.
PM me if you know how to do it,
Here's a link to the Order Form in Picasa, you can enlarge it.
https://plus.google.com/photos/11384...17762774560215
Old 07-24-2013, 08:47 PM   #23
oem4me
Here's a like to the Order Form in Picasa, you can enlarge it.
Awesome Norm. This subject has come up many times, but this is the first order form I've seen. It pretty much spells it out. Thanks bud.
Curiously, with a revision date of 8/65 for the 1966 model year, it still shows the 230 cu.in. six instead of the 250.
Old 07-25-2013, 09:05 PM   #24
aerotruk63
aerotruk63's Avatar
If anyone's interested, I took liberties while picking up a load of aluminum ingots to make photocopies of the 1966 order sheet on the suppliers photocopier. The copies came out clear though short on the bottom where it's printed zone copy. PM me your mailing address and I'd be happy to mail you a black and white copy to study. I could fold the sheet to make mailing less expensive but if you would prefer I could mail it out with a do not bend printed on the full page envelope.
Old 07-27-2013, 06:49 AM   #25
aerotruk63
aerotruk63's Avatar
Ford emblem
