TCI to start new R&D Project with a C10!
Check out their facebook page, this was posted earlier today. Looks like more options coming soon!
https://www.facebook.com/Total.Cost.Involved?ref=br_tf |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: TCI to start new R&D Project with a C10!
Nice.
Everyone is seeing the $$$ possibilities in producing C10 parts. They have the pre-'60 trucks covered. http://www.totalcostinvolved.com/c/2...Classic-Trucks Surprised it took so long to get to the 60-87 trucks.
I believe jim meyer racing was the first one and a few others came in slowly.But its not just these trucks the early mustang 10 years ago had a small aftermarket but it boomed about 5 years ago.
Yeah, I think Jim Meyer had an offering like 15 years ago, and still do. I'm surprised it is taking everyone else so long to jump on the band wagon!
http://roadstershop.com/ has a full frame that has a irs
The 'problem' w/any of these is price. The RS chassis will set you back around 15 large w/o the trick IRS.... That's a difficult chunk to pony up.
Yeah a full frame from anywhere is pricey now,Some places are 8k to 10k for a bare frame.
I'm just glad to be here!
I am following it on the pro-touring web site...looks interesting so far...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
*another update*
The first articles have had a few revisions through development but we're getting close. Here, Ed is changing the anti-dive angle to 7.5. ![]() A quick tack weld ![]() We also revised the crossmember. We raised it up to frame another inch and put a degree tilted back. ![]() Ed installing the upper plate onto the frame to confirm some simulations. ![]() -Jason |
Are you guys utilizing a CPP MOD Spindle for your front kit? Would love to see a truck kit come with truck spindles and not Mustang II's.
A pretty big change of plans. In order to use the CPP spindles we wouldn't be able to use the more readily available T-Bird rack without a big compromise in turning radius. The T-Bird power rack is the same rack that most aftermarket companies use to replace a manual MII rack. This rack does not have enough travel to be used on the CPP spindle because the steering arms are too long. The factory steering box has 7" of travel whereas the T-Bird and MII racks have 6". We'd lose 14% of the turning angle if we went this route. The other major compromise is that the tie rod end needs to fit into the spindle from the bottom instead of the top in order to keep the engine in the factory location. Once the tie rod is moved it limits your ability to run 15" & 16" wheels with any sort of backspace/width.
We mocked up our Custom spindle that we use on some of our Pro-Touring builds and it would work very well in this capacity. While this spindle works well in its current applications we feel that making something even more robust would be more fitting. So we will begin designing a new spindle immediately. Should only be a few weeks delay in production. -J |
#15 |
It's awesome that you are keeping with the ideology that 1/2 ton trucks need 1/2 ton truck rated suspension/steering components. Others seem to think MII spindles are sufficient, but let's face it, they were designed for cars that barely tipped the scale past 2,000 lbs. Not to mention the wheel bearings, which I brought up in a conversation recently with another vendor. The conversation seem to go down hill when I started mentioning L10 life for the bearings and how they are over loaded by 150% when ran on a truck weighing in close to 3k. Keep up the great engineering work, I'm quickly becoming more and more of a TCI fan!
#16 | |
Something that struck us as odd is the OEM C10 spindle pin is smaller than the MII pin. So basically the I/D of the C10 bearing is smaller than the MII bearing. Although the C10 bearings are larger overall, both width and O/D. If GM felt the pin was suffeciently strong enough, who are we to argue? We will base our new spindle pin dimensions off the OEM pin. Ours will just be made out of Chro-Moly. This way replacement parts like rotors and bearings will also be OEM. -J |
#17 | |
Wouldn't GM have likely based decisions of the 'pin' design & dimensions w/the vehicles anticipated use in mind which likely wasn't near what the current trends are (autocross specifically). Just wondering out loud here. Obviously you guys put alot of thought into what you design.
#18 | |
![]() Again, kudos to you TCI, for the great development going on! |
#19 | ||
![]() -J |
#20 | |
#21 |
#22 |
Awesome job guys! keep it up. How much shock travel are you expecting for the front? Looks like you could get 5" with 12" springs.
#23 |
That's looking good!
#24 | |
![]() -J |
#25 |
It is a good thing you are not using the modular spindle. They do not hold up to racing. The pin would actually deflect in the spindle. I went as far as welding them front and back on the pin to help this but it was not enough they still flex bad enough to cause brake knock back.
These trucks are really hard on parts in a autocross/road race environment. |
