Old 08-01-2013, 07:27 AM   #1
DirtRocket8x
What make 205
Need help is this a np 205 but is it chevy or dodge
DirtRocket8x is offline   Reply With Quote
Old 08-01-2013, 07:31 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: What make 205
need a pic of the back to ID the case for sure. But it looks like a TH400 bolt pattern in the pic.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-01-2013, 08:05 AM   #3
DirtRocket8x
Re: What make 205
Old 08-01-2013, 08:08 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: What make 205
NP205 for sure
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-01-2013, 08:10 AM   #5
DirtRocket8x
Re: What make 205
Old 08-01-2013, 08:11 AM   #6
DirtRocket8x
Re: What make 205
Old 08-01-2013, 08:22 AM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: What make 205
Gm
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-01-2013, 10:36 AM   #8
snj8198
snj8198's Avatar
Re: What make 205
yep, looks like a late model GM 205, slip yoke style, 6 bolt round pattern, 32 spline, found behind turbo 400's from '88-'92? and NV4500's '93 up.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 08-01-2013, 10:44 AM   #9
DirtRocket8x
Re: What make 205
Ok thanks
Old 08-01-2013, 10:50 AM   #10
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: What make 205
I got the same unit in my 85 K3500.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-01-2013, 10:52 AM   #11
Redcap
Re: What make 205
Round-6 TH400 version of NP205. For sure.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 08-01-2013, 11:04 AM   #12
DirtRocket8x
Re: What make 205
What crossmember did u use to put it in ?
Old 08-01-2013, 11:18 AM   #13
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: What make 205
Its original to the k3500. It has the W style cross member.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-01-2013, 11:26 AM   #14
dieseldude4bt
Re: What make 205
It's not a round, its a figure 8 with a turbo 400 adapter
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 08-01-2013, 04:07 PM   #15
72chevyk10
I built it
72chevyk10's Avatar
Re: What make 205
i dont see an adapter..?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 08-01-2013, 07:58 PM   #16
b454rat
Re: What make 205
That is a late 80s TH400 version NP 205. Figure 8 has a taller adapter, that one is short. Could be swapped in,but has the electric plug for 4wd on shift rail....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-01-2013, 10:23 PM   #17
72chevyk10
I built it
72chevyk10's Avatar
Re: What make 205
actually should say, dont see the figure 8 part of it..
Old 08-02-2013, 07:17 AM   #18
Redcap
Re: What make 205
You must be partially blind.
Old 08-02-2013, 09:47 AM   #19
dieseldude4bt
Re: What make 205
Round pattern 205
http://www3.telus.net/u2slow/v3500/gm_np205_round.jpg
205 with turbo 400 adapter same as original pic
http://www.google.com/url?sa=i&sourc...75536952803624
If you have to be rude maybe you should not be giving advice!!
Old 08-02-2013, 11:15 AM   #20
dieseldude4bt
Re: What make 205
I could be wrong, but most 1984 and down turbo 400 205 had figure 8 with adapters.
We dont need to be rude to have a discussion.
The second pic in the above post is not what I was looking for sorry about that, wont let me edit now. And I cant seem to find one of the figure 8 to turbo 400.
Old 08-02-2013, 12:06 PM   #21
dieseldude4bt
Re: What make 205
DirtRocket8x could you post a pic of the front of the case where the adapter bolts to it?
The one you have is a little to close to see the back of the adapter.
Old 08-02-2013, 01:13 PM   #22
72chevyk10
I built it
72chevyk10's Avatar
Re: What make 205
i have the one for the figure 8 and th400. it looks a lot like the th350-205 adapter..
Old 08-03-2013, 12:04 AM   #23
dieseldude4bt
Re: What make 205
After much photo searching it appears that the adapter I thought looked like my old 84 turbo 400 205 is in fact one on a round pattern 205 . I was wrong and can accept that.
Round patter turbo 400 adapter:
figure 8 turbo 400 adapter:
Old 08-03-2013, 10:12 PM   #24
snj8198
snj8198's Avatar
Re: What make 205
I've watched your build, enjoyed it.
Steve
Old 08-03-2013, 11:17 PM   #25
franken
Re: What make 205
So what are the plans for the 205?
