Old 08-20-2013, 12:27 PM   #1
Big bad Green
Big bad Green's Avatar
Question about my 1971chevy truck k20
I bought my 1968 chevy truck k20 and it came with a 71 k20 also I got the vin plate and the title also. My question is if the vin tag is from a different truck it has no glove box so I can't look up the spid card the truck has been painted once so my question if the vin plate do people remove it to paint a truck? The cab appears to be a k20 cab has cab lights with the humps for the cab lights in the roof. The frame is all 3 /4 ton it has v8 motor mounts in it also the truck was also a standard at one point because there is a hole in the cab where the couch linkage was I also have a manual steering Column that came with it I have all the parts for it here's the truck and vin is ke24IT601076
1968 Chevy K20 Long bed dump truck
1978 Chevy Custom deluxe long bed
1986 Chevy Custom deluxe short bed
1987 Chevy Custom deluxe short bed
1987 Chevy Silverado short bed
1990 Chevy Silverado K5 Blazer
All four wheel drive! All non mutt trucks!
Big bad Green is offline   Reply With Quote
Old 08-20-2013, 12:28 PM   #2
Big bad Green
Re: Question about my 1971chevy truck k20
Old 08-20-2013, 12:32 PM   #3
Big bad Green
There's red Peaking under the green
Old 08-20-2013, 12:35 PM   #4
JOJABOY
Just curious does the VIN (number) on the VIN plate match the number on the driver side frame rail? Do not remove the VIN plate to paint. Use a chemical stripper in that area the mask the VIN plate before painting.
JOJABOY is offline   Reply With Quote
Old 08-20-2013, 12:51 PM   #5
Big bad Green
There's a vin plate on the frame?
Old 08-20-2013, 01:19 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
No, there is apartial vin stamped on the top of the frame near the steering box
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-20-2013, 01:37 PM   #7
JOJABOY
It's no big deal if it doesn't match. DMV only cares about VIN plate on cab. But since you mentioned that the cab did not have a glove box door and SPID.....I just mentioned it. Curious as to if that cab came on that frame.
Old 08-20-2013, 02:10 PM   #8
Big bad Green
Are the numbers spoest to match some numbers on the vin plate?
Old 08-20-2013, 02:19 PM   #9
Ol Blue K20
Yes its a partial, i don't remember how many digits it is
Dale
Old 08-20-2013, 02:37 PM   #10
Big bad Green
Can i get a photo on Were it Is at?
Old 08-20-2013, 02:40 PM   #11
Ol Blue K20
I'm at work, but I will take a pic tonight..Hopefully some one can post a pic before me.
Dale
Old 08-20-2013, 02:53 PM   #12
Classic Bowties
Always on the hunt...
This varies state to state, would be best to check in with your local dmv office on that. Mel
Classic Bowties is online now   Reply With Quote
Old 08-20-2013, 03:37 PM   #13
JOJABOY
It on top of the frame rail on the drivers side.
Old 08-20-2013, 03:41 PM   #14
JOJABOY
I bought my 1968 chevy truck k20 and it came with a 71 k20 also I got the vin plate and the title also. ..... and vin is ke24IT601076
Are you saying you have the title for the truck pictured and the VIN is KE241T601076?
If you have the title, it shouldn't be a problem registering it regardless of what the frame rail is or anything else. It's all about the cab, the VIN plate and the title.
You can put 1972 fenders, hood and grill on it and turn it into a 2wd shortbed and still register it as a K20 if that is what the VIN plate and title read.
Old 08-20-2013, 03:45 PM   #15
JOJABOY
KE241T601076 = 1971, 3/4T, 4X4, (K20), gas engine, pick up (cab and bed) built in Tarrytown, Serial # 601076
You say you have a 1968 as well? Title on it too???
Old 08-20-2013, 04:19 PM   #16
Big bad Green
I just want to know uf Its had a cab Swap are the numbers on the frame on a tag?
Old 08-20-2013, 04:24 PM   #17
Big bad Green
I just want to figure out what I got
Old 08-20-2013, 04:27 PM   #18
JOJABOY
frame numbers should match the VIN plate.
Old 08-20-2013, 04:47 PM   #19
briank
The numbers in the frame are stamped in the frame itself. You may have crud or rust to remove. I thought on one of mine they were actually stamped on the front frame horn too I believe
briank is offline   Reply With Quote
Old 08-20-2013, 09:25 PM   #20
Big bad Green
Any pics?
Old 08-21-2013, 10:32 AM   #21
Ol Blue K20
Here's some pics of my vin on my frame (as promised)
Dale
Old 08-21-2013, 11:37 AM   #22
Big bad Green
Thanks dale
Old 08-21-2013, 11:38 AM   #23
Big bad Green
Old 08-21-2013, 11:48 AM   #24
Ol Blue K20
The fender is 69-72 and the grill is 71-72..you can always send me the grill if you don't want it..
Dale
Old 08-21-2013, 12:11 PM   #25
Big bad Green
