03-16-2014, 07:05 AM | #1 |
Re: 63 full frame build help!!!!
Nice work.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
03-16-2014, 05:16 PM | #2 |
Cutoff access and tacked
03-16-2014, 05:21 PM | #3 |
Fishplates on bottom and inside
03-16-2014, 05:27 PM | #4 |
Some more fishplates
03-16-2014, 05:31 PM | #5 |
Sorry for the sideways pics
03-16-2014, 05:36 PM | #6 |
Have rad mounts and front crossmember in
06-01-2014, 11:21 PM | #7 |
Got a chance to look in on your progress.
Totally dig those motor mounts. |
06-02-2014, 07:53 AM | #8 |
As long as it fits, nice job
06-02-2014, 08:18 AM | #9 |
Awesome work!!!
I look forward to watching this one more closely... subscribed. peace - rg |
06-02-2014, 11:33 AM | #10 |
Thanks for the comments guys
I've been working in chopping up the front crossmember and building my 4 link bars. |
06-02-2014, 11:35 AM | #11 |
Here is a shot of all four bars should have it tacked in today
06-02-2014, 11:38 AM | #12 |
One side of crossmember cut up to see if it'll work for what I need. I need all the suspension I can get laying this out on the 24s
06-02-2014, 11:36 AM | #13 |
As for the crossmember I have a lot more cutting and plating to do
06-02-2014, 10:28 PM | #14 |
What size of tire you plannin?
Im runnin 22's with somewhat tall tires. 32" overall height. Your bars look killer. |
06-04-2014, 11:20 PM | #15 |
My overall height is 321/2 I've been messing with the 4 link. Not sure if there is enough triangulation but angles and length work nice 3 degree over the full sweep.
06-06-2014, 04:06 AM | #16 |
Shot from the side
06-12-2014, 03:27 AM | #17 |
Thats some nice fab work man. Hopefully I will get some time off work to get inti mine more. Working OT right now to get some parts ordered.
1965 C10 Project |
10-18-2014, 10:50 PM | #18 |
haven't posted in a long time. have been busy working on truck. here is a bunch of pics of progress. the front and rear suspension is done now minus watts link. Frame is off the table and motor and trans mounted. put temporary airline which will work for the final setup. It rolls now which is a great accomplishment. for the front i made some rack mounts, used porter built hardware kit. cupped the lower arms and shortened them. i used cpp uppers cause they were cheap and available they work good for me. I had to flip them side to side and upside down (upper ball joint was binding)
10-18-2014, 11:01 PM | #19 |
some pics of the 4 link. Wasn't happy how triangulated worked so went parallel and will do a watts link when i get the fuel tank figured out
10-18-2014, 11:10 PM | #20 |
frame on the ground and cab sat on to see how much firewall modification.
10-18-2014, 11:27 PM | #21 |
had to move the firewall back quite a bit. gave me and excuse to buy a english wheel and bead roller
10-18-2014, 11:42 PM | #22 |
made up a bracket for m/c. wanna keep wipers so had to goto the left rather right . Found another yard not far from home. Got a gauge cluster, seats and console out of a tahoe
10-20-2014, 11:28 PM | #23 |
You sir, are an artist! Not my style, but very admirable and a true demonstration of skill! I do not believe that truck would make it to far one of these 'ol Blue Ridge Mountain back roads, but I am sure it'll cruise along fine on the prairie. Please keep the photo's coming!
Thanks!
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
11-18-2014, 12:38 AM | #24 |
A few pics of wiring and rust repair. the first pic is the engine fully wired, minus the coil packs aren't on. I used a fuse and relay from a 98 caravan. The repair panels i used for the headliner and front brow are from a 65 so i had to use the front corners from my original headliner panel.
11-18-2014, 12:51 AM | #25 |
here is the difference between 60-63 and 64-66 panel. panel is all ready to weld tomorrow. here is a truck i bought today for 100 bucks runs great gonna use the 5.3 for my parts truck eventually
