Old 08-31-2013, 12:21 PM   #1
ericjon262
262's 1970 GMC
Picked up a 1970 GMC last week, the plan is to restomod it, keep it mostly stock, possibly an updated powerplant, definitely an updated transmission(want overdrive), and a good refresh of the paint. interior will be stock.
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 08-31-2013, 12:31 PM   #2
MusicMan70
MusicMan70's Avatar
Re: 262's 1970 GMC
Welcome Eric, nice truck! What does the SPID show for color code?
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-31-2013, 12:36 PM   #3
ericjon262
Re: 262's 1970 GMC
Thanks!
I have the dealer tag, but I haven't seen the spid anywhere. where would it be on one of 70 model? glovebox?
Old 08-31-2013, 06:23 PM   #4
ole dollor
ole dollor's Avatar
Re: 262's 1970 GMC
great looking truck you got there, nice score....i like it
ole dollor is offline   Reply With Quote
Old 08-31-2013, 08:41 PM   #5
ericjon262
Re: 262's 1970 GMC
Thanks, I think I got a sweet deal, I only paid $2300 for it.
I started working on the tailgate today, I'm going to repaint around where it say's GMC white again, and then paint "GMC" red. I think it should look pretty good. I'll post pictures tomorrow.
Old 09-01-2013, 07:11 PM   #6
ericjon262
Re: 262's 1970 GMC
A little bit of progress
The overspray has been removed. overall right now, it's good from afar, but far from good! I'm not too worried about it though, because I plan to replace the tailgate in the near future before I respray it.
Here's a shot of the SPId sheet. hard to make out, but the color was listed as Dark Gold.
Old 09-22-2013, 11:18 PM   #7
ericjon262
Re: 262's 1970 GMC
it's dirty under there...
what is all of this???
on the firewall near the HVAC box.
on the driver's side core support, looks like a relay?
Looking better, "good from afar, but far from good"
Old 09-23-2013, 02:34 AM   #8
marvgarr68
marvgarr68's Avatar
Re: 262's 1970 GMC
that box you called a relay is the voltage regulator for alternator. You might have a internal regulated alternator on it no picture of it so can not be sure. The wiring by the heater box I am not sure I tore it all out of my 71 c20 I had got ride of all the extra wiring.
And looks good nice truck
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 09-23-2013, 12:34 PM   #9
Zeke's Garage
Zeke's Garage's Avatar
Re: 262's 1970 GMC
I can see that someone 'fixed' a 'heat soak' problem by installing a Ford type solenoid on the passenger fender. If you're looking to clean up the electrical mess, you can start by removing that solenoid and making sure your main battery cables are clean and tight, and that your starter solenoid wire (should be purple) is in good shape going to the starter. The small relay/solenoid on the firewall almost looks like a relay for a later model emission 'anti dieseling' feature, but can't even imagine why it would be there. What's it hooked up to?
Also any wire that has black electrical tape 'insulating' a splice or worse yet, hiding a wire nut or two, needs to be replaced with a new run. Those kinds of fixes will oxidize and turn into high impedance gremlins in just a few years.
The wiring on these trucks are dead simple. Get the colorized wiring diagram (It's around here someplace, I'll attach it if I can find mine) and go through each circuit from the bulkhead connector to the device and clean up one thing at a time. You'll have it cleaned up (and less of a fire hazard) in no time.
Good luck!
Shawn
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 09-23-2013, 03:44 PM   #10
ericjon262
Re: 262's 1970 GMC
Good luck!
Shawn
The relay on the firewall didn't appear to be hooked up to anything. I need to trace it back better though.
I Already have a new battery cable to fix the "fix" the PO did for me. I plan to re-wire the whole truck (as you said, it's dead simple) and intend to incorporate a few modern touches,
Electric Fans
headlight relay
electric fuel pump/EFI
A/c
all in a nice little relay center like the late model trucks have. thankfully, I'm not new to wiring, this will be a walk in the park compared to my Fiero's engine swap harness.
my favorite part that you can't see, is the 4 Ga wire connected to B+ and run through the firewall with no grommet or protection...
Old 09-23-2013, 04:06 PM   #11
ole dollor
ole dollor's Avatar
Re: 262's 1970 GMC
the relay next to the heater box is the high blower relay. the two wires you were holding in your hand look like old wiring for temp and or oil gage for dash light warning ( idiot light) . yours prop. has mechanical gages in it now.
Old 09-23-2013, 04:15 PM   #12
ericjon262
Re: 262's 1970 GMC
the gauges appear to be stock, oil pressure is mechanical, temp is electric. I'll just have to find a diagram and trace them back and see. hopefully I can do that this weekend. if anyone has the diagrams available, I'd love to see them so I can familiarize myself with the colors.
Thanks-
Eric
Edit:
Anyone have a P/N for radiator hoses? I remember looking ages ago, and not being able to find one that fit properly.
Old 09-23-2013, 04:40 PM   #13
ole dollor
ole dollor's Avatar
Re: 262's 1970 GMC
the wires came in all the custom pickup wiring harness, whether it was light or mech. gage. the one that has something plugged into it looks like the top off of an old sending unit, it would have been plugged into the passenger side of the block to the rear, if yours is the original motor the other part should still be there in one of the water jacket plugs....
Old 09-23-2013, 04:44 PM   #14
ericjon262
Re: 262's 1970 GMC
not the original engine, this one is an older 327 block with vortec heads.
Old 09-25-2013, 05:36 PM   #15
ericjon262
Re: 262's 1970 GMC
The box on the core support is most definitely the voltage regulator, the one on the firewall is still unknown. I assume is was something to do with emissions, or the choke, there's one green wire(which gm usually uses for temp sensors) a blue wire, a black wire, and a red wire. the red goes to the firewall just to the left of the master cylinder. I'm going to get a multi-meter(need to buy a new one) and check for voltage and see if it's hot still.
Old 09-25-2013, 06:49 PM   #16
SCHRUMGMC
SCHRUMGMC's Avatar
Re: 262's 1970 GMC
Only thing I'd change on that is the Side markers
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 09-26-2013, 12:09 AM   #17
ericjon262
Re: 262's 1970 GMC
as in delete them? I like them, I think the truck would look weird without them.
Old 09-26-2013, 12:10 AM   #18
SCHRUMGMC
SCHRUMGMC's Avatar
Re: 262's 1970 GMC
No, heck no ...I mean like Deluxe Markers
1971 GMC Sierra
1959 GMC 100
Old 09-26-2013, 12:17 AM   #19
ericjon262
Re: 262's 1970 GMC
I'm gonna stick with the plain ones and maybe throw some LED's in.
Old 09-26-2013, 12:22 AM   #20
SCHRUMGMC
SCHRUMGMC's Avatar
Re: 262's 1970 GMC
Okay, I just love the Deluxe look
1971 GMC Sierra
1959 GMC 100
Old 09-26-2013, 06:28 AM   #21
OhioDan
OhioDan's Avatar
Talking Re: 262's 1970 GMC
If ya squint, from a distance you're truck looks familiar? Welcome to the boards from Ohio.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 09-28-2013, 08:42 PM   #22
ericjon262
Re: 262's 1970 GMC
uhhh... ****! well, no more radio for a bit, PO did a real great job with that! along with the tachometer wiring...
I'm tempted to go ahead and just but a new interior harness at this rate. the engine harness will be redone either way, so that's no biggy...
Old 09-28-2013, 08:43 PM   #23
ericjon262
Re: 262's 1970 GMC
nice looking truck! 3/4 or 1 ton?
Old 09-29-2013, 03:55 AM   #24
OhioDan
OhioDan's Avatar
Cool Re: 262's 1970 GMC
It's a 3/4 ton. Bought it down in Texas while I was there back in 84-85.
Old 09-29-2013, 04:00 PM   #25
ericjon262
Re: 262's 1970 GMC
presenting plug number 4
and plug number 6
looks like I have a reason to start on the engine swap.
