Old 09-10-2013, 10:35 PM   #1
restorationboy14
Putting a diesel in my 69 GMC? What engine to use?
I have a '69 GMC with no engine. So I thought id try my hand at a diesel with some stacks to make it a puller. Now the problem for me is is this. One thing. Money. Im a highschool student working on a farm but havnt gotten the chance too since school. So heres my plan, getting a diesel in her and getting a tranny behind it. Ive never worked on a diesel engines before. What kind of mounts do I need? whats the most inexpensive engine that I can get and keep suspension mods and a zero or at a minimum. I want to put a 5 speed behind it and make it roll some coal. So what can I use for a 5 switch? So the main question is this. Im lookin for a I6 or even a 4 banger, just want some torque and a five speed. Im in Nebraska as far as prices go. Thanks Guys!!!! Thanks again and cant wait to start the BUILD!!!!
restorationboy14 is offline   Reply With Quote
Old 09-10-2013, 10:58 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Putting a diesel in my 69 GMC? What engine to use?
If money's short toss in a 350 and trans of your choice. Going diesel is never cheap. I run a 12 Valve Cummins in my burb and even with a donor truck the cost was much more than a traditional small block.
Get the old gal running and driving with a gasser and when you have more cash start planning a diesel swap and buying parts. A truck on the road is much more fun than one in the garage.
-And rolling coal is just wasting fuel and abusing your hard earned parts. I have a small haze under full throttle and can pull my trailer at 80 plus without thinking about it at part throttle. And that's with 35s and a lift.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-10-2013, 11:16 PM   #3
mmiddle
mmiddle's Avatar
2X ^
A truck on the road is better than two in the garage. Converting to diesel is no small task. Going with a 4 cylinder will help on the weight issues only, but you won't like the power. It will run out of legs real quick.
Get the truck running on a gasser and enjoy it. Then look for a 3/4 or 1 ton to drop a Duramax into and tune it with EFI Live. BIG POWER!
Chicks dig old trucks... you'll soon find out. Use your money and time making it a chick magnet.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-10-2013, 11:23 PM   #4
Syndrome
Do a Cummins 6bt or 4bt. Go Cummins or go home. And if you do the 4BT with twins then you wont run out of legs, it will make a 350 look stupid.
BTW Cummins is American, I believe the Duramax is Isuzu.
1970 GMC
Syndrome is offline   Reply With Quote
Old 09-11-2013, 07:16 AM   #5
Bigdav160
Bigdav160's Avatar
The easiest and the cheapest would be a 6.2/6.5L Chevrolet.
Any transmission able to put up with a diesel is likely to be as costly (or more) than the engine.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-11-2013, 07:18 AM   #6
Bigdav160
Bigdav160's Avatar
The two (24 valves) in my daily drivers were made in Brazil
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 09-11-2013, 07:41 AM   #7
Syndrome
American design, where as the duramax is designed by Isuzu. Nothing is actually made in America anymore.
1970 GMC
Old 09-11-2013, 03:20 PM   #8
Dova
Dova's Avatar
For price, the 6.2/6.5 is the cheapest way to go. What you want to do with it is going to be what costs the most money. A cummin's swap as said would be expensive but is the best diesel to have in one, but a lot of work and money.
Dova is offline   Reply With Quote
Old 09-11-2013, 09:00 PM   #9
hugger6933
I lot of people are telling you to put in a 350 and drive, that is true. You should find one with a tranny and be up and running for around 1200 to 1500 depending on what you already have with the truck and if you have some help that know something about trucks. Now to get a Diesel in and running and driving in that same truck [assuming it is 2wd] it is gonna cost around $4000 to $6000 still assuming you have some help that has some knowledge. This isn't a project for the faint of heart or weak of wallet. I don't want you to give up on your dream, I build and rebuild trucks for a living and have since I was a teen and opened my my own shop in 1987.
hugger6933 is offline   Reply With Quote
Old 09-11-2013, 09:02 PM   #10
Shortie
Junior Member
Shortie's Avatar
The cummins swap wont be that bad money wise, can pick up a decent 12 valve 6bt for $1000 all day long up here.
best thing would be find a pre 98 ram thats rotten and use it for a doner
Shortie is offline   Reply With Quote
Old 09-11-2013, 09:59 PM   #11
Bad Jackson
Cummins!!!!!!
I work with tools.
Bad Jackson is offline   Reply With Quote
Old 09-11-2013, 10:15 PM   #12
marvgarr68
marvgarr68's Avatar
6.2/6.5 turbo mounts bolt to it any small block tranny will bolt to it parts are cheap they don't weigh much more then a big block good on fuel and last for ever if you don't abuse them. A cummins swap is expensive and heavy have to use a tranny with a cummins bellhousing bolt pattern. Also parts for cummins is expensive and a lot of modification. Do not use the 5.7 diesel you may find it cheap still do not use it.
marvgarr68 is offline   Reply With Quote
Old 09-11-2013, 10:25 PM   #13
Shortie
Junior Member
Shortie's Avatar
6.2/6.5s are junk tho. Never seen one that didn't have horrific blow by. The cummins may be a bit heavy but parts are readily available and considerably easier to work on.
Chances are you will want more power out of it down the line, honestly when is enough really ever enough, and a p-pump 12 valve will be one of the strongest bases to build off
Old 09-11-2013, 10:42 PM   #14
marvgarr68
marvgarr68's Avatar
Never had one that was junk just tore mine down had 275000 miles and looked like it had only 50000 on it. Like I said if you take care of them which might not be a good idea being you have never worked on a diesel. Maybe get some hands on before you swap something in your truck. My .02
p.s not trying to steer you away from a diesel swap just better to know how to work on them when swapping
Old 09-12-2013, 01:52 PM   #15
Dova
Dova's Avatar
They get a bad name the 6.2/6.5 because they're not the powerhouses that cummins are. Member 67_C_30 I believe is the one who did a 6.5 swap into one and it is a very well documented build thread.
Old 09-12-2013, 02:40 PM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I used to work as a fleet mechanic for the Post Office here in Fort Worth Texas. We had a whole bunch of 6.5 powered trucks and they were very good ones. The drivers just put the accelerator on the floor everywhere. Across the whole fleet, I don't ever remember needing to go into one of the engines. Basically injector pumps were about the only thing we ever had to mess with. They clattered their way down the road six days a week driven by abusive drivers.
Tx Firefighter is offline   Reply With Quote
Old 09-12-2013, 05:40 PM   #17
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
12 valve cummins.
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 09-12-2013, 07:43 PM   #18
Codez67Chevy
Codez67Chevy's Avatar
Cummins is German my friend. Look it up. But still a great motor.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 09-12-2013, 07:44 PM   #19
Codez67Chevy
I would do Cummins or a D-Max.
Members I've met...
Mister-B
Old 09-12-2013, 07:51 PM   #20
Codez67Chevy
My mistake thinking of a different motor, don't mind me.
Members I've met...
Mister-B
Old 09-12-2013, 08:24 PM   #21
Syndrome
Here's a link on their Headquarters building..
http://en.wikipedia.org/wiki/Cummins...ffice_Building
1970 GMC
Old 09-12-2013, 10:02 PM   #22
clinebarger
Have you ever had a 4BT? That thing will shake the teeth right out of your head. What good are Twins without supporting mods on a 3.9L?
6.6 Duramax engines are built by DMAX LTD. in Ohio, A joint venture between Isuzu & GM, Yes Isuzu designed the engine FOR GM, So what......Isuzu has a lot of light/medium duty diesel experience.
The founder of Cummins Engine Co. Clessie Cummins was born in Indiana.
clinebarger is offline   Reply With Quote
Old 09-12-2013, 10:15 PM   #23
1972RedNeck
1972RedNeck's Avatar
You could have it balanced.
My opinion? 6>8
Hard to come by, but an Onan/Cummins 6AT will mate to a SBC/BBC bellhousing. I think* the motor mounts are similar to a 250 or 292.
*I am thinking that I read this somewhere but could be wrong
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-13-2013, 11:19 PM   #24
clinebarger
My opinion? 6>8
It's not a balance issue.....All 4 cylinder engines without harmonic/balance shafts shake. A 17:1 4-cylinder will shake ALOT, Only firing 2 cylinders per crank revolution makes this an Inherent issue.
All engine manufacturers balance rotating assembly's.
How is 6 greater than 8? All B series Cummins owners think their engine's are supreme. In my opinion if Cummins made a V8 version of the B series....It would be "all the rave"!
Old 09-13-2013, 11:58 PM   #25
Syndrome
Doesn't seem to be shaking to bad. Can't be 100% positive but looks very fun to me.
1970 GMC
