Old 09-16-2013, 08:31 PM   #1
79Betty
79Betty's Avatar
Question Shimming after swap?
I went from a 350/203 to a 465/205... Torqued everything right while apart... But after i got done my starter just makes a... Growing/grinding/horrible noise and it won't turn it over... The flywheel looks good, it's brand new... 11" if i remember right. How do tell how much it needs adjusted? How do you adjust it? I tried the starter off my 350 and it made this noise, so i pulled the one off my c30 parts truck which looked pretty new, and same noise... Help! I'm ready to drive this thing lol
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-16-2013, 08:55 PM   #2
geezer#99
geezer#99's Avatar
Re: Shimming after swap?
Are you using the correct knurled shank starter bolts and a brace on the end to the block?
Old 09-16-2013, 08:59 PM   #3
79Betty
79Betty's Avatar
Bolts yes! Brace no as i don't have one before i even bought the truck. Neither does my dually
Old 09-16-2013, 09:10 PM   #4
geezer#99
geezer#99's Avatar
Get a brace. It will help.
Meanwhile slide underneath and manually slide the gear from the starter drive into the ring gear teeth. A screwdriver works to lever it. See how the teeth mesh. Shim the starter so that a paper clip will fit where the teeth mesh. Also look for how deep the starter gear goes into the ring gear teeth.
Once you have that set up have someone crank it over for you and watch what the starter does. If it deflects you might need new bolts and a brace.
Old 09-16-2013, 09:16 PM   #5
79Betty
79Betty's Avatar
What do you mean by deflects? Also where could one get a brace? Nearest j-yard is louisville, almost 2 hours away
Old 09-16-2013, 10:13 PM   #6
geezer#99
geezer#99's Avatar
DEflects. It will move on the end closest to the motor mount due to the torque of the rotating starter motor. THat's why a brace helps. And new bolts help too. Without a brace the old bolts get bent a touch and when you tighten them they'll move the starter enough to make it grind. Summit has braces. Here's a sample.
http://www.summitracing.com/parts/nal-354353
If you're handy with a hammer and hacksaw you can make one from a piece of angle iron.
Old 09-16-2013, 10:28 PM   #7
faribran
If you have all the correct components, no shims will be needed. As mentioned earlier, the front brace is very important. Good luck, keep after it, you will figure it out.
faribran is offline   Reply With Quote
Old 09-16-2013, 10:30 PM   #8
79Betty
79Betty's Avatar
I don't have any spare iron around... Had to use it for my step braces. It's only 10 bucks too... I'ma stop in at o'reilly's abd get some new bolts n shims... Thanks geezer for the input. My truck was a mud truck who's philosophy was less is better... Not always true lol.
Old 09-17-2013, 07:11 PM   #9
79Betty
79Betty's Avatar
Little progress? I got it to spin over and it will, just seems like it isn't turning fast or hard enough? Even with 24V to it. Gap looks good i had 2 1/32 and 2 1/64 shim in just the left bolt farthest from the crank.
Old 09-17-2013, 08:15 PM   #10
79Betty
79Betty's Avatar
Now i got it to fire... And starter stayed engaged.. Pulling my hair out at this point
Old 09-21-2013, 05:13 PM   #11
79Betty
79Betty's Avatar
Anyone have a clue? Swapped i different column to see if different ignition switch fixes it and it didn't. .020 .040 n .060 none fix it. I'm at a loss. Only thing different now is my 4spd and 205 switch why wouldn't it stay the same?
Old 09-21-2013, 07:44 PM   #12
geezer#99
geezer#99's Avatar
Wired wrong!
Purple wire from ignition goes to 'S' terminal on solenoid.
Old 09-21-2013, 09:54 PM   #13
79Betty
79Betty's Avatar
But the stickler tickler is i never touched the wiring. Only difference is i went from a 78 k20 wiring in cab harness to a 77 c30 harness. Are there supposed to be 4 pink wires tied into 1? Looked like heavy guage wires as well... Looked factory.
Old 09-21-2013, 11:05 PM   #14
geezer#99
geezer#99's Avatar
Can't tell without a pic.
Why the wiring change?
Old 09-22-2013, 09:37 AM   #15
79Betty
79Betty's Avatar
Cab swap. Went through the wiring and looked it over it looks alright. Rewrapped it. Plugged it all in. Weird thing is when i bought the dually it started
Fine and i drove it home... Until it threw 2 rods :/
Old 09-22-2013, 10:10 AM   #16
geezer#99
geezer#99's Avatar
Well it sounds like you're getting power to the purple wire from somewhere in your wiring harness. When it keeps cranking does it stop if you turn the ignition switch off?
Old 09-22-2013, 10:20 AM   #17
79Betty
79Betty's Avatar
It will pull back if i have it shimmed close enough. Some did some didn't. Figured when i did it was shimmed right just sething else fudged up. I just wana roll it down a hill... Lol
Old 09-22-2013, 10:25 AM   #18
geezer#99
geezer#99's Avatar
[QUOTE When it keeps cranking does it stop if you turn the ignition switch off?[/QUOTE]
If you answer this question we can figure it out!
Old 09-22-2013, 10:26 AM   #19
79Betty
79Betty's Avatar
Sorry meant yes my bad
Old 09-22-2013, 10:39 AM   #20
geezer#99
geezer#99's Avatar
So that means nothing wrong with your wiring in cab. Problem lies at the starter.
Check the wiring there. Pull it off, clean the solenoid connections and the wires, make sure you have no bare spots on the wires and see what it does.
Old 09-22-2013, 10:44 AM   #21
79Betty
79Betty's Avatar
I'll try that again. At wallart right now gettting groceries... Well she's getting groceries i'm reading off road mag lol. I took one of my other ones in to o'reilly's and i'll try it instead of the rebuilt one. See what happens.
Old 09-22-2013, 02:13 PM   #22
79Betty
79Betty's Avatar
Well took the r-starter off. Put on good tested one. Same thing. Just sounds horrible and not right still. Good clean connections and no bare wires. Purple to right terminal other 2 to top. .020 shim stays as does .040 and .060
Old 09-22-2013, 02:19 PM   #23
geezer#99
geezer#99's Avatar
Purple to right terminal is wrong. IIRC it's purple to left terminal which should be marked 'S'.
Old 09-22-2013, 02:25 PM   #24
79Betty
79Betty's Avatar
Left is r right is s i meant rifht as looking toward rear axle or "front" of starter. Was it was with my automatic as well...
Old 09-22-2013, 02:39 PM   #25
geezer#99
geezer#99's Avatar
OK I see my manual shows only one terminal which has the purple wire and it is on the right closer to the block. What's the other two wires for or hooked to what? I assume one comes from the battery. What about the other one?
