Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-23-2013, 07:31 PM   #1
Operatorfailure
Quarter mile estimate?
I'm curious as to what my time will be, 68 swb stepper with a stock 5.3/4l60, cai and a tune. Street tires with 3.73 posi. Any guesses? I'll be going friday night to see for sure.
Operatorfailure is offline   Reply With Quote
Old 09-23-2013, 10:18 PM   #2
Blue Rat
Re: Quarter mile estimate?
14.50 1/4 mile.
Blue Rat is offline   Reply With Quote
Old 09-23-2013, 11:47 PM   #3
El Campo
El Campo's Avatar
13.99 is my guess
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-24-2013, 05:28 AM   #4
Operatorfailure
I've been telling myself I will be happy with a 14.99, which I don't think should be any problem but a 13.99 would be awesome, it would put me right next to my dad in his 66. Thanks guys, I will update this Friday with what I run.
Old 09-24-2013, 01:55 PM   #5
mongoose
mongoose's Avatar
15.70
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-24-2013, 06:22 PM   #6
regan wilson
regan wilson's Avatar
14.20 @ 92 mph. What does the winner get?
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 09-24-2013, 06:38 PM   #7
Operatorfailure
Hmmm.... I guess the knowledge that you're the best guesser, lol. Btw Regan, your story of your truck is very entertaining, keep up the good work!
Old 09-25-2013, 04:23 PM   #8
Hart_Rod
Hart_Rod's Avatar
14.5 @ 87 mph
Hart_Rod is offline   Reply With Quote
Old 09-25-2013, 11:16 PM   #9
C10-Rat
C10-Rat's Avatar
15.40's
1970 CHEVY SWB 454BBC TH350
C10-Rat is offline   Reply With Quote
Old 09-26-2013, 12:17 AM   #10
Super73
Super73's Avatar
It has a tune? What did it make on the dyno, might be easier for us to guess.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-26-2013, 05:26 AM   #11
Operatorfailure
I am tuning it myself with hptuners. There is talk of a dyno day here locally, if they do that I will find out what it puts to the ground but as of now I don't know.
Old 09-26-2013, 10:35 AM   #12
Custom 68
Custom 68's Avatar
I think Hartrod is close... I have ran that track with the same setup... A cam and some nitrous and you will be in the low 13s and over 100 at least I was. I have ran out there several different setups so I may have forgotten one and didnt keep very good logs.
I wont make it out this weekend because of the street machine nationals but lets hook up out there some time.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-26-2013, 12:03 PM   #13
Operatorfailure
14.5 I will be happy with for sure, I'm guessing a little slower. I will be at the street machine nationals for sure, and definitely want to check out your truck. I want to go turbo next summer so checking out your setup would help a ton.
Old 09-26-2013, 12:46 PM   #14
Super73
Super73's Avatar
Are you using a wideband for your AFR? If so, what is your current AFR?
Where do you have timing set right now?
Stock doesn't really care for more than 25ish degrees of timing. But make sure all your timing modifiers are adjusted as the stock tune has timing pulled for air temp, coolant temp, etc..
I would also suggest you log all your KR points. This might help you find a little more ET/mph at the track.
Burst KR
Torque management KR
Actual KR
I think a well dialed in stock 5.3 with stock verter could go low 14's hooked at 3,800lbs.
Old 09-26-2013, 01:07 PM   #15
Operatorfailure
Yes I am using my wideband, WOT is 12.8ish. Timing I am not sure about, somewhere in the 25-27 range, I would have to check. I know I am logging burst KR and I will check on the others. Thanks for the input!
Old 09-26-2013, 05:41 PM   #16
Operatorfailure
Burst KR
Actual KR
How do I go about logging these in hptuners? I can't seem to find TM KR, I have found Burst KR, and regular KR.
Old 09-26-2013, 08:17 PM   #17
Super73
Super73's Avatar
KR and Burst KR are under Engine>Retard
You will find both Ignition timing advance (total timing) and Torque management advance under Engine>Advance.
Old 09-26-2013, 08:49 PM   #18
Operatorfailure
Thanks!
Old 09-26-2013, 09:12 PM   #19
softballnrd27
Always a work in progress
softballnrd27's Avatar
85 SWB with 5.3, small cam, th350 and 2.xx gears ran 14.8 @97 on street tires. Gearing was killing me
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 09-28-2013, 08:58 AM   #20
Operatorfailure
I ran it first with a bone stock tune except the VE and MAF tables dialed in for my AFR. I ran a 16.3855 @ 80.20, then I put in the tune I had been working on and ran a 15.6782 @ 83.75. I think I found a leak in my intake manifold that I am going to try and seal up, and if that isn't it I will do a leak down test because there is no reason I shouldn't be at least low 15's IMO. I was spinning off the line, but not much at all. I did pick up .700 and 3.55 mph with the tuning so that at least made me feel a little better.
Oh, and I couldn't get it to run the timing I was commanding. It would bounce from 20-22 total advance with no KR, no matter what my timing cells were set at.
Here is a pic of the time slip, I am on the right.
Old 09-28-2013, 04:06 PM   #21
mongoose
mongoose's Avatar
.02 off.... so close!
Old 09-28-2013, 05:44 PM   #22
Operatorfailure
Yeah, Mongoose wins for sure, lol.
Old 09-29-2013, 07:35 PM   #23
Super73
Super73's Avatar
If you want to e-mail me your tune, I would be happy to try and help you find the issue with your timing.
Also, if you have any logs and your .cfg file as well.
Shaunliddy@hotmail.com
Old 09-29-2013, 07:40 PM   #24
Operatorfailure
Thanks, I'm on my phone so I cant email you the files but I will later. I'm pretty sure I found my timing issue, I was running 110-122 degrees IAT so it was pulling timing because of that.
Old 09-30-2013, 09:23 AM   #25
70shortwide
If you get that 60' down you will be in the 14's
70shortwide is offline   Reply With Quote
