Old 10-01-2013, 08:50 AM   #1
jus2qwk
jus2qwk's Avatar
JUS2QWK'S Official Build Thread
I've had a few threads for this truck but nothing to show the entire build, what’s happening now and what the plans are. So I'll start at the beginning I got the truck for my 13 birthday and was intended to be a my daily driver for school. To make a long story short my truck got skipped in line, in our shop with some other restorations so when I got my license not truck. I drove a junky Plymouth laser through most of high school. The truck took a little longer than expected but it was worth the wait. It turned out a lot nicer then I we expected. Now to the pictures!
The original truck. Basically nothing was used other than the frame and grille. Straight 6 with a 3 on the tree
For some reason I can’t seem to find the very first part of the build. So I’ll start with this, after most if the metal work had been completed. Cab corners, rockers, cab supports, and I small section of floor. The hood and fenders and aftermarket. The frame was sandblasted and painted.
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 10-01-2013, 08:58 AM   #2
jus2qwk
jus2qwk's Avatar
Re: JUS2QWK'S Official Build Thread
Trying to get an idea of how I wanted my flames to look.
The end caps for the bed rail I made.
Corey Jones Designs
Old 10-01-2013, 09:02 AM   #3
jus2qwk
jus2qwk's Avatar
Now on to paint
Corey Jones Designs
Old 10-01-2013, 09:27 AM   #4
jus2qwk
jus2qwk's Avatar
now the fun Part! The original engine was a thrown together with what we had 408 small block. stock crank, 350 5.7 rods, new cast pistons,cast heads, edelbrock torker 2 intake, decent sized cam and a Holley 750... all junk we had laying around for the most part. I think we had 1200 bucks in the complete engine. I'm thinking it had around 400hp and a ton of torque. the original trans was a muncie 4 speed with 373 12bolt rear.
Corey Jones Designs
Old 10-01-2013, 09:34 AM   #5
jus2qwk
jus2qwk's Avatar
Now the Interior
I got a seat from a late 70s early 80s c10 and had it recovered, new carpet, door panels,dash pad and dash bezel were installed. I also put in a speaker box behind the seat with a 10 inch sub and 6x9 speakers I also put in kick panels with speakers and a Sony head unit. all the speakers were also Sony. sound deadening material was put throughout the entire cab
Corey Jones Designs
Old 10-01-2013, 09:40 AM   #6
jus2qwk
jus2qwk's Avatar
Bed Final assembly
we sprayed in bed liner the painted the bed sides which turned out nice considering how bad of shape the bed was in.
The inside of the fenders were also covered in bed liner as well as the bed sides
Where we were on a budget we just went to lowed and bought some pine planks and stained them. Not Ideal but the money was starting to run low
Corey Jones Designs
Old 10-01-2013, 09:48 AM   #7
jus2qwk
jus2qwk's Avatar
The Finished Product
Nothing felt better than all that hard work finally finished and I got to take the first drive in the Fall of 2006. The truck turned out WAY better than I could of imagined and for a 18 year old senior in high school I definitely had the coolest ride in the parking lot
Corey Jones Designs
Old 10-01-2013, 10:12 AM   #8
c10Dream'n
c10Dream'n's Avatar
that's a sweet looking ride. Here's a pic of my 69' stepside i had in high school.
c10Dream'n is offline   Reply With Quote
Old 10-01-2013, 10:16 AM   #9
Low Elco
Slick! I think I'm on the update thread as well. Nice work!
Low Elco is offline   Reply With Quote
Old 10-01-2013, 11:00 AM   #10
jus2qwk
jus2qwk's Avatar
well for the next couple of years when I went to college close to home I still go to drive it some. I went to some cruise in's, parades, Dyno days, and basically just had a lot of fun with it.
Corey Jones Designs
Old 10-01-2013, 11:12 AM   #11
jus2qwk
jus2qwk's Avatar
I even did a little photo shoot with a guy from Virginia Tech
Corey Jones Designs
Old 10-01-2013, 11:24 AM   #12
jus2qwk
jus2qwk's Avatar
Fast forward to 2011. I just had graduated college got a grown man job and I finally had time to start enjoying the truck again. Until this happened. I was messing around with the timing and changing a few things and I think it leaned WAYYY out.
Corey Jones Designs
Old 10-01-2013, 11:35 AM   #13
jus2qwk
jus2qwk's Avatar
Now I have to build a motor which is fine. I was ready for a little more power. so this is what we did. another small block 400 high nickle block, eagle rods 6 inch rods, srp forged pistons, aluminum heads, tall air gap intake, bullet custom ground solid lift cam, MSD digital 6al box and a ProForm 750 carb. Machine work was done by Buck Racing Engines and a drag racer buddy who used to build engines put it together. this set us is supposed to be good for a little over 500 hp. I forgot to mention that I had put a Richmond 6 speed in it a few years back
Corey Jones Designs
Old 10-01-2013, 11:42 AM   #14
jus2qwk
jus2qwk's Avatar
sounds pretty healthy
Corey Jones Designs
Old 10-01-2013, 11:55 AM   #15
jus2qwk
jus2qwk's Avatar
Since I now had a engine that would rev to almost 7k I thought it would be good to have a tachometer. this is one mod Im quite proud of. New vintage 10k tach in the factory location
Before
After
Corey Jones Designs
Old 10-01-2013, 12:46 PM   #16
jus2qwk
jus2qwk's Avatar
So new engine in and life is good. More cruise in’s, shows, Drag strip, and even took it on the 3 hour trip to the rod run in rod run pigeon forge
Corey Jones Designs
Old 10-01-2013, 12:51 PM   #17
jus2qwk
jus2qwk's Avatar
Everything had been great with the new engine but then the one thing I didn't replace failed... and let me tell you it was like a bomb went off under my hood. The harmonic balancer decided it didn't want to in one piece anymore. This was during the fall of last year
Corey Jones Designs
Old 10-01-2013, 01:06 PM   #18
jus2qwk
jus2qwk's Avatar
Okay so now we are almost up to speed. Like I said the balancer broke in the fall of 2012 and I replaced everything on the engine that it destroyed and got it running again but at that point it made me sick to even look at the thing so I parked it in the corner and left it. until about mid way through the summer I decided to start piddling with it here and there and did a few thing but the more I looked the more stuff I noticed needed to be fixed so about 2 months ago I finally decided to buckle down and get it done.
I had a very nice truck before but if I'm going through all this work it would kill me the have the exact same thing as before. Not only that but I want to do some of the things that I didn't have the money or knowledge back then to do. So here are the most recent updates.
New hood
This was by far one of the worst fitting hoods I've seen but nothing the welder and hammer couldn't handle
The Bed came of for a little rust repair, body work, new wood, fleet side tubs and so I could put the c notch in.
Corey Jones Designs
Old 10-01-2013, 01:11 PM   #19
jus2qwk
jus2qwk's Avatar
lots of body work has been done and everything from the cab up is almost ready to paint but there was a lot to do, to get everything lined up where I was satisfied.
like cutting the fenders and rockers
Corey Jones Designs
Old 10-01-2013, 01:23 PM   #20
jus2qwk
jus2qwk's Avatar
Iva also done a lot of small things like adding a new cpp deluxe trac bar, shock relocation kit, new springs for the rear to drop it another 2 inches and cleaning the frame and repainting it. I also am cleaning up the engine bay a bit with with new plug wires routed under the headers, new valve covers and a lot of odds and ends.
new deluxe trac bar with the springs install and shock relocation kit installed
I also made new 3 inch tail pipes because I didn't really care for the way it sounded or looked with the 2.5 tail pipes
engine bay with new valve covers, air cleaner, breather, dip stick and plug wires rerouted
and this is how it sets at the moment
Corey Jones Designs
Old 10-01-2013, 01:40 PM   #21
jus2qwk
jus2qwk's Avatar
I currently don't have a fan shroud but I don't think I will need one with my new electric fan so I changed these up to make the look a little better.
I think they turned out nice and the new stainless hardware looks good too
Corey Jones Designs
Old 10-01-2013, 01:42 PM   #22
jus2qwk
jus2qwk's Avatar
Well all that took a while! haha but now everyone is up to date.
I want to take this truck to the next level so the plans are to
-paint it basically the same minus the flames
-new wheels maybe 18x8 up front and 20x12 out back
-narrow rear end or maybe jump to a ford 9inch
-black walnut bed
-fleet side wheel tubs
-recover seat/ maybe even change the entire interior
I’ll try to do my best to keep this thread updated
Corey Jones Designs
Old 10-01-2013, 10:53 PM   #23
67c10rustbuket
67c10rustbuket's Avatar
For a minute there I thought you had a truck twin Took a minute to realize I saw your truck in another thread where you blew it up. Great looking truck and I like that tach, it goes well with the stock gauges.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-02-2013, 12:22 AM   #24
jus2qwk
jus2qwk's Avatar
haha yea I kinda had stuff all over the place. I just wanted to get it all in one spot.
Thanks man. the install on the tach wasn't a bad at all and its cheaper than a factory replacement
Corey Jones Designs
Old 10-08-2013, 08:43 AM   #25
jus2qwk
jus2qwk's Avatar
I haven't had much time to mess with the truck as of late but I did get out in the shop and put my new fuel tank in that came from LMC trucks. I think its a 18 gallon top fill. I didnt want to use the straps so I came up with this.
not sure what the actual name of this kind of metel is but it worked well
welded studs to the frame. Im also gonna switch to a lock nut but didnt have any on hand
I think it looks pretty good setting in there
Corey Jones Designs
