Old 10-29-2013, 10:10 PM   #1
7d1truckguy
7d1truckguy's Avatar
Let's see some pics of 4-6 and 5-7 drops on 71-72 c 10
I want to get some idea's on if I want to go 4-6 or 5-7 on my 71 gmc with leaf springs on the rear I will probably keep these 15x8 ralley's until I can afford 20x8 and 20x10 torq thrust II
7d1truckguy is offline   Reply With Quote
Old 10-29-2013, 10:55 PM   #2
68bowtie
68bowtie's Avatar
Re: Let's see some pics of 4-6 and 5-7 drops on 71-72 c 10
here's a good thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=471442
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 10-29-2013, 11:03 PM   #3
leddzepp
Moderator
leddzepp's Avatar
5/7
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-29-2013, 11:06 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Other side
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-29-2013, 11:09 PM   #5
67ctener
67ctener's Avatar
This should give you a good idea, very similar to what your lookin for
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 10-29-2013, 11:49 PM   #6
shopking72
shopking72's Avatar
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline   Reply With Quote
Old 10-30-2013, 12:14 AM   #7
Rod Run
Rod Run's Avatar
Are these drops just done with springs, or is there more to it so that you can still get a proper alignment after the drop?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 10-30-2013, 12:25 AM   #8
leddzepp
Moderator
leddzepp's Avatar
2.5" dropped spindles in front (no change to geometry), combined with one cut coil on each original spring for another 2.5-3". Added one additional shim to each mounting point on the upper control arms. Aligned perfectly and drives straight down the road. 5" drop springs combined with 2" blocks in the rear.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-30-2013, 12:51 AM   #9
68bowtie
68bowtie's Avatar
i love the 5/7 look, especially with rally wheels and raised white letters. nice truck. you need frame mods for 7" right?
Old 10-30-2013, 07:36 AM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
4.5/6 ECE drop with NO c-notch installed.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-30-2013, 09:11 AM   #11
c10Dream'n
c10Dream'n's Avatar
Installed the ECE kit a few months back. Total drop of 4/7 to even out the stance. Added a 1" lowering block in the rear. C-notch to follow.
17" TTII's w/ 255/55/17 on all 4 corners
c10Dream'n is offline   Reply With Quote
Old 10-30-2013, 11:38 AM   #12
leddzepp
Moderator
leddzepp's Avatar
Thanks. Yes you need to c-notch for clearance. Even with CPP 5" springs I bottomed out all the time and it needed then. Opinions and numbers seem to be all over the place as to when it is "required". I recommend installing the springs and using your own judgement.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-30-2013, 12:28 PM   #13
NC_John
NC_John's Avatar
Looks wicked. How is your scrub line in the back with the 2" blocks and those wheels? I measured mine and best I could get before I starting hitting hard parts was 1.5" with blocks. 2" was really close.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 10-30-2013, 12:53 PM   #14
leddzepp
Moderator
leddzepp's Avatar
I wouldn't go any lower than this with 15" wheels...it's very close!
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-30-2013, 12:57 PM   #15
sKnNyPpY
sKnNyPpY's Avatar
71 GMC 1500 with 2.5 CPP Spindles, 1" CCP Spring, DJM Flip Kit 5" FK1012-5 for 2.25" leaf spring. Supposedly 3.5/5 more like a 4/6. 20x8 OldSkool with 275/45 Falken Ziex TZ04. The front has settled a little more since these pics after doing the ball joints and getting the springs seated properly.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 10-30-2013, 04:40 PM   #16
Roger71SWB
Roger71SWB's Avatar
Its not a 4-6 or 5-7 but here is a 6-8.
Roger71SWB is offline   Reply With Quote
Old 10-30-2013, 06:30 PM   #17
ksshane
ksshane's Avatar
Lowering mine this weekend. Ill post before and after pics when its done.
I know yellow isn't for everyone, but I really like that yellow.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 10-30-2013, 08:43 PM   #18
JointTech
JointTech's Avatar
nice truck shopking. i havent seen that one around the forum for some reason.
72blackbeauty, roger, c10dreamin can you guys fit 20's? your stances are perfect.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 11-04-2013, 12:49 PM   #19
rgreathouse
Shopking72 your truck looks great! What color is that gunmetal grey? Is it a chevy color?
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 11-04-2013, 01:46 PM   #20
c10Dream'n
c10Dream'n's Avatar
I haven't got to that point yet of seeing if 20's would fit, but I dont see any reason they wouldn't. only thing i would have to take into consideration is tire sizes for front and rear.
Old 11-04-2013, 01:48 PM   #21
c10Dream'n
c10Dream'n's Avatar
beautiful truck, interested on knowing what set up you got to get the 6-8. first time i've come across that set up. i was under the impression that anything after 5-7 needed to be bagged. thanks.
Old 11-04-2013, 01:53 PM   #22
C/10 King
C/10 King's Avatar
What the heck, one more 4.5/6 on Intro's Vista 20/22 combo.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 11-04-2013, 01:54 PM   #23
Roger71SWB
Roger71SWB's Avatar
I have 20x8 front and rear. Rear is 6" spring with 2" block
Old 11-04-2013, 02:41 PM   #24
sublime1996525
There are some sexy trucks here.
sublime1996525 is offline   Reply With Quote
Old 11-04-2013, 03:15 PM   #25
landsurvey1
landsurvey1's Avatar
Here is mine with Boss 338 wheels, 20 x 8 front and 20 x 10s rear.
1972 Chevy short bed ZZ4 350/355hp GMPP crate engine.
1972 Cheyenne K-20 454/400hp big block
1988 Jeep Wrangler
2010 Jeep Sport Unlimited
landsurvey1 is offline   Reply With Quote
