Old 12-09-2013, 09:28 PM   #1
Jahloha
Jahloha's Avatar
Pictures Of Frame Prep/Paint
Team:
I am reading a lot of our articles on products like Por 15, Rust Hammered, Eastwoods, etc., but I learn best through visual. That being said,
Does anyone know of a thread or have pictures of their own builds of right before and after paint? I am trying to see what "bare metal" means to everyone, or what a frame should look like prior to Por15/Eastwood application over rust.
I really appreciate your help. I just dont want to commit to a certain path, then figure out I didnt prep properly then have to blast and powder coat or something (both are out of my budget).
I plan on doing all prep with my hands and hopefully finding a product I can brush on.
Mahalo!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-09-2013, 09:41 PM   #2
808_67C10
808_67C10's Avatar
Re: Pictures Of Frame Prep/Paint
I have used both KBS Coat and POR15. Both layed down and smoothed nicely. You have to prep well though... Bare metal is bare metal. Any paint and it wont stick long. I did notice the POR15 turning purple with time though. I just rattle canned over it and called it a day. If I had it to do over again, KBS is the same thing, holds up just as well and is half the price of POR15.
My 2 cents for that its worth.
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 12-09-2013, 10:17 PM   #3
67ctener
67ctener's Avatar
You would be surprised what some places will sandblast for. I paid 150 for all components of my short box frame to be done. You'd spend weeks sanding to get a comparable prep job
67ctener is offline   Reply With Quote
Old 12-09-2013, 10:23 PM   #4
Jahloha
Jahloha's Avatar
Mahalo for the input. I have just started reading about KBS. Anything good enough for back home in the 808, would be just fine out here in dry Utah.
Originally Posted by 67ctener View Post
Consider sandblasting. I paid 150 for all components of my short box frame to be done. You'd spend weeks sanding to get a comparable prep job
I know man. I am very much torn. I do not have plans to remove the cab, but I am starting to get into that "might as well" stage because I have everything torn out already.
But seeing as this will be a DD, I also know I can do good prep and get a good paint afterwards as well. If that makes sense.
-JASON
Old 12-09-2013, 10:38 PM   #5
67ctener
67ctener's Avatar
Understandable, I've always had good luck degreasing, cut brush and maybe some 80 grit and paint. Rust tuff make a semi flat paint that IMO has a great and super strong finish.
Old 12-09-2013, 10:41 PM   #6
Jahloha
Jahloha's Avatar
What does cut brush mean? Like cutting in? I dont want to assume ha.
-JASON
Old 12-09-2013, 10:44 PM   #7
67ctener
67ctener's Avatar
May of been the wrong word but one of these wire cups
Old 12-09-2013, 10:45 PM   #8
guzzidude
guzzidude's Avatar
I use kbs's gas tank sealer on my Dnepr motorcycle. It worked great and much better than kreem. Very nice system.
76 Custom Deluxe LB
guzzidude is offline   Reply With Quote
Old 12-09-2013, 10:54 PM   #9
Jahloha
Jahloha's Avatar
Oh gotcha, yeah I bought one of those for the flat surfaces and a wheel for grooves. I am testing the system out tonight on a two foot section to see how the results look.
So you have used a wire wheel or cutter (whatever that picture is) to prep a frame? What paint did you use afterwards?
-JASON
Old 12-10-2013, 12:33 AM   #10
Jahloha
Jahloha's Avatar
SPent about 2 minutes on the frame with my wire wheel and drill, heres the product. Check out my build thread for my thoughts.
Name:  Wire Brush Product.jpg
-JASON
Old 12-10-2013, 08:58 AM   #11
DaHos
DaHos's Avatar
A little before and after.....Started with a clean AZ frame, power washed and de-greased with Home Depot "Super Purple", sprayed on a phosphate metal prep followed by a scuff with red scotch-brite pad. Paint used was SEM "Rust Shield" and was applied with brush in some tight areas followed by spray. Pending on how you thin/spray it it can be matte or gloss.
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 12-10-2013, 12:06 PM   #12
Jahloha
Jahloha's Avatar
Looks great! So you didnt use any primer?
-JASON
Old 12-10-2013, 02:38 PM   #13
DaHos
DaHos's Avatar
Thanks, No primer used.....per tech sheet.
I used 1 gal for a complete LWB frame.
http://www.semproducts.com/product-c...n/rust-shield/
1967 C10 SWB
Old 12-10-2013, 03:07 PM   #14
Sammy
Power washed and used Dawn, blasted, then POR 15. Rear was swapped out to 5 lug.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-10-2013, 04:35 PM   #15
KMC3420
KMC3420's Avatar
You might try using a paint stripping disc, they work like a wire wheel but a bit faster. They sale them at home depot, but a vendor has them on here as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=584223
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 12-10-2013, 04:46 PM   #16
808_67C10
808_67C10's Avatar
Agreed, the stripping disc is amazing! It took me a while to stumble apon one but I am sold. I used to wire wheel the $hit out of everything but the disc is much better on the end of a grinder!
sand blasting is suprisingly cheap too. If I did it again, I would have it blasted but, I did mine is seperate parts with the cab still on so, I used the disc.
Old 12-10-2013, 05:56 PM   #17
Jahloha
Jahloha's Avatar
You guys buy these from the vendor in the post? Also, looks like they only work on grinders (a tool I do not have, yet). Thats one thing about the wire wheels, I can use it in my drills.
-JASON
Old 12-10-2013, 06:34 PM   #18
88fordf150
88fordf150's Avatar
Sand blasted and sprayed with Summit Racing Frame Paint.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 12-10-2013, 06:53 PM   #19
KMC3420
KMC3420's Avatar
I have bought from him but have bought about 6 from Home Depot. $10 a pop. I used them to clean up before sandblasting. Made it go much faster. They have ones that fit in a drill as well.
Keagan
Old 12-10-2013, 07:00 PM   #20
Jahloha
Jahloha's Avatar
Bingo, thats what I was hoping for. But I am afraid of getting ahead of myself by priming in sub 50* weather. So dont want to take the front end to bare metal and then not be able to prime.
But these pads look to be a good option other then wire wheeling, although I believe I can get good results with it on my particular frame.
-JASON
Old 12-10-2013, 07:12 PM   #21
KMC3420
KMC3420's Avatar
Yessir. They work good. The thing about a wire wheel is they take paint and rush off but they polish the metal. So you need to scuff up the metal for your paint to stick very good. Depends on what paint you use. Some paints cover much better.
Keagan
Old 12-10-2013, 07:14 PM   #22
Jahloha
Jahloha's Avatar
Exactly. After doing that quick section, I was shocked at the polished frame afterwards. I do not feel comfortable using a rust encapsulator, I would rather start "new". I will swing by and try out this padded option.
I also assume if I use this pad, I will not have this bare metal I have from last nights work, that now needs to be primed to avoid rust. Is that correct?
-JASON
Old 12-10-2013, 07:22 PM   #23
KMC3420
KMC3420's Avatar
The paint stripping disc will take it down to bare metal as well. I have done some spots on my frame and it has been sitting for a couple of months now and no rust. It doesn't take it down to raw metal like sandblasting does. You can see a few examples of how it will look on the link above for the vendor that sales the disc he did a door. You will want to go ahead and prime or paint what you can. The advantage of the disc is it strips faster than a wire wheel and no flying wires.
Keagan
Old 12-10-2013, 07:31 PM   #24
KMC3420
KMC3420's Avatar
Forgot to mention that the parts that aren't rusting yet are sitting inside the shop. So if your parts are inside you have a little bit of time. But priming ASAP is best.
Keagan
Old 12-10-2013, 08:58 PM   #25
808_67C10
808_67C10's Avatar
The discs work great for smoothing out welding on sheet metal... just have to be careful not to buld up too much heat or it will get wavy... that isnt an issue on a frame.... Hot up lowes or home depot... or even harbor freight. You can pick up a grinder super cheap... the most dangerous tool I have but, it is also the fastest and most used to cut, grind and sand!
