Re: S10 Frame Swap w/ AD and LS motor
HI Tlorber, I'm starting my on build of a 1952 5 window with LS,,thanks and I'll be reading and watching you..Looking good so far
1952 Chevy truck 1955 chevy Belair 2 dr Hardtop 1955 Chevy Belair 2 dr post 1962 Red corvette 1962 Red impala 2 dr hardtop 1926 Star by Daurant |
Bauto, welcome aboard. I look forward to seeing your progress.
Borrowing liberally from Old Sarge, I got some progress done on my brake and steering column reinforcement plates. I got the brake plate plug welded to the firewall and got the steering one ready for mockup with the column. I had to do things slightly differently from his, since my GMC Dash is shaped a bit different. I will be using the original mounting holes and steering bracket to hold the steering column, but using the S10 brake bracket and holes to connect it to the dash. I will relocate the interior truss rods that go from the firewall the dash so that they connect to the same bolts that will hold the brake bracket. These plates would have been really difficult to make without a die grinder.
http://67-72chevytrucks.com/vboard/s...s10+frame+swap Last edited by tlorber; 11-17-2014 at 02:14 PM. |
nice work, HF actually has a decent hole saw set. but.....their burr/rasp bits are terrible
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
Well, I didn't get a whole lot done on the truck last week because of this...
We then got back to Los Angeles to rain. However, over the weekend I was able to weld the baseplate onto my steering column, thanks once again to Old Sarge's thread. I am also working on how to pickup around 4" on each side of the inner fenders. I have cut the inner fender here, and I hope that with some hammer and dolly work, and then subsequent filler pieces I can preserve as much of the inner fender as possible.
http://67-72chevytrucks.com/vboard/s...s10+frame+swap |
I got some work done on one of the inner fenders over the weekend-you can see the weld scar on the left side. It still has more to be done on it, but the contour came out exactly as I wanted (so far). This should give me adequate room on the passenger's side. Before I started, the inner fender was touching the header. I plan on doing the same on the driver's side.
I probably have 8 hours into just the one side at this point. I am going to wait on the remaining hole up front until I know how the AC compressor will fit in. That is way down the road.
nice job. crazy how much time gets eaten up but little things that most people don't notice.
#7 | |
But we are all doing this for the love of the journey, no?
Looks very nice!
Ok so, I've gotten a few things done in the past month. I smoothed out my inner fenders after recontouring , though I still need some filler pieces once I figure out where the AC compressor will sit.
I also got my cab dolly finished. I was shocked that the holes actually lined right up with the cab's. I still want to weld on some outriggers so that I can tip it either forward or sideways to work on the different sides. Then I started working on the bed floor. The fender tubs will be cut off and I will need to find some material to fill the resulting spaces. The bed will be shortened by about 5-6" in order to fit.
yah know, its funny how people get so pumped on other peoples cab dollies. I must say yours is beast mode. Keep it going.
Yeah, the only reason it is that beefy is that I got a cart from a client who sold his business (wood shutter manufacturer) and he gave me the cart. I had to do some cutting and welding, but it works. Definitely overkill for this application.
I will be watching your progress Im still debating on the LS1 swap.
I got a couple things done on the bed this weekend. I cut and sectioned the bed bottom (using the original S10 metal), and I welded the new front bed supports to the frame by using 2"x2" metal tubing. I still need to do some grinding and smoothing to the bed bottom, and then cut the width down to around 49" wide.
Finished length on the bed will be 82 1/2" long. This will require me taking about 7 1/2" out of my bedsides and running boards (originally a 3/4 ton longbed).
#14 | |
#15 |
Mine will not really be a shortbed when it is finished since the S10 started out as a standard cab long bed. You may have started with a standard bed. What was your finished bed length?
#16 |
The regular cab longbox S-10 is almost the same wheelbase as the regular cab shortbox early truck. That's what I used, and it's the 4th swap we've done that way. The first of which was a regular cab shortbox AD. My finished bed length was the same as a shortbox (within a half inch or so, I believe). I'm assuming you're just placing your wheels differently in the wheel wells.
#17 |
I haven't yet determined whether I need to reposition the fenders relative the the wheels. The measurements I've taken from the centerline of the wheels to the rear of the bed are within 1/2" of eachother for the S10 and the '54 bedsides. I will be sectioning the bedsides in front of the wheels, and I'm hoping I don't need to lengthen or shorten the bedsides behind the fenders in order for them to be centered.
#18 | |
#19 |
I put the '54 cab onto the S10 frame. I left about 5/8" behind the cab for the gap, which is where my S10 bed bottom now ends (i.e. where the new bed front will be located). This determined how much of the S10 bed would be sectioned out (roughly 5 1/2") leaving me 82 1/2" total bed length". Now I just have to section my bed sides to match what I have sitting on the truck, assuming the fenders line up as I stated above.
So in other words, the S10 bed bottom essentially stays where it originally was (i.e. cross members bolt to the chassis as they used to, except for the front one which is now relocated). With the rear of my bedsides aligned with the S10 rear cross sill, the fenders APPEAR to be properly centered, but I will need to bolt them back onto the bedside and mock them up to verify. I hope that all makes sense.
#20 | |
You might want to check out the following two documents. Page 4 of this one: S-10 Vehicle Information Pack Page 60 of this one: 1954 Restoration Pack I hope the measurements of both bed length and the distance from the center of the wheels to the back of the bed help make this more clear. You're trying to match the floor of a bed that's 80" long with 45.6" behind the wheel centers with the sides of a bed that need to end up somewhere near 78" long with 42" behind the wheel centers. All of these swaps that I've seen need to have the rear of the framerails bobbed, and it seems like you haven't done that. As a result I think things aren't going to line up correctly for you. What we did was figure out where we wanted the wheel center in the fender, then find the measurement from there to where the front of the bed needs to be. Once you know that, the difference between that and your original bed measurement is how much you need to shorten it, then you'll also be able to figure out how much you need to bob the framerails and in your case the rear of the bed floor. |
#21 |
Snopro,
The pic below shows how the bedside aligns with the wheel when the rear is aligned with the rear cross sill. The middle stake pocket is just off of the centerline of the wheel. The S10 bed has 43.5" between the wheel centerline and the rear cross sill, while the '54 bedside has 43". Hopefully this does not put the wheel too far in the front of the fender. If so, my worst case would be to cut and lengthen the bedsides behind the rear fender, and shift everything from that point toward the front. Not a huge deal since I'll have the material from when I shorten the front of the bedsides, but still something I'd rather not have to do-there are plenty of other projects that are consuming my time.
#22 |
It's alsways something.....
![]() Join Date: Nov 2008
I really like the idea of using the S10 floor. I plan to haul whatever I want in mine (i.e. greasy truck parts) so I want to steer clear of the beautiful wood furniture boards in my AD.
Im looking forward to how your's pans out. Thanks for posting the pics and info.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#23 |
I got one bedside on just to mockup its location-I still need to cut about 8" off the front of it and then splice, but the rear wheel looks to be in a pretty good location. Once I get the bed into final position and get some weight back on the truck, I'm figuring the suspension will drop another 1.5"-2".
Chuck, I wanted the metal bed for the same reasons as you. I actually got the Idea from BlueJeep, who has a more detailed writeup on the process. He has a couple postings on this thread, so you can find his build thread if you want. Mine won't be exactly the way he did it, but I think all of these are different and require some adaptation.
#24 | |
Looks good! |
#25 |
I got some time to work on the truck last night. I filled about 60% of the firewall holes (what a PITA, and still plenty more to do), got the fuel pipe filler panel in, and I was able to cut a section of my bedside out. The cut came out real clean-I just have to weld it together and get then get the other side done.
