Old 12-23-2013, 06:55 PM   #1
rgonza
1970 c10 LSX 427 twin turbo setup
Here's my 1970 C10 Twin Turbo Setup.
rgonza is offline   Reply With Quote
Old 12-23-2013, 07:08 PM   #2
rgonza
Re: 1970 c10 LSX 427 twin turbo setup
More pics
Old 12-23-2013, 07:32 PM   #3
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Beautiful setup with a great package. Welcome to the site.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-23-2013, 08:15 PM   #4
71chevystep4x4
71chevystep4x4's Avatar
doesn't get much cooler than that!!
71chevystep4x4 is offline   Reply With Quote
Old 12-23-2013, 08:30 PM   #5
tinydb84
tinydb84's Avatar
Dyno??
David
Instagram: myfabguy
Old 12-23-2013, 09:03 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Very cool, and way different than all the custom sandrails and audio competition cars I see come out of Puerto.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-24-2013, 02:16 PM   #7
rgonza
Originally Posted by tinydb84 View Post
Dyno??
1378 rwhp @6890 Rpm 19 pound of boost
Old 12-26-2013, 02:48 PM   #8
69trk
69trk's Avatar
where did you get the ac bracket? I'm doing a turbo build also... love the truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-26-2013, 02:50 PM   #9
69trk
69trk's Avatar
Are you using truck exhaust manifolds?
1.58- 60'
11.37- 1/4 @115.81
Old 12-26-2013, 05:21 PM   #10
rgonza
Hi, The bracket come from lsbracket.com this is a high mount bracket kit. the alternator and power steering come from 2002 chevy silverado 5.3Lt.
Old 12-26-2013, 05:24 PM   #11
rgonza
Hi, Not is a custom made, the truck manifold work good , but because of my setup need ones can flow more highter, so it are very easy to do we build that from black steel elbows and reducer from a boiler supplier.
Old 12-26-2013, 05:35 PM   #12
rgonza
Here's the pics
Old 12-26-2013, 05:44 PM   #13
rgonza
Installing the center console.
Old 12-26-2013, 05:51 PM   #14
69trk
69trk's Avatar
That is awsome..... I just ordered the ac bracket.... thanks
Are you using the holley dominator efi or the hp? Or a different ecm?
1.58- 60'
11.37- 1/4 @115.81
Old 12-26-2013, 05:58 PM   #15
rgonza
i'm using Holley Dominator EFI Because i'm using to control the 4L85e Transmission ,the paddle shifter and drive by wire throtle body, with the holley HP you can not is just to control fuel and timing the engine not the transmission unless you use manual or not computer controlled transmission.
Old 12-26-2013, 06:41 PM   #16
mud.man.rj
mud.man.rj's Avatar
1,378 hp, man that is nice. Would like a ride in that.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 12-26-2013, 09:32 PM   #17
69trk
69trk's Avatar
I went with the holley hp. Only reason i have a turbo 400 trans. I was going to build a 4l80e to handle 1000hp plus, but could'nt bring myself to pay that kind of money for the trans and converter... After i get her dialed in and everything else is done on my truck, i'll probably by the gears vendor od...
Was it pretty easy tuning the dominator? What size injectors are you using?
1.58- 60'
11.37- 1/4 @115.81
Old 12-26-2013, 10:47 PM   #18
rgonza
Yes , Very easy is like hp practically is plug and play just plug in the 4L80e configure the software and that's, i'm using 1200cc injectors with 8 660cc under the manifold but i'm not using them yet, i'm using a gear vendor behind 4L85e and it work great! is like 8 speed transmission and got very nice MPG on high way, consider to use an 3 disk lockup converter if you going turbo, i got an John Winter 10" 3400 stall Converter and like an stock one with lock up acitve.
Cheers
Rob
Old 12-27-2013, 12:57 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm not used to seeing the GV units behind the already-overdrive trannies, do you really get much use out of some of those doubled gears? (without being able to ECM/TCM control the gv unit)
Old 12-27-2013, 05:14 PM   #20
rgonza
In my case it works very nice on highway and the overdrive + Gv Overdrive + LU cause to drop around 1000 rpm on normal or cruise driving not race, when i switch to manual mode i will able to control the gear vendor through from mastershift paddler shifter control system.
Old 12-27-2013, 05:51 PM   #21
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very cool build and nicely done! I really like the aluminum piping and is that the intercooler on the LH fender well area?
Ryan
1969 Chevy milk truck
Old 12-27-2013, 06:11 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Damn, after looking at your build (and watching like 2 hours of Travel Channel), makes me want to go to Puerto Rico lol.
Have you used the Mastershift unit before? I read about it and another similar system, but I've never seen it used, since most of the guys with 6spd auto's will run the GM TuTd shifters. Does it allow for "full" control, or just the GV? (getting tap-shift for all 8 speeds would be epic)
Old 12-27-2013, 07:33 PM   #23
rgonza
i Have an Transgo HD2 modified valve bodies so when it put in D4 and switch to auto mode the tranny shift like factories does 4 + manual activation GV Overdrive , But when i ****ch to manual mode i have totally control over the tranny and GEAR VENDOR so there's when the master shift come on, the mastershift you can program it to gear splitting with the GV you will have 8 forward shift from your paddle shifter.
i have an another Modification in this tranny to handle the power from LSX 427 turbo.
1-Hardened Input Shaft
1-Hardened Hub.
1-TCI 2.97 First Gear Set
1-Intermediate Hardened Shaft
1-Alumum Direct clutch Assy.
1-Pump modification
1-34 elements Sprags
1-John Winter 3400 Stall 3 Clutch Lock Up Converter
1-red Alto Frictions
1-kolene friction plates
with this mods the tranny hold over 1400++ with out any issues
Old 12-27-2013, 07:45 PM   #24
rgonza
There's an video clip from mastershift with 4l80e and gear vendor.http://www.youtube.com/watch?v=jeOsodOvabU#t=16
Cheers
Rob
Old 01-02-2014, 06:33 AM   #25
69trk
69trk's Avatar
Looks like you kept the coil packs on the valve covers... Did you just custom make some plug wires andgo around the manifolds?
1.58- 60'
11.37- 1/4 @115.81
