Old 01-04-2014, 04:29 PM   #1
rob32472
Re: Project remove my sunroof
You could always weld the seem solid across the back..... IMHO it looks better that way.
rob32472 is offline   Reply With Quote
Old 01-04-2014, 04:33 PM   #2
westong
Originally Posted by 69SWB4X4 View Post
I am about to do the same repair on my truck. My thought was to flange the sunroof opening and cut a patch from my donor skin. Could also flange the patch if room is an issue.. On the inside I plan to use dyna mat in the old sunroof hole and add a headliner.. Thoughts??
I did that kind of repair on a 1966 chevelle that someone put a sunroof in. It worked great i drove the crap out of it and never had any problems. The car has been gone for a few years but i would like to think it held up well. Just take lots of time welding it in as u dont want to warp the thin sheetmetal.
westong is offline   Reply With Quote
Old 02-03-2014, 10:38 PM   #3
Razor454
Razor454's Avatar
Quick update: Stripped and sanded the paint off the donor top and fitted it in place. Will epoxy paint the inside once it warms up.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline   Reply With Quote
Old 02-03-2014, 10:56 PM   #4
Elliot949
Elliot949's Avatar
Very Nice...
Elliot949 is offline   Reply With Quote
Old 02-03-2014, 11:22 PM   #5
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Very nice, you make it look easy.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 02-04-2014, 08:47 PM   #6
Razor454
Razor454's Avatar
Thanks guys
Old 02-04-2014, 08:56 PM   #7
Lou Boffa
Lou Boffa's Avatar
mad skills!
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 02-04-2014, 09:07 PM   #8
chrisestes
Thumbs up Re: Project remove my sunroof
nice job on the roof!!!
chrisestes is offline   Reply With Quote
Old 05-13-2014, 01:53 PM   #9
Razor454
Razor454's Avatar
Ok, so I finally got some time to finish the roof. I stripped and primed the inside of the roof, then installed the original insulation inside before buttoning it up. I ended up welding the front lip of the roof and using 3M panel adhesive on the back edge. I clamped it all together and let it sit over night. The results turned out great.
Old 05-13-2014, 02:28 PM   #10
cericd
cericd's Avatar
Congrats! Looks way better without the sunroof hole.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 05-13-2014, 03:59 PM   #11
swamp rat
swamp rat's Avatar
Great work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-13-2014, 10:38 PM   #12
Razor454
Razor454's Avatar
Thanks, I only have to smooth out a small dimple in the rear of the panel. Which I should have done by this weekend.
Old 05-13-2014, 11:29 PM   #13
CUSTOM/10
CUSTOM/10's Avatar
Awesome job !!! I also don't like sunroofs in theses trucks ! Great workmanship !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 05-14-2014, 04:54 AM   #14
leftybass209
leftybass209's Avatar
Wink Re: Project remove my sunroof
That's some good work! Congrats, so when's the new sunroof going in?
leftybass209 is offline   Reply With Quote
Old 05-14-2014, 09:39 AM   #15
Mr Chevorlet
Rusty Nuts
That was a nice job well done!
Larry
Mr Chevrolet
