08-12-2018, 08:45 PM | #1 |
Re: What did you do to your truck today? Chapter II
Thanks. I love the sound of the exhaust so much, it's like music to my ears.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
08-12-2018, 07:49 PM | #2 |
Washed the frame and undercarriage.
Zane's 71 Build |
08-12-2018, 11:31 PM | #3 |
Getting started on some new parts. My first project truck. Sat for 20+ years. I can tell there are a few "new" parts that aren't OEM, but I think these plugs and wires are original 72. Whatcha think?
08-13-2018, 01:06 AM | #4 | |
No worries about the broken insulator, time to get upset when the bottom threaded part remains in the cylinder head..... .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-13-2018, 06:17 AM | #5 |
Installed ece front sway bar and drove it.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
08-13-2018, 03:07 PM | #6 |
Flared a short section of stainless brake line. Failed to flare of section of brake line. I was trying to shorten a pair of stainless lines on my rear end to work with my disc brakes. The line and/or tool did not like the small 3/16" line... 1/4" line was perfect.
08-18-2018, 06:14 PM | #7 |
Replaced the heater hoses...while I was taking the wire clamp off the 5/8 inch hose, it popped out of my pliers, sailed into the driver’s side engine bay, rattled around and disappeared (that’s my conclusion after spending 30 minutes looking for it - which included taking the driver side front wheel off)
Used hose clamps to secure the hoses on the heater core, then spent 20 minutes trying to get the metal thingie that holds the hoses together, failed, and just used a cable tie. I hope that clamp didn’t end up somewhere that will cause me problems later....
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
08-18-2018, 08:05 PM | #8 |
This was yesterday... but I welded up some of the spot weld holes, and cut some of the firewall out.. had help with cleaning!!
08-18-2018, 09:48 PM | #9 |
Finished my rear end rebuild, and installed brake adjusting holes in my rear drum backing plates.
1968 SWB Step Side, Big Block, 4L80E , Running! |
08-18-2018, 10:20 PM | #10 | |
Who Changed This?
I spent so many hours at about that age scrubbing parts that you wouldn't believe it. We couldn't afford chemicals, so it was "just wear out the screwdriver or brush"!
08-18-2018, 11:06 PM | #11 |
It wasn’t under the tire - I looked about 3 times.
08-18-2018, 10:40 PM | #12 |
Today I finished the install of an auxiliary fuel tank. It's a 31 gallon unit which gets me about 50 gallons total as I have elected to keep the tank behind the seat. Looking forward to fewer (but more expensive) stops at the gas station which can be a real inconvenience with a travel trailer in tow.
08-18-2018, 11:28 PM | #13 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-18-2018, 11:45 PM | #14 | |
Who Changed This?
08-19-2018, 02:01 AM | #15 |
Guys, the tank is applicable to the Blazer. The exact model years escapes me but later 70's to later 80's I believe. It has a taper on the trailing bottom corner, assume to help with driveway approaches but the problem for me was that it then put the fill pipe aimed to the passenger side. So... I cut it off and brazed up the hole. On the driver side of the tank on the top corner there is a circular depression, that's where I put my fill tube. I used a mopar style grommet, which allows a little play/flex of the fill pipe if needed. I actually had an old Chrysler gas tank from which I cut the section that receives the grommet, and then brazed it onto the Blazer tank. This is what the stock 31 looks like:
08-19-2018, 02:06 AM | #16 |
Here are a couple pics of my tank after the previously noted modifications were made. The top of the tank is a little ugly, I got a few bucks off on it as it had a few dents and the heat from brazing didn't help any either, but I don't plan to see the top of that tank again for a long time.
08-19-2018, 02:11 AM | #17 |
Under the truck, I made a couple spacers to provide something to pull the tank up against, and also provide a little bit of gap/space for the vent line, fuel line etc. Two frame cross members were moved, never took a picture of their original location but they were riveted to the frame. I moved them outward to a point at the edges of the tank to provide a place to mount the tank straps.
08-19-2018, 08:24 AM | #18 |
Completed Lizard Skin, I used both the sound and heat control.
08-22-2018, 11:57 PM | #19 |
Started removing the purple window tint. Razor blade scraped the tint film off. Lacquer thinner and a towel took care of the glue residue. I was pleased to discover the windows have factory tint and all the glass looks to be OEM.
08-23-2018, 01:34 AM | #20 |
How did I get this OLD!
Installed the 327 in the truck this evening. Everything on the bottom installed and hooked up. Hoping to bring it to life tomorrow evening.
http://67-72chevytrucks.com/vboard/a...1&d=1535002197
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
09-03-2018, 06:33 PM | #21 |
Good day today. Installed copper wire to get my oil pressure guage working. Replaced the master cylinder. Installed overflow bottle and new grille.
09-03-2018, 08:31 PM | #22 |
Scored a stock 2004R 2-3 servo assembly for my trans from Pick a Part to downgrade the super servo that the local trans builder put in and then keep putting me off to fix my issues. I guess he thought i was wanting a 1/4 mile truck as the shifts up were very harsh and the 3-2 downshift was absolutely horrible. The sound of the clunk made it sound like I was going to drop the rear end everything I slowed to a stop.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-03-2018, 09:13 PM | #23 |
Finally got the replacement parts installed from the near accident on Mothers day this year. My u-bolt on the lower control arm snapped when I was turning off a two lane highway and sent me,my wife and my camper into oncoming traffic. Got it stopped and no one was hurt. Truck got a bent upper control arm and inner tie rod.Got the truck home and it has sat till now.Pictures are of the right side but I had already done the left.
68' with no bells or whistles unless I add'em. |
08-23-2018, 01:42 AM | #24 |
Bent and installed brake lines from the new master. First time doing it, but I think it turned out pretty good.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
08-24-2018, 12:36 AM | #25 |
Engine started right up! So glad I decided to upgrade to power steering. No leaks. Engine runs smooth.
http://67-72chevytrucks.com/vboard/a...1&d=1535085363
