Old 01-20-2014, 02:47 AM   #1
tll74
"Junkyard Dog"
tll74's Avatar
Parting out 72 GMC K20 4x4 350-TH350
I just finished parting this one out. A 72 GMC 3/4t 4x4. Most all metal parts have been hot tanked and acid dipped. Media blasting available at no cost on most parts. All prices are plus shipping. Thanks, Tom
NP205-TH350 transfer case. 200.00
Transfer case adapter w/coupler. 125.00
TH350 trans been rebuilt at some time. Nice fuild and clean pan. 250.00
Pic 1
Rear crossmember 40.00
intermediate cross member 45.00
front cross member 25.00
Transmission-transfer case cross member 65.00
cab frame mounts (2 fronts, 2 rears) 20.00 each
front spring/core support mounts 35.00 each LH one is ruff have a good one.
front spring rear shackle mounts 25.00 each
front bump stops w/brackets 10.00 each
front shock brackets 5.00 each
front LH spring stop 10.00
forward rear spring hangers 30.00 each
rear/rear spring hangers 25.00 each (only one in pic)
Front u-bolts with plates 30.00 per side
rear u-bolts w/plates 25.00 each Pic 3
rear bump stops w/brackets 12.50 each
box supports 6 of them 10.00 each
rear shock mounts 15.00 each
rear e-brake cable brackets 5.00 each
front exhaust hanger bracket 10.00
rear hyd brake line bracket 10.00
P/S steering conversion complete 125.00
steering intermediate shaft 25.00
steering rag joint 22.50 nice
fan shroud, minor fan rub on top. can not see when installed 85.00 very nice
original flex fan 10.00
AT pedal hanger and pedal 25.00
e-brake cables, support links, bracket, coulpers and spring. 45.00
transfer case support kit 45.00
trans-tcase rubber mount kit original 27.50
speedo cable minor blem in platisc 20.00 looks very nice
L71-72 RH axle (large u-joint) 75.00 nice
L71-72 LH axle (large u-joint) 75.00 nice
draglink tight ends 25.00
heat riser nice springs works perfect original 25.00
crank pulley 12.50
water pump pulley 2 groove 15.00
Pic 2
oil line 8.00
tail gate hardware on box 25.00
tail gate hardware in gate complete w/bolts 45.00
GMC letters good chrome needs black repainted 15.00
GMC park lamp wiring 10.00 each nice condition
heat stove pipe 12.50
washer hose set 12.50
tail lamp lens 10.00 nice condition
fender-core support triangles 5.00 each
door stricker plates 8.00 each
Pic 3
door panel seal 5.00
door latch rods 3.00 each
amber marker lenses 10.00 each nice color
red marker lens 10.00 nice color
GMC turn lens/housing 12.00 some fade
vent pull rods w/knobs 5.00 each
dome light switch wiring 10.00
fuel tank wiring 8.00
dome light wiring 10.00
inside door handle 5.00
window crank handles 6.50 each tight knobs
tail lamp housings 10.00 each
back up housings 7.50 each
LH outside door handle very nice driver quality 25.00
RH outside door handle chrome peeling 8.00
oil filter adapter 8.00
dip stick sleeve 5.00
heater controls needs center lever I will replace it 45.00
window weather strip channels 10.00 each
Misc pics
C/K20 71-72 power brake conversion 65.00
base black door panels very nice outside one has broken spot for one retainer the other has two melted spots from me heating the nuts to get armrest off. It would still work just fine. 60.00
steering colum black 60.00
4x4 AT tunnel cover 40.00
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 01-20-2014, 03:01 AM   #2
tll74
"Junkyard Dog"
tll74's Avatar
Re: Parting out 72 GMC K20 4x4 350-TH350
more pics
Old 01-20-2014, 05:12 AM   #3
gmclonghorn
gmclonghorn's Avatar
I will take the flex fan . Pm thanks. zip code 92683
gmclonghorn is offline   Reply With Quote
Old 01-20-2014, 06:05 AM   #4
gmc 2500 4x4
is this the one with the hubs i asked about? if so, in line
gmc 2500 4x4 is offline   Reply With Quote
Old 01-20-2014, 08:09 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
Interested in the high hump A/T tunnel !
Do you have the top radiator metel pipe ?
Drivers side door latch control ? The piece in the door the handle goes on .
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-20-2014, 09:18 AM   #6
dec010974
dec010974's Avatar
Hello. I'm looking for a set of rear bumper brackets.donyou have a set? Shipping is to Miami, Florida 33176.
dec010974 is offline   Reply With Quote
Old 01-20-2014, 09:55 AM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tom I'll take the front exhaust hanger bracket and speedo cable. Is the rear hanger there? Thanks, Pete
Old 01-20-2014, 11:28 AM   #8
mx289
mx289's Avatar
Interested in gmc fender eyebrow trim pieces,t-case support (just need rubbers+bolts ?),and speedo cable if pete passes.shipping would be to 07719.
Thanks,Tom
mx289 is offline   Reply With Quote
Old 01-20-2014, 11:32 AM   #9
20HDriver
I'm interested in the top metal radiator pipe if you have one.
20HDriver is offline   Reply With Quote
Old 01-20-2014, 01:54 PM   #10
blackbolt
blackbolt's Avatar
intrested in the trans crossmember, pm shipping to 77505 thanks JJ
blackbolt is offline   Reply With Quote
Old 01-20-2014, 03:20 PM   #11
72swbcamo
Active Member
How much for the rear cab mount boltts?
72swbcamo is offline   Reply With Quote
Old 01-20-2014, 03:26 PM   #12
karphan
karphan's Avatar
I'll take the steering rag joint. Shipped to Sparks, NV 89441. PM sent. Thanks, Dan
karphan is offline   Reply With Quote
Old 01-20-2014, 04:10 PM   #13
72longbed
72longbed's Avatar
Question Re: Parting out 72 GMC K20 4x4 350-TH350
Do you still have the center tie rod that connected left knuckle and right knuckle? About 56" long with a tiee rod on each end.
Thanks,
72
72longbed is offline   Reply With Quote
Old 01-20-2014, 05:24 PM   #14
allons
In pic#3, I'll take the 2 window weather strip channels @ $10 each. PM me so I can pay and get shipping to 43357. Thanks, Jim
allons is offline   Reply With Quote
Old 01-20-2014, 05:25 PM   #15
allons
Also, would you have the 2 channels that the window glass in resting in? I need those also. Thanks, Jim
Old 01-20-2014, 05:31 PM   #16
tll74
"Junkyard Dog"
tll74's Avatar
Hang tight guys I'm at work till 5:00 and I'll catch up then. Thanks, Tom
Old 01-20-2014, 08:07 PM   #17
cst204x4
I will take e-brake cables,supports, etc for 45.00 also e-brake rear brackets and rear hyd brake line bracket let me know a total shipped to 48817 thanks Mike also would you consider seperating the bump stops from the brackets?
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 01-20-2014, 09:01 PM   #18
freakshow108
freakshow108's Avatar
What would be the cost of the fan shroud shipped to 98328? Thanks
freakshow108 is offline   Reply With Quote
Old 01-20-2014, 09:43 PM   #19
sboris
sboris's Avatar
Second on the center ebrake cables. In line for top radiator pipe..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 01-20-2014, 10:12 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Just to clarify, being a GMC the e-brake cable is probably for a Dana 60 rear not an Eaton HO 52?
Old 01-20-2014, 10:15 PM   #21
tll74
"Junkyard Dog"
tll74's Avatar
Shipping is via UPS and is actual cost. I have a daily pick up so that's what works for me. USPS on small items in flat rate boxes and or padded envelopes.
gmclonghorn, pm coming
gmc 2500 4x4 Paul, No..that's the 72 Sub K20. I will have it this Friday. Don't worry your in first place on them.
CUSTOM/10 Gary, nothing on the upper rad pipe. I Should have the relay 10.00 for a good one.
dec010974, Nothing right now on the sport rear bumper brackets.
DeadheadNM Pete, I can't recall. Let me look on the frame chunks. I'll start a pile for you.
mx289,The RH is a nice driver with a screw hole at the very bottom tip, 20.00. The LH is rusty towards the top 5.00. I plan to keep the t-case support complete. 16.07 shipping if you want all of it. Some PMed me for a pair of these and I cleared out PM's and lost who it was. For who ever that was my apology.
20HDriver, Sorry nothing right now.
blackbolt, JJ Shipping is 32.70 it weighs 28lbs
72swbcamo, 11.00 shipped
karphan, Dan, 6.00 shipping
72longbed, Yes 85.00 plus shipping
allons, Shipping for all of it 19.94 and 20.00 for the channels that attach to the glass.
cst204x4,Shipping 24.61
freakshow108, Shipping is 27.40 With packing it is 32x22x11 which is oversize.
Old 01-20-2014, 10:17 PM   #22
allons
Thanks for getting back to me, but I'm gonna pass on the package.
Old 01-20-2014, 10:20 PM   #23
tll74
"Junkyard Dog"
tll74's Avatar
Pete, yes it was a D60. Would it matter? Wouldn't this portion be the same? I have a couple HO72 4x4's that I could compare it. Thanks, Tom
Old 01-20-2014, 10:22 PM   #24
jimer1964
jimer1964's Avatar
hi,intermediate cross member. large one in front of leaf spring hangers also power steering set up as well, but may be to much to ship! pa 19320 thanks
jimer1964 is offline   Reply With Quote
Old 01-20-2014, 10:33 PM   #25
CUSTOM/10
CUSTOM/10's Avatar
What about the 4x4 AT tunnel cover, what kind of shape is it in ? Any rust, or extra holes ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
