Old 03-02-2014, 10:13 PM   #1
Andy4639
Old member
Andy4639's Avatar
Talking First trip
Took the truck on a 254 mile round trip today up to NC to see my parents. Truck ran great! I ran 100MPH a couple of times to see how it would do and it did fine. The water temp stayed right around 190 the whole way. I ran 75-80 most of the time. Filled up before I left and used a little over a 1/4 tank.
This is all the gas it used. heck if I would run 55MPH it wouldn't have used this much!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-02-2014, 10:47 PM   #2
whitels1
whitels1's Avatar
Re: First trip
Bad ass man!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 03-03-2014, 02:01 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: First trip
You didn't blow it up! Hehe. Glad its working out man!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-03-2014, 07:03 AM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: First trip
Truck ran great. Nope didn't blow it up! March 20 it will head to Myrtle Beach SC for the big car show. That's a 5hr drive each way.
Got appointment Thursday for the transmission. Taking it to the local guy to do a fluid change and check the thing out for the temp reading.
Old 03-03-2014, 10:35 AM   #5
Houston Ben
Houston Ben's Avatar
Re: First trip
That's awesome Andy, what size gas tank you using? I am using the 87 style tank and I don't think mine is reading right. I figured each line in the gauge cluster is 2 gallons but it seam to drop faster than it should and then when I fill up it takes less than I thought it would meaning there is more gas in the tank than I figured.
Houston Ben is offline   Reply With Quote
Old 03-03-2014, 12:03 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: First trip
I have a 1993 Subarban gas tank in it. 42 gallon out of a TBI motor sub. I've had the tank now for several years. Works great.
Old 03-03-2014, 01:18 PM   #7
Houston Ben
Re: First trip
Nice, do you have a picture of it? Was it easy to install? I hate having the small gas tank!
Old 03-03-2014, 01:35 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: First trip
Nope no pictures never been asked for any before. I installed this tank in the front part of the long bed like a extra tank. It's not in the frame rails under the bed.
Old 03-03-2014, 01:45 PM   #9
Clyde65
Clyde65's Avatar
Re: First trip
So that would equal about 16 or so gallons and a 254 mile trip= 16+/-MPG
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-03-2014, 02:14 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: First trip
That's what I figured about. Taking in to account I ran 75-80 the whole time with 4:10 gears in the rear and 80-100 with ease.
Well worth the swap!
Old 03-03-2014, 05:36 PM   #11
Custom 68
Custom 68's Avatar
Re: First trip
glad it is running good Andy. Is the torque converter lock up and unlock all working like it should? Since your using a GPS speedo it should all be good.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-03-2014, 06:32 PM   #12
Billett
Billett's Avatar
Re: First trip
Keep in mind, on almost all of the older cars I've driven the fuel needle doesn't drop at all for the first 50 miles or so then it starts diving real fast... Might be closer to 20 gallons used up already. Fill it up and let us know! My 6.0 is still getting 14 with 3.73s and 65 mph driving. I know its on the low side of what it should be, but this weather is killing all of my free time to get it figured out.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-03-2014, 10:02 PM   #13
Andy4639
Old member
Andy4639's Avatar
Talking Re: First trip
Yes the torque converter is locking in and out just fine. Look at the speed and RPM's. It's running about 3 to 4 hundred less than what the 700 r4 ran.
The gas gauge is less than 2 years old. It's not the old sendor either.gas milage isn't really a big concern guy's as long as it perfoms well.
I'm going to try my best to drive it at a normal speed going to the beach and see what it does but dang it's hard to keep my foot out of it!
Old 03-04-2014, 01:12 PM   #14
Andy4639
Old member
Andy4639's Avatar
Wink Re: First trip
Call the local trans shop this morning. Taking it Thursday to have the fluid changed and filters cleaned and check the temp senor wiring. Fix the gasket leak also.
Old 03-04-2014, 03:28 PM   #15
jamesjones
Freakin Awesome!
jamesjones's Avatar
Re: First trip
Awesome man. I can't wait until my first drive.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 03-04-2014, 05:00 PM   #16
Andy4639
Old member
Andy4639's Avatar
Cool Re: First trip
It was a great ride for sure.
Old 03-04-2014, 10:34 PM   #17
Acorn
Re: First trip
Andy4639
Re: First trip
Well if I request to see pics of your gas tank that would make two. I think two request in one post is worthy of a pic!
I'm extremely curious because I'm searching for a tank that is bigger than the blazer tanks that will work in my '70 with tbi.
Acorn is offline   Reply With Quote
Old 03-04-2014, 11:03 PM   #18
Andy4639
Old member
Andy4639's Avatar
Originally Posted by Acorn View Post
Andy4639
Re: First trip
Well there isn't a lot to see under the bed cover except for a rubber mat that I covered it up with and the filler tube. But OK I will take some pictures in the next day are so. I have a set of wheels in the truck right now to take and sell tomorrow. The tank has the ring that you unlock it and the whole sendor comes out. Fuel pump and all. I just swapped pumps and reinstalled it. It has the correct size lines and all of the lines you need. I have the tank strapped in to the frame rails just as you would under the truck but in the bed. It's sorta redneckish but it's hardly ever asked about since the bed cover is a hard cover and not to many people going to crawl under it to look at it.
Old 03-05-2014, 11:30 AM   #19
desertdogg
desertdogg's Avatar
Re: First trip
Andy, I like your gauge cluster where did you get yours ?
desertdogg is offline   Reply With Quote
Old 03-05-2014, 09:29 PM   #20
Andy4639
Old member
Andy4639's Avatar
Thanks,
It's a factory cluster that I installed speed hut guages in.I'm planning to redo it sometime with a better face. I think I'm going to buy the aluminium one maybe and have the holes drilled for the gauges.
Old 03-05-2014, 09:55 PM   #21
Andy4639
Old member
Andy4639's Avatar
Wink Re: First trip
As you requested! Pictures of my Redneck gas tank. Before anyone makes any comments about it. The tank is strapped just like it would be under the truck maybe better. I even doubled the straps. It has been this way since 1995. It has never given me any trouble. I don't haul a lot in the truck so it was OK to take up the room up front under the cover.
Old 03-07-2014, 12:05 AM   #22
Acorn
Re: First trip
That'll get her done. I didn't realize you had a bed cover. I was wondering how you routed your filler. Man I would love to have a 40 gal tank! I'm sure I would have a heart attack and have to get financial aid to top that sucker off. But that would be better than having to stop and get gas every 4days....
Thanks for sharing!
Old 03-07-2014, 08:35 AM   #23
Houston Ben
Re: First trip
Dang, that is massive!
Old 03-07-2014, 09:58 AM   #24
Andy4639
Old member
Andy4639's Avatar
Wink Re: First trip
Most times I only run a 1/2 tank down and fill up. That's 20 gallons and don't worry about it. I haven't done that since the motor install trying to get a feel for the milage. Last tank I did was 15.8 MPG which was mostly interstate driving. I was hoping for better milage than that but at 75-80 MPH with 2 short 100 MPH runs I guess that ant to bad for a 5hr round trip to my parents house and back. It's hard to drive it at the legal speed for a whole 1/2 tank are even a full tank to see what it will do.
Old 03-07-2014, 10:54 AM   #25
ls1nova71
ls1nova71's Avatar
Re: First trip
That isn't too bad of gas mileage for a 6.0 with 411 gears.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
