Re: 1963 C-10 SWB BBW Fleetside in NC
The last PO put a lot of parts in 5 gal buckets while doing his disassembly and left some of them in the rain. Took some of the parts.....tailgate chains and brackets and have them in a vinegar soak for a few days....pics tonight.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I'll be zinc plating my bolts soon. There's a place not to far from me that does it.
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
right on, let me know how they are price wise and the quality when your done. We had a chrome shop locally that use to do them, but they closed up a few months back. Their quality went downhill and eventually it cost them their business. Shame too....was only 5min from work and on the route home.
SC title arrived today, so I'll get down to DMV either tomorrow or Monday and then I have the green light to really start working on this build. So close.....hard to wait.
Chains came out great after a 3 day soak in vinegar. I've changed my formula up a little....75% vinegar and 25% clr. It has cut the soak time down around 30% and the parts come out just as nice. Rust prevention and primer/paint this weekend.
Goal is to just reassembly the truck and replace what parts are missing and get it to start, stop and steer while I complete the stepside. Had to straighten out a few links, but I think the OEM chains will stay around for awhile. I normally replace w/stainless steel, but to just get the truck complete...these will work. The mounting bolts appear to be stainless steel and look brand new after soaking.
Very good info. So did you use regular vinegar or cider? And what is the approximate soaking time? I was thinking I could try this on my my headers. At least the collector part at the bottom where all the tubes come together. It will be pretty hard to sandblast down in there.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#7 | |
let me know how it works out. Got the tailgate cleaned out of all the loose debris and the hardware installed. Got the pass side tailgate chain on....waiting on the inner bracket for the chain bolt before I can install the driver side. Got the tail light assemblies on also. Other than that, most of the work today was on the stepside.
Some pics of the little bit of progress I got done this weekend on the back end. The rear bumper brackets will both need replaced...and still have to find a bumper. The tailgate is actually pretty solid except for the two small holes over the "C" in Chevrolet. New trunions and bolts for all the hardware. I have the driver side chain and bolt also. So a couple more pieces of the missing puzzle put in place. Still have a bed full of parts to finish sorting through. Luckily I have a big bag of misc 60-66 bolts on hand from the last two parts trucks!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-31-2014 at 11:39 AM. |
2 hours in line at NC DMV today.....oh joy. Titles have been transferred, truck is registered...now I just have to wait between 5-10 days for a DMV officer to come to the house to visualize the cab & frame VIN's and we are all set.
![]() Join Date: Oct 2012
Hells Bells....they come to you? Frack! I hadda go to them!
Looks like your entertaining coming to the dark side of the 60-63's huh?
![]() Join Date: Mar 2013
I'm with ya..I'm not looking forward to the bull crud I'll have to go through to get my 66 licensed, registered, and insured...just more money going to the government so they can waist it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#14 | |
Off top....brakes will need rehabbed all the way around. Outer tie rod on the driver side. New e-brake linkage from crossmember and all cables. Engine bay wiring and tail light wiring. Steering shaft. Master cylinder converted to dual from single. Rear bumper & mounts. Some of the cross sills in the bed will need replaced. Rear glass needs replaced. Driver side vent is broken ( I have a spare). Other than that, it should be fairly easy. I have most off the small stuff that it needs other than the time on the cosmetic and body work.
#15 |
That's a good list for TLC. The good thing is you have all the parts so just the time to get it done. Sometimes its harder to find time than it is money. And you have two going on. I wouldn't be able to focus. One is hard enough to focus on!
Bret
#16 | |
I figger ta get my Ruger Blackhawk Lightning revolver done an it'll be so Hot Melty,Sexy that someone'll trade me fer it. I just finished installin Colt Lightning style brass grip frame and badassed spalted curly maple grips I made special fer it. Should be done inna few weeks. Last edited by Sharps40; 03-31-2014 at 08:36 PM. |
#17 |
We'll...its not listed as non-operable which is more in depth with the state. Since I was able to piece it back together prior to NC DMV involvement, its just a titled truck that's not registered...even though they give you registration....which is even more confusing. So no tags/insurance required. And yes, they'll come to you...at least in Cumberland County. I went and made the appointment right after going to DMV....the stolen plate / stolen vehicle bureau is the ones who come out. They told me they'd contact me within 5-10 days to come out and lay eyes on the frame & cab vins....which both match.
I'll let you know down the road if I decide to not build it Rich...just trying to get it NC legal and complete for now.
#18 |
I just hate all the government tape BS stuff you gotta do.....what a pain in the neck.
#19 |
The host site lost the pics, sorry.
#20 |
I'll keep it in mind Rich and let you know. Ruger Blackhawk is a good model.
Did get the stepside pulled out from under the carport and rinsed off. Will drive it a few more weeks until ready for the engine/crossmember swap. A few pics of the 2 63's together. My dad has bluing tanks in his gunsmithing shop. I did a ton of it growing up working weekend when not at my regular job.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-01-2014 at 08:17 AM. |
#21 |
I got offered a 70 Ford truck for it! HA! It'd prolly need a Chevy driveline to make it go!
#22 |
Haha.....I would have kept the pistol personally too.
#23 |
Well, its got a bit more work to go...mostly prettyin up now....but not as much work as a Found On Road Dead would take!
#24 |
Hmmmm gun and matching knife... hard combo to pass up.
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#25 |
Ya have to fight GoodWife for the dagger, that's herins. But that there pistola ain't just a simple huntin piece. When I'm done prettyin her up with sexifyin custom work that piece is gonna be so TotesmaGoats Hotty Melty Sexy that foolish boys will be rammin each other in an effort to get to my driveway for ta make the swap first!
