Old 03-25-2014, 08:23 AM   #1
66PANEL
66PANEL's Avatar
Installing Rack & Pinion on your C10
Hi guy's, I'm a new guy on here I have a 66 short panel truck, I've bagged it, got 3 in drop spendals and raised the k-member 1-1/2 in the frame (after reading some builds on here there where better ways of doing that!). But anyway I want to put a rack & pinion on it but I don't know the best way to do the tie rod ends? I was curious what you all thought! O and by the way this forum rocks!
66PANEL is offline   Reply With Quote
Old 03-25-2014, 08:33 AM   #2
Mathew21
Mathew21's Avatar
Re: Installing Rack & Pinion on your C10
I don't know the answer to your question. But I wanted to say Welcome.
Mathew21 is offline   Reply With Quote
Old 03-25-2014, 08:42 AM   #3
66PANEL
66PANEL's Avatar
Here's a few pic's of her!
Old 03-25-2014, 08:45 AM   #4
66PANEL
66PANEL's Avatar
Thank's Mathew21!
Old 03-25-2014, 09:27 AM   #5
kieth
kieth's Avatar
Rob at no limit engineering makes a rack and pinion kit,
Here is a link: http://nolimitengineering.com/produc...47&id=26244520
kieth is offline   Reply With Quote
Old 03-25-2014, 09:29 AM   #6
Jmiller022
Jmiller022's Avatar
why do you want the rack and pinion over the standard drag link and gear box set up? is it a clearance issue?
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 03-25-2014, 09:56 AM   #7
66PANEL
66PANEL's Avatar
Well it puts my tie rod ends at a serious angle, cuz I moved the K-member up in to the frame.
Old 03-25-2014, 09:58 AM   #8
66PANEL
66PANEL's Avatar
I'll check it out Kieth, thanks!
Old 03-25-2014, 10:13 AM   #9
BRASSHEAD
BRASSHEAD's Avatar
Got any build pictures of how you did the frontend? That thing looks sweet, love the stacks!
BRASSHEAD is offline   Reply With Quote
Old 03-25-2014, 11:17 AM   #10
66PANEL
66PANEL's Avatar
I think so, I'll have to dig deep that was a few years back!
Old 03-25-2014, 11:45 AM   #11
66PANEL
66PANEL's Avatar
Brasshead, here are the pic's I got!
Old 03-25-2014, 12:03 PM   #12
tincan1966
tincan1966's Avatar
I built my own front cross member, with a rack and pinion mount. What I had done was had the stock spindels reamed out to the newer taper. (OEM is 1.5 taper and the T-Bird rod ends I used are a 2.0) They fit well now.
I also did not narrow my front end any, which, looking back would have been a good idea, as I did have a little trouble getting my toe in close and having a safe amount of threads in the tie rod end. Ended up with some inner tie rod spacers in the rack, which I am not big on. I have since found that there are tie rod ends available that are 1.5" longer in the threaded section, which would have solved my whole problem, too. It's all a learning curve when you start building your own parts.
There's a lot of good kits out there, and my decision was purely with budget, and I wanted to see if I could do it.
tincan1966 is offline   Reply With Quote
Old 03-25-2014, 12:56 PM   #13
BRASSHEAD
BRASSHEAD's Avatar
Look's like you cut your frame to fit over the cross member. That's not a bad idea. I should have seen your truck around, do you go to many shows? If you get a chance you should come to Kunkels Drive-in over in Connersville this summer they have a cruise-in twice a month.
Old 03-25-2014, 01:46 PM   #14
66PANEL
66PANEL's Avatar
Ok cool I've seen the different taper reamers, I'll probably go with that! Wonder where I could find the longer tie rod ends you were talking about. Yeah I'm like you, no money, and love to build! Thanks for the info!
Old 03-25-2014, 01:52 PM   #15
66PANEL
66PANEL's Avatar
Cool, just realized your in Connersville! I know a lot of people that live there, I think half the population works in Shelbyville! Anyway I got on the road last May just in time for Beatersville car show in Louisville, KY which is an AWESOME car show, but other than that just a few local shows, but I will have to check out that cruise-in your talking about!
Old 03-25-2014, 03:14 PM   #16
BRASSHEAD
BRASSHEAD's Avatar
You may want to check this show out it's in Lewisville right on US40. Lots of cool cars and cool people, your ride would fit right in.
Old 03-25-2014, 04:27 PM   #17
66PANEL
66PANEL's Avatar
If I got it back together, I will for sure! Its in pieces at the moment! Doing a T-56 swap and all that goes with it like, drive shaft, clutch linkage and rear end gears.
Old 03-25-2014, 04:46 PM   #18
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Installing Rack & Pinion on your C10
1960-87 Chevrolet & GMC Pickup Bolt-in IFS Package
http://67-72chevytrucks.com/vboard/s....php?p=6503312
I have a Mustang II IFS Clip on my 62.
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-25-2014, 04:55 PM   #19
Mater/10
Mater/10's Avatar
Bro thats a SHHHHWEEEEEETTTTT Panel!
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 03-25-2014, 05:07 PM   #20
66PANEL
66PANEL's Avatar
Man that thing is awesome, and mean!
Old 03-25-2014, 05:09 PM   #21
66PANEL
66PANEL's Avatar
Thanks Mater!
Old 03-25-2014, 05:14 PM   #22
66PANEL
66PANEL's Avatar
Ok ? if I'm mostly replying on this forum from my phone how do I get my pics to show up? (I'm not real tech savvy!)
Old 03-25-2014, 05:38 PM   #23
1Bad62Pro/Street
what type of smart phone do you have?
Old 03-25-2014, 05:45 PM   #24
66PANEL
66PANEL's Avatar
Verizon Motorola RAZR.
Old 03-25-2014, 06:01 PM   #25
66PANEL
66PANEL's Avatar
Ok, I'm on the wife's Kindle! Want to show you guy's what I'm working on now, other than the rack & pinion
