Old 04-09-2014, 08:57 AM   #1
WDE86
86 K10 350 w/ stock Rochester Quad. Jet -Rebuild carb or go with bolt on replacement?
Question in the title. I've got an '86 K10 pickup with the original Rochester Quadrajet carb. I'm almost certain it's time to get it rebuilt/replaced. Just wondering if I'd be better off having it rebuilt or just buying a brand new carb compatible with the truck's current stock setup.
Also, if I decided to go new. What are some of my options? I'm carburetor dumb but I do know that there are some that would require a manifold swap as well and I'd like to avoid that.
WDE86 is offline   Reply With Quote
Old 04-13-2014, 03:38 AM   #2
cjlloyd81
cjlloyd81's Avatar
Re: 86 K10 350 w/ stock Rochester Quad. Jet -Rebuild carb or go with bolt on replacem
If you stick with a Q-jet (spread bore) you won't have to worry about manifold swaps. Even if you go with a square bore (edelbrock/holly) you can get an adapter plate.
If you were closer i'd invite over and rebuild it for you and teach/show u. Quadrajets are an odd carb because people either hate them, or LOVE them (me). They're a great carb once you get them all dialed in. And no I'm not a holly/edelbrock/carter/etc... hater. I love all carbs but have mostly played with Qjets. I have 5 sitting in my shed right now that I pick up for next to nothing and rebuild.
If you end up getting a new one and don't have to core return ur old one let me know
-Chris
1966 Dorsett Daytona - 16'6" Fiberglass boat "Suits Us"
1972 Chevrolet P30 Motorhome - "Giddy Up Go"
1986 GMC C3500 High Sierra Custom - "Ruby"
2007 Chevrolet Avalanche - "Faith"
cjlloyd81 is offline   Reply With Quote
Old 04-13-2014, 05:41 PM   #3
tkeduk8r
tkeduk8r's Avatar
stick with the quadrajet for sure....they are not that bad to do and will be the best for mileage and power... PLUS your way ahead because you dont have to modify anything!!! Ive done close to 100 of these carbs and it is something YOU can do... I have gotten high school kids to do them too, so you should be ok... Cliff Ruggles has a great book out there with color illustrations and great descriptions on how they go back together... dont have an ISBN on hand but do a quik search on Amazon and youll find it..... hope that helps...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 04-15-2014, 10:16 AM   #4
WDE86
--Mike
But don't I need a few specialty tools to make adjustments and whatnot once I get inside it? I was under the impression that this was the case.
Old 04-15-2014, 10:50 AM   #5
Old Truck Man
Old Truck Man's Avatar
I never had much success with rebuilding Q jets.I usually buy a adapter and adapt to a 2bbl or a square base carter(edelbrock) I once told a customer who asked how to fix a Q jet? You take a BFH and set it on the sidewalk and beat it till its as flat as you can get it. Then you install something good!
Old Truck Man is offline   Reply With Quote
Old 04-15-2014, 11:03 AM   #6
BADAZ chevy guy
BADAZ chevy guy's Avatar
When I had my last truck, 73 3/4 ton, it had a Q-Jet on it but the carb was in real bad shape and the shaft seals leaked. So, I bought a new Edelbroc 650 and tried that first. Great performance... lousy gas mileage. Then I bought a reman Q-Jet. Better mileage, but I lost a bit of the performance. The Q-Jet just wasn't as responsive off the line. Other than that... I've always loved Q-Jets and have rebuilt several over the years.
My new truck, 1977 C10, I'll be going to Edelbroc because I want better responce and I'll be running Vortec heads and aluminum manifold.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-15-2014, 06:43 PM   #7
crashz
crashz's Avatar
I like the Q-jets for power an mileage. But they take a bit of tinkering to get just right. i guess all carbs do, but I could never get my holleys set up to run as smooth and clean as the Q-jets. Had both on 350's and 454's, and both times I was able to get much more from the Q-jets.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 04-15-2014, 07:29 PM   #8
geezer#99
geezer#99's Avatar
Common tools needed:
Big flat screwdriver.
Small flat screwdriver.
Needle nose pliers.
Old 04-15-2014, 08:05 PM   #9
imjeff
imjeff's Avatar
Definitely Quadrajet. Back before the internet people used to give them away if they got a "bad one". It was usually an ignition problem! The ones that got some people hating them had internal vacuum leaks (easy fix). A lot of people don't like them because someone told them not to. Holley did a lot of very good advertising, Rochester, not so much, but I still prefer the Quadrajet. No constant blowing of power valves, no fuel leaking gaskets, a bazillion different metering rods, small (responsive) primaries.......what's not to love?
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-15-2014, 10:32 PM   #10
Irishbleueyes
You can get decent performance and mileage out of an Edelbrock. Advantages are theres no gaskets below the float bowl to leak, the primaries do have metering rods and different tension springs to lift them at specific vacuum pressure like the Qjet but not on the secondaries. Metering rods can be changed in seconds, they're right under the air cleaner. Edelbrock has many jet sizes and metering rod sizes. Also affordable. Install an AFR (air fuel ratio) gauge and really dial it in it. Its like doing your own dyno work, you'll love it
Irishbleueyes is offline   Reply With Quote
Old 04-16-2014, 09:21 AM   #11
bnoon
Rebuilt and properly adjusted, any carb sized appropriately to your engine will perform well, no matter the brand. For my basically stock 86, a rebuilt Quadrajet was the choice. Started with the flick of the key and one pump every time, even through winter... For my 454, a 750 Holley will most likely ride along, and the built 350 in my 74 will be a Holley 600.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 04-16-2014, 09:53 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
my 78 has a square holley on it,and i've tried to fix it,rebuild it? no
79 has a 2B,both going to stock 4B Q-jets
picked this used intake up for that change over
you can see the second set of holes
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-14-2014, 12:45 PM   #13
Old Truck Man
Everything you state is spot on. I grew up messing around with the Carter AFB carbs. Its what im familiar with and I like mechanical secondaries. The edelbrock is nothing but a rebaged carter.
Old 05-14-2014, 09:25 PM   #14
Irishbleueyes
Yes, just an ol carter. The quadrajet does have the better secondary setup but edelbrock does have the AVS carb that has some kind of adjustable secondary that I haven't fooled with yet. Edlebrock doesn't have a wide enough variety in metering rod sizes down in the small end. Small ci motors need the smaller jets and smaller metering rods and they are really sensitive from lean-even-rich just by a thousandths or two to make a dynamic change on the AFR at least I found out. Had to make rods just for mine by sanding down the power end with emery cloth and a drill...
Old 05-15-2014, 01:26 AM   #15
rich weyand
rich weyand's Avatar
I took the metering jets down a size to put the A/FR in the middle of the range of metering rods where there are more choices.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-15-2014, 07:54 AM   #16
naphtali5725
naphtali5725's Avatar
QJet's were only installed on millions of cars, so they must be a bad carb right? LOL
great carb, no need in anything else... get a good carb rebuild kit for it...
go to Cliff Ruggles web site, and get a rebuild kit
or get in contact with Lars Grismund he'll rebuilt it for a fair price, quick turn around that's who did mine... excellent
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-15-2014, 08:17 AM   #17
tucsonjwt
On my 3 squares, I have had 2 new Carters, 1 new Edelbrock, 2 rebuilt Q-jets from auto parts stores, and got my current Q-jet rebuilt. Of all these, the current rebuilt Q-jet was the best, but the local rebuilder did not do a very good job. I will go with one of the better online Q-jet rebuilders next time.
The Carters and Edelbrocks worked OK, but I had trouble with the quality of the parts. The throttle shaft would jam on one Carter. On the Edelbrock, the throttle valve was too big for the opening (or the opening was improperly machined) and would jam.
tucsonjwt is offline   Reply With Quote
Old 05-15-2014, 10:25 AM   #18
Irishbleueyes
I don't think anybody is saying anything bad a about a Qjet and I think we all agree its the best carb made. For sure we all agree if you could buy a brand new one, we all would. Maybe some day fuel injection will be affordable for all...
Old 05-15-2014, 10:30 AM   #19
naphtali5725
yeah, 2000 bucks or so for EFI is ridiculous, glad there are a few QJet specialists still around
My build thread...
Disabled Veteran
Old 05-15-2014, 01:37 PM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
sure is ,i picked up a new Quad for my 79
John
Old 05-15-2014, 05:55 PM   #21
naphtali5725
where did you get that one? price?
My build thread...
Disabled Veteran
Old 05-15-2014, 09:00 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
My local parts guy.think it was 325/350.plus core
Figured better to swap in a new quad, then rebuild the old 2B .
Might even get better mileage if I keep my foot out of it lol
John
Old 05-18-2014, 11:25 AM   #23
Irishbleueyes
What size Edelbrock carb do you have and what size jets came in it and what size jets did you end up with?
Old 05-18-2014, 12:12 PM   #24
rich weyand
Edelbrock 1406. Stock jets and rods are:
Primary jets: .098
Primary rods: .075+.047
Secondary jets: .095
I am running A/FR of 14-14.5 (cruise), 13.5 (power), and 12.5 (secondaries) on a 350 with stock low-compression heads, dual plane manifold and headers with these jets and rods:
Primary jets: .095
Primary rods: .064+.055 (polished down from .067+.055)
I also run the 8" step-up springs stretched an extra 1/4" in length for earlier transition, because my cam (Comp 12-300-4) draws like 18" of vacuum. In the winter I switch to .062+.052 primary rods to keep the same A/FRs with the colder, dryer air.
Performance is great, transitions are crisp and without stumble. Dyno simulation predicts 275hp at 4000 rpm and 422lbft at 2500 rpm at the flywheel. In recent mileage testing in best tune I get 9.5 mpg on short trips around town (5-10 miles one way with lots of stop and go), and 11.5 mpg at 65mph on the highway.
Rich Weyand
1978 K10 RCSB DD.
Old 05-18-2014, 02:39 PM   #25
midnight rambler
midnight rambler's Avatar
Research edelbrock 1902. Cant get them new but can find them rebuildable or just rebuild ur stocker
midnight rambler is offline   Reply With Quote
