Re: Project: 1972 K30 Crew Cab Duramax
the roof looks nice and flat. i think that makes it look right. one of these days i will have to tackle a crew cab project. i just dont have much confidence in my ability to do the work you are doing now. one day when i get a big boy shop to work in... haha
SWB 4x4 Collector
![]() Join Date: Jun 2001
Ryan, I feel like the little kid when talking thicker type welding. I'd say you'd be fine lol.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
6>8 Plugless........
![]() Join Date: Sep 2007
Trevor, great work on it. It's looking great.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
SWB 4x4 Collector
Thanks Ryan, Everything from here on out will be rough fitting to get my proportions and driveline figured out and then I will tear it all back down for paint. Never did a project like that and always wanted to.
SWB 4x4 Collector
Got the cab on. Cab mounts lined up. Optical illusion on the way the cab sits. I have to still put my 4x4 hangers on the rear frame to level out to the front. My frame is hanging roughly an inch lower under the rear cab mount than the front.
Wow, it's looking good Trevor! Those 157" frames are so loooong!
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
Still Learning
Incredible build you have going here! I don't usually get on the 4X4 section, that explains why I've never seen it. I love all the attention to details on the rear pillar and fourth door. All that hard work will pay off when you are cruising in this beast. I hope to have one myself someday.
Keep up the good work! |
SWB 4x4 Collector
7Dee2, Thanks for the kind words. These frames are definitely long but perfect for my build. Just wish the original owners didn't change the wheelbase already, than it would be closer at least. Though, at least they didn't section the frame and rebooted the brackets further back on the rails. Its like having a 72 built duramax frame, here is the back of the dmax frame. I'm planning on using the rear spring perches from it and the longer springs for a better ride.
Thanks Mcbassin, almost hit the 1year mark. This build area doesn't see the traffic of the other build area, but am trying to do my part to keep the site organized.
SWB 4x4 Collector
Found a little time to change out the cab mount cushions to the correct 4x4 ones.
That looks nice! Do you plan to move the front axle to where it's centered in the wheel well opening? My crew cab build keeps getting pushed back. we're looking for a house now, so who knows when it'll start. I've got the burb shell and donor cabs, just too many other things to finish before I start on it.
SWB 4x4 Collector
Ryan, there are some things out of skew. Fender is loosely bolted on and needs to go back a hair. Only have a bolt going through where a bushing goes on my passenger side shackle is. The angle of the pic don't help either. Trevor
Yeah, the excitement of standing back and getting a first view.
Vintage 4x4s
Nice project! I like how you're using a beefy frame so you can use the truck to the haul heavy loads if needed, since the drivetrain will allow you to.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
SWB 4x4 Collector
Thanks Jud, hoping to get the donor in the shop this coming week and start tearing into it. I get a free shop weekend this coming weekend and don't have to leave its site like most weekends. Trevor
#15 |
Subbed for the build. Looks sick so far. Is that a short bed on the frame there? Do you plan to put a long bed on it or shorten the frame? Looks like a very high potential build and a duramax swap is a cool twist. I may have missed it but have you decided if you are going to run the Allison or another Trans with an adapter? Will you run a standalone harness or try to put the whole duramax harness in the 72?
My names Tye. No Chevy right now ![]() |
#16 |
SWB 4x4 Collector
Tye, it is a short bed, I have to dial in the rear end on the frame with 4x4 spring hangers and won't have to splice the frame. It will retain the Allison paired up with a Cummins/Getrag np205 29 spline transfer case. I will also be doing a stand alone as I want to run the original 72 tilt column and a factory-ish gauge cluster. I don't want to run the duramax gauges.
#17 |
SWB 4x4 Collector
Put in a little time on the truck between chasing leads on new projects and parts. Took a pic of the distance I am pretty much taking off the rear portion off the 157" wb frame. The yellow line is where the end of a normal cab and chassis frame ends. Also, I finally figured out what spring hangers I needed for this frame and got those cut off at a salvage yard today. I need to allign the bed still but I think I can figure that out as I move forward.
#18 |
It's looking good Trevor!
#19 |
Looking good your build is awesome. looking great
#20 |
SWB 4x4 Collector
Thanks Ryan!
Mikie, your build is getting off good. Keep it up!
#21 |
Still Learning
Very nice!
#22 |
![]() Join Date: Aug 2013
Very cool. Looking forward to seeing this one done.
#23 |
![]() Join Date: Jul 2012
good work so far! keep it up!
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
#24 |
I just read your whole build. Looks awesome! You have quite a stable of cars and trucks. I love your blue and white shortbox.
Bud |
#25 |
Any progress Trevor?
