Old 04-15-2014, 10:51 PM   #1
gehrts
1972 GMC 4x4
Parting out a 1972 GMC 3/4 ton 350 / 4 speed / 4x4. 4.11 gear ratio. Parting out complete chassis.
Front and rear spiral shocks $120.00 + shipping $75.00 shipped
Complete clutch linkage setup $40.00 + shipping SOLD
Power steering pump and brackets $50.00 + shipping SOLD
Complete gas pedal / throttle cable assembly $50.00 + shipping
Front exhaust hanger $15.00 + shipping $12.50 Shipped
Points distributor & coil $25.00 + shipping
High hump manual / 4x4 $40.00 + shipping
Fan shroud $40.00 + shipping
Upper radiator hose pipe $25.00 + shipping Sold
Spark plug wire heat shields w/bolts $25.00 + shipping
Brake booster assembly with brackets $30.00 + shipping CAN NOT FIND
Exhaust manifolds left & right $75.00 + shipping SOLD
Rear overload spring set / with hardware $100.00 + shipping $60.00 + shipping
Transmission / transfer case cross member $50.00 + shipping
Front cross member $25.00 + shipping
Front bump stops $10.00 each + shipping
Rear bump stops and brackets $12.00 each + shipping
Front spring front mount $30.00 each + shipping
Front spring rear mount $20.00 each + shipping
Left front spring stop $10.00 + shipping
Front parking brake cable $20.00 + shipping
gehrts is offline   Reply With Quote
Old 04-15-2014, 11:20 PM   #2
cst204x4
Re: 1972 GMC 4x4
Interested in speedometer cable and spark plug wire holders at rear of intake
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 04-15-2014, 11:24 PM   #3
gehrts
Re: 1972 GMC 4x4
Rear spark plug wire holders and speedometer cable $30.00 + shipping.
Old 04-15-2014, 11:28 PM   #4
t korinek
Truckin' Krazy
t korinek's Avatar
Re: 1972 GMC 4x4
I'll take the upper metal hose if not completely rusted out, power steering pump & brackets , does that include the pulley too? Pending reasonable shipping to 85207
& how about the front lockout hub assemblies? are they in decent shape? how much shipped with the other stuff
Thanks,
Tom
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 04-15-2014, 11:44 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 1972 GMC 4x4
Cost and condition of the pitman arm shipped to 59901 please.
Old 04-15-2014, 11:48 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 1972 GMC 4x4
Also, should be a Dana 60 rear if a GMC but if an Eaton HO52 does it have a posi rear diff?
Old 04-15-2014, 11:51 PM   #7
JeffD72
JeffD72's Avatar
Re: 1972 GMC 4x4
Interestd in the Spark plug wire heat shields w/bolts, can you quote shipping to 66207?
JeffD72 is offline   Reply With Quote
Old 04-15-2014, 11:53 PM   #8
cst204x4
Re: 1972 GMC 4x4
I'll take the cable and wire holders also in line on lockouts and shipped price on brake booster assembly to 48817
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
Old 04-16-2014, 06:03 AM   #9
dodgiesdad
dodgiesdad's Avatar
Re: 1972 GMC 4x4
I would be interested in the torque mount for the transfer case (this is the part which bolts to the side of the transfer case and then to the passenger side of the frame). What is the condition and cost shipped to 15701?
dodgiesdad is offline   Reply With Quote
Old 04-16-2014, 06:26 AM   #10
undertaker72
undertaker72's Avatar
Re: 1972 GMC 4x4
ill take the shroud if its in good shape , do you have a pic , and ill get in line on front selective hubs
undertaker72 is offline   Reply With Quote
Old 04-16-2014, 06:38 AM   #11
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: 1972 GMC 4x4
Interested in locking hubs, a few more pictures and condition description. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 04-16-2014, 08:15 AM   #12
gehrts
Re: 1972 GMC 4x4
t korinek, I will get pictures of the upper metal hose to you today. Power steering pump, pulley and brackets are still on the truck. I will get them removed tonight to get a weight for shipping. The front hubs are not for sale. Thanks Mike
Old 04-16-2014, 08:19 AM   #13
gehrts
Re: 1972 GMC 4x4
DeadheadNM
I will inspect the pitman arm tonight and send you pictures. I should be able to ship the pitman arm in a USPS flat rate envelope, I think. Thanks Mike.
Old 04-16-2014, 08:22 AM   #14
gehrts
Re: 1972 GMC 4x4
DeadheadNM
I will look at the rear differential tonight. Pretty sure it is the Dana. Doesn't the Eaton have a back cover on the housing, but the carrier comes out the front? Thanks Mike
Old 04-16-2014, 08:24 AM   #15
gehrts
Re: 1972 GMC 4x4
JeffD72
I will remove the heat shields tonight and get a shipping quote. Thanks Mike
Old 04-16-2014, 08:27 AM   #16
gehrts
Re: 1972 GMC 4x4
cst204x4
I will remove the spark plug wire holders tonight. The lockouts are not for sale. I will get a shipping price on the brake booster assembly. Thanks Mike.
Old 04-16-2014, 08:29 AM   #17
gehrts
Re: 1972 GMC 4x4
dodgiesdad
I will inspect the mount and get you pictures tonight. Thanks Mike
Old 04-16-2014, 08:30 AM   #18
gehrts
Re: 1972 GMC 4x4
undertaker72
I will get you pictures today of the shroud. The hubs are not for sale.
Thanks Mike.
Old 04-16-2014, 08:30 AM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 1972 GMC 4x4
Originally Posted by gehrts View Post
DeadheadNM
Thanks - I'll bet a small flat rate box would work. Hoping the grooves are nice and solid.
DeadheadNM
Yes, unlike the Dana the Eaton rear diff is removed via the front of the axle and has a round cover on the rear.
Old 04-16-2014, 08:31 AM   #20
gehrts
Re: 1972 GMC 4x4
D.PASSMORE
Sorry, the hubs are not for sale. Thanks Mike.
Old 04-16-2014, 09:18 AM   #21
sboris
sboris's Avatar
Re: 1972 GMC 4x4
Second in line on the upper radiator pipe..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 04-16-2014, 09:49 AM   #22
JimH2828
Re: 1972 GMC 4x4
I'll take the exhaust manifolds with bolts if $80 shipped to 30005 GA works for you.
JimH2828 is offline   Reply With Quote
Old 04-16-2014, 10:17 AM   #23
BlueMule72
Re: 1972 GMC 4x4
Front driveshaft to 58045?
BlueMule72 is offline   Reply With Quote
Old 04-16-2014, 03:55 PM   #24
gehrts
Re: 1972 GMC 4x4
JimH2828
I will get them weighed and get you a shipping quote.
Thanks Mike
Old 04-16-2014, 03:56 PM   #25
gehrts
Re: 1972 GMC 4x4
BlueMule72
I will get it weighed and get a shipping quote tonight. Thanks Mike.
