04-17-2014, 04:54 AM | #1 |
Active Member
66 Pro Street Build (Domeringer)
Hi All, Have been lurking this great forum for a while. I'll start by introducing myself... My name is Gary and I live in Connecticut. Had a shop that specialized in drag bike chassis and go fast work... decided it was time to close down and have some fun with other things. Bought this truck a while back and drove it for a year... but the drag racing in my blood took over again. I'm going to pretty much scratch build the whole setup, any questions or advise will be greatly appreciated.
The truck was purchased tricked out old school and had this sticker on the back window... so that's what we'll call it! Think it will live up to it's new name Here's some pics of the truck the way I bought it. 350 (010 block) with an M20 tranny, 2 inch drop spindles, 3" drop springs up front, 4" drop springs in the rear, disc brake conversion up front. Had some issues but all in all very cool truck and had a blast cruising with it. Here's some pics of where we are at this week. Will try to do my best at giving a weekly update. No time today but will post up the plan tomorrow |
04-17-2014, 05:19 AM | #2 |
Re: 66 Pro Street Build (Domeringer)
Welcome aboard!
That's already a great looking ride so i can't wait to see what you're gona do with it.
My old truck: '66 Shortbed Stepside - Ex USAF - Shiny and new on the inside & underside, original patina on the outside. - http://67-72chevytrucks.com/vboard/s...d.php?t=487701 Tattooed pinstriper and graphic designer with an awesome award winning beard! Check me out at http://www.vontash.co.uk |
04-17-2014, 07:27 AM | #3 |
Very Cool Truck. You have the exact lowering setup that I plan to run. So now I know what it will look like. Your engine looks almost spot on to what mine did.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
04-18-2014, 05:09 AM | #4 |
Active Member
Hi Neatbeard Thanks had mixed feeling about tearing it down for the project. Had a look at your facebook page, great work! Also read your build story and that's just plain cool that you were able to find the original. Good luck with your future enhancements!
04-18-2014, 05:20 AM | #5 |
Active Member
Hi Bret, I liked the stance of the truck with that setup and glad you were able to get a preview. When I get this current project finished I will use the parts from this one to build another almost the same way. The cross member was hacked pretty bad on this one and trailing arms were shot. Will post some pics later to show what not to do.
04-18-2014, 05:42 AM | #6 |
Active Member
Ok basic laundry list...
LS1 about 425 HP N/A all ARP Twin Turbo setup shooting for about 1000 HP 4L80E Tranny Strange center housing 3.25" tubes, back brace Strange Ford 9" nodular iron case (3.25 bore) Spool with 35 Axles Autoweld Ultimate II 4 link, custom bent 2 X 4 frame rails. Nice stuff! Wilwood rear discs W/Parking Brake Will post more parts later... This weekend plan to remove the body and cab top to send off for media blasting... will post picks |
04-18-2014, 10:59 AM | #7 |
1000 hp
Truck is sweet!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-18-2014, 01:17 PM | #8 |
Senior Enthusiast
Welcome to the forum! Looked like a very neat truck to begin with, and should be a lot more fun when you're finished!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-18-2014, 02:04 PM | #9 |
Welcome from Clinton ct, my dad and i are also building a 66. It's a k-20. Evan396
04-18-2014, 02:51 PM | #10 |
and to the site !!
I also have a 66, and I really like your wheels
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-18-2014, 08:18 PM | #11 |
welcome to the MADNESS. nice truck. if you go to the engine and drivetrain section on this site there is a guy that either won or came in second on the PINKS show. he might help you set up the truck to run well!!!!
04-19-2014, 07:00 AM | #12 | |||
Active Member
Thank you! Have to have a goal we will see what that LS can hold
First time visit to the engine and drivetrain section! Lots of very good LS info thank you for heads up and welcome! |
04-20-2014, 12:52 AM | #13 |
60-66 Nut
Welcome to the forum Gary
This sounds like my kind of build.......I'll be watching.
04-20-2014, 08:38 AM | #14 |
Active Member
Hi Captain, Been following a lot of your posts while lurking Great fab work and a great help to all C10 heads! Thanks for the welcome!
04-20-2014, 09:08 AM | #15 |
Active Member
OK Plans of having the cab on a trailer today and off to the media blaster were nixed by the boss... but it's ok to sit here and post pics. So here's some part pics and info for the build.
Autoweld Ultimate II Pro Street Full Clip As mentioned I will fab the setup to try and keep costs down. Urethane Rod Ends, Frame Brackets, Rear Housing brackets, Shock Brackets and Wheelie Bar Brackets, Custom Frame Rails More parts... Strange Engineering Bare Housing (3.25" Diameter Strange part number H1112) 3.25" X 1/4" Wall DOM Tube Wilwood 11" Diameter DYNAPRO LOW-PROFILE 2.50" OFFSET, BIG BEARING FORD NEW STYLE (Torino ends) Wilwood part number 140-11389-D Last the sneakers... Centerline Warrior 15" X 15", 5/8" X 5X5" BC, Mickey Thompson 29" X 18.5"-15LT Hope you all have a nice Easter Holiday! |
04-20-2014, 12:14 PM | #16 |
SWEET!! 1000hp
Im in for this one, are you going to make your own rear wheel tubs or use the factory style but just widen them?? I used 67-72 style tubs an widened mine like 4.75" I will be putting a 29x15x15 on the back, just got to get the right backspacing and offset for the rims to fit right
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
04-20-2014, 05:25 PM | #17 |
That's a gonna be one heck of a c-notched frame! LOL!
04-20-2014, 05:35 PM | #18 |
very cool project, can't wait to see this done
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-21-2014, 05:43 AM | #19 | |
Active Member
LOL
Thanks T. J. Quote:
04-21-2014, 06:38 PM | #20 |
if I remember right the 29x15x15 will fit, just have to have the right offset and backspacing! my tubs are 16in. from the inner bedside, so there maybe an inch or so! when I cut my steel floor out it pretty much goes straight up from the frame! there's a thread in the sub section 'rocktonka' is the member, check out what he has done! it shows that that's pretty much the biggest tire you can go with without cutting the frame!
04-22-2014, 06:55 PM | #21 | |
Active Member
04-22-2014, 07:03 PM | #22 |
Active Member
More parts came in
Aldan Eagle Double Adjustable Coilover, 17" Aldan part number 758, Made in the USA Strange Engineering 3.25" Bore Ford Housing, Strange part number N1906 |
05-19-2014, 10:00 PM | #23 |
Active Member
Hi all, Been a while since I posted last and figured it was time for an update and some pics. Left off posting that we were going to remove the cab... done! Have spent a lot of time building a jig for this project... here's progress so far. Should start some frame cutting and welding this weekend.
05-19-2014, 10:58 PM | #24 |
Welcome Gary. This looks to be a bad ass project. I'll be following.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
05-27-2014, 07:04 PM | #25 |
Sweet looking build. I'm gonna watch this one
Tags |
66 c10, drag truck, pro street, twin turbo ls1 |
