Old 06-22-2014, 11:22 PM   #1
neal64ss
2-yr build for my 13-yr old (1968 C-10 SWB fleetside)
Always wanted to build one of the 67-72 SWB fleetside trucks and when my 13 yr old son said he was interested as well I decided to go get one. I did not pay very much and I didn't get very much as well. Hope I can put it in nice, safe, dependable driving condition before he hits 16 yrs old.
neal64ss is offline   Reply With Quote
Old 06-22-2014, 11:29 PM   #2
thelonerife
thelonerife's Avatar
Re: 2-yr build for my 13-yr old (1968 C-10 SWB fleetside)
Nice starting point.
thelonerife is offline   Reply With Quote
Old 06-22-2014, 11:32 PM   #3
neal64ss
We got the front clip removed and found a few surprises. Looks like it was hit in front drivers side corner, not so bad. Rusted where bottom rear of fender bolts to cab, guess this is fairly common. Can I get replacement sheetmetal for that area? Where is the best place to get the sheetmetal parts like rockers and floorpan sections? Also noticed a strange upward bend in the frame on the passsenger side. Anyone know why the frame would be bent there and how does a guy go about fixing that? See pics.
Old 06-23-2014, 08:16 AM   #4
Low Elco
You can get the cab metal from most of the usual vendors, classic, lmc, brothers, GMCPaul, Jim Carter, Ron Manes. The turned up lip is factory. No one knows why. Torch it and beat it flat if it bugs you. Leave it if you're going LS, some guys use it to their advantage dealing with AC lines. Good luck!
Low Elco is offline   Reply With Quote
Old 06-23-2014, 10:46 AM   #5
neal64ss
Great, one less thing to worry about. I am going LS so that may help with clearance.
Old 06-23-2014, 11:10 AM   #6
mcbassin
Still Learning
mcbassin's Avatar
Looks like a pretty solid start. Two year build is ambitious. Looking forward to following along. Welcome to the forum BTW.
Old 06-23-2014, 12:04 PM   #7
nlped
nlped's Avatar
I'm watching... 2 years is a great timeframe, but you better get to work
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-23-2014, 12:27 PM   #8
KMC3420
KMC3420's Avatar
Looks like a great start to me, appears you have all the body panels. I think two years is a great goal and maybe with your sons help you will be able to achieve that. Good luck and welcome!
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 06-23-2014, 04:00 PM   #9
scotts72heavyhalf
scotts72heavyhalf's Avatar
Two years? No problem. From start to finish me and my two boys finished our truck in less than one year, you will have her done in no time.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 06-26-2014, 08:58 PM   #10
eagleuh1
eagleuh1's Avatar
Hey Neal64ss, glad to see you got the build thread going. Was going to say that lip helps to keep the AC lines from hitting the frame. Also allows wrench room. Truck looks nice. Good start for a project. I got most of my panels from Banana something or other. Triplus parts. Most we're good quality. Don't get the bed floor repair panel, nowhere near matching oe. Everything else was close enough to make work. There's a nice crate LS3 in the adds section. Just what a 16 year old boy needs. Good luck. Jim
eagleuh1 is offline   Reply With Quote
Old 06-26-2014, 11:02 PM   #11
neal64ss
If I buy an LS3 crate engine it will go in my 64 chevelle and the boy will get the 5.3L I am currently running.
Old 06-28-2014, 10:12 AM   #12
Xeen
Xeen's Avatar
Good plan, no 16 year old boy needs 430 HP that's just asking for trouble.
You are going to enjoy this truck just as much as he will they are a lot of fun.
Tabco makes some of the best fitting replacement panels and patch panels and they are made in the USA , no matter where you buy the patch panels make sure you get the direct replacement version not the slip on version because there are both types available, Tabco indicates the difference on their website but unfortunately most others don't so be careful when ordering. http://www.tabcobodyparts.com/
One other thing, don't forget to have fun and cherish the one on one time because as you know they grow up way too fast and are gone before you know what happened.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-28-2014, 09:27 PM   #13
neal64ss
Thanks for the info. Looks like they have competitive pricing as well.
Old 12-08-2014, 09:41 PM   #14
neal64ss
Update time. Been busy last few monthsbut trying to get back to work on the 68 truck. Found a frame on craigslist. It had 5 lug discs and rear, which I was planning to change anyhow and it is straight, so I bought it. Got it stripped down and plan to flip the rear trailing arm brackets, install bolt in c notch, and sandblast it in the next week. Will then give it a couple coats of rust encapsulator and a couple coats of chassis black.
Old 12-09-2014, 05:54 PM   #15
neal64ss
Old 12-09-2014, 06:17 PM   #16
KMC3420
KMC3420's Avatar
Nice update, looks like a good score, and one step forward. Keep us updated and remember to have fun with the kiddo.
Keagan
Old 12-10-2014, 09:14 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
Nice looking frame. Craigslist scores are good
Old 12-11-2014, 04:34 AM   #18
gdavis
gdavis's Avatar
good luck there man. At least you have some help. Grab hold and enjoy the ride.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 12-17-2014, 10:09 PM   #19
neal64ss
Working today at installing c-notches. I hate rivets. Took out about 20 a week or two ago and thought I had developed a winning method (Dremel & air chisel). Currently am stuck trying to get the two rivets out where the coil spring mounts. Got the c-notch section cut out but the rivets are kicking my butt.
Old 12-27-2014, 10:24 PM   #20
eagleuh1
eagleuh1's Avatar
I like drilling the head out till it falls off then punching the rest out with a hammer and punch. Any pics?
Old 12-28-2014, 12:57 AM   #21
kxmotox247
kxmotox247's Avatar
Drilling rivets sucks. Quickest way I've found so far is to use a flap disc like these:
http://www.ebay.com/itm/WEILER-50603...item4874fa21ff
With a 4" grinder it takes about 90 seconds to grind the whole rivet head off. Then just use a punch to knock the rest out.
Looks like a great project!
kxmotox247 is offline   Reply With Quote
Old 01-05-2015, 10:58 AM   #22
neal64ss
Got the c-notches installed. My new method for removing rivets is cut head longways with cutoff wheel, air chisel to remove head, punch out if possible, drill out if it will not punch out. Now to get this frame painted.
Old 01-12-2015, 10:35 PM   #23
neal64ss
Got frame painted over the weekend. Used rust encapsulator and chasis black from eastwood. Put both on with brush. Rust encapsulator went on great and easy. Chassis black went on OK but if I had to do it over again I would have sprayed it instead of using a brush. Just the frame, so I am happy with the result. Big milestone in the build to now have the frame done and ready to start on the suspension.
Old 01-12-2015, 11:10 PM   #24
slowcpe
slowcpe's Avatar
Looking good. Its amazing what a coat of paint can do.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-12-2015, 11:52 PM   #25
KMC3420
KMC3420's Avatar
Looking good! Wait til it rolls. That is a great feeling. Warm weather will be here soon enough. That's much more fun when it's nice out. GO HOGS! Saw your little razorback sticker.
Keagan
