07-03-2014, 02:26 PM | #1 |
Project Beatrix
Renderings:
Changed my first post to be more of a build log. I will include what I have so far for parts and what still needs to be done. Hopefully I get some time and I will try to put prices to everything. Build Information Powertrain: 2003 6.0L/317 Heads (LQ4) - Purchased Turbo Cam (Speed Inc TU1 (Lift .581/.581 Duration @50 225/225 113 LSA) -Purchased LS9 Gaskets - Purchased LS7 Lifters - Purchased ARP Head Studs - Purchased Valve Springs - Purchased Hardened Push Rods - Purchased HV Oil Pump - Purchased LS2 Timing Chain - Purchased Accessory Drive (Drive Junky) - Purchased Holley Hi-Ram - Purchased Holley Retro Oil Pan (302-2) - Purchased Valve Cover Adapters - Purchased 1967 Chevy Valve Covers - Purchased Transmission: 4L80e (2006) - Purchased Last edited by boostedc10; 04-21-2016 at 04:51 PM. |
07-03-2014, 02:29 PM | #2 |
Re: My 67 SWB BoostedC10 (LQ4 S475)
Cab floor, outer rockers and cab corners were in pretty bad shape but not a big surprise in these norther trucks.
07-03-2014, 02:33 PM | #3 |
Previous owner had also cut a hole in the bed for a fuel cell so the decision was made to go with a black walnut wood floor. It will be fully raised to clear the notch in the new rear suspension.
07-03-2014, 03:04 PM | #4 |
Got the chassis stripped down and ready for the Suicide Door Triangulated 4 Link. Just a note this was long before Nate had his rear kit
07-03-2014, 03:06 PM | #5 |
Here it is with the bed test fit.
07-03-2014, 03:09 PM | #6 |
Next up on the list of to do's was to get the frame filled and sand blasted, then get a fresh coat of paint on it.
07-03-2014, 03:12 PM | #7 |
I had all the chassis bolt-ons powercoated grey. This will be the same gray that will be used on all the bright work on the truck. (Bumpers, door handles and so on)
07-03-2014, 05:16 PM | #8 |
It'll Buff Out!
I know that **** Storm all too well. Caught up in one of my own.
It looks like it's coming along good, and I love the fact your doing it with your Son. My boy is right along side me working on mine and My girl is now old enough to Ask Why?, Why?,Why?,Why?,Why?,Why?,Why?, Good luck and I look forward to seeing it come together! Subscribed!
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
07-03-2014, 05:32 PM | #9 |
I like it. That black & gray look great on the rendering.
07-04-2014, 10:55 AM | #10 |
Thanks guys. A ton more pictures soon.
So.Cal.Super I would say the kids make a build that much more special for sure! |
07-08-2014, 12:51 PM | #11 |
I will be running a 6.0l LQ4 stock bottom, 317 heads, cam, and the S475 through a 4l80e. Goal is around 700 at the tires.
Here is the "Little" turbo And a shot of the 6.0l I just picked up. |
07-08-2014, 03:16 PM | #12 |
Looks good!
Also looks like we're going about the same place with our builds other than I will still have a stock rear clip/no raised bed floor.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
07-08-2014, 03:59 PM | #13 |
Should be amazing.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
07-08-2014, 05:03 PM | #14 |
sweet!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
07-08-2014, 05:39 PM | #15 |
Here is the cab after it was sandblasted and put in epoxy.
Working on the cab corners, floor and rockers now. Hope to have the metal work finished up in the next few weeks. |
07-08-2014, 05:44 PM | #16 |
Also ordered the CPP big brake kit for the front and rear. Put the fronts on to see how they fit before tearing them down for powder coat. Shortly after the tear down I scored 4 brembo 4 piston calipers so I may swap the CPP calipers out to get the stopping power.
And a pic of my boy tearing them down Last edited by boostedc10; 07-09-2014 at 06:47 AM. |
07-08-2014, 05:52 PM | #17 |
Had a good friend of mine that is a fabricator build me a aluminum fuel tank to house my A1000.
He thought it was funny to show me after it was done that the pass throughs in the baffles were little penises! Got to love my friends! |
07-17-2014, 02:22 PM | #18 |
Made some progress today and got the cab floor out. It was fairly simple just had to brace the cab a bit and go to town with a spot weld cutter. Now, while it is out i need to replace some rot on the inner kick panels and replace the lower end on the "a" and "b" pillar along with the cab corners.
07-17-2014, 02:29 PM | #19 |
Also got lucky and found a Savanah van in a you pull it yard with a 4l80e. An hour of mine and a buddys time with hand tools and she was out with all the parts needed.
I will start tearing it down to rebuild it next week. It will get an HD2 shift kit with a complete trans-go rebuild kit and a single disc 10" 3400 stall converter I am having built. |
07-18-2014, 11:15 AM | #20 |
Boosted Member
Looking good. Gotta love those BW turbos.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
07-18-2014, 11:23 AM | #21 |
Thanks and ya you can't beat them for the price vs performance.
07-18-2014, 11:31 AM | #22 |
Ill be watching this one, I like where you're going with it.
Brannon Yazell 67' C10 mated w/ a 01' Silverado, extreme custom 2015 Chevy 2500 Z71 LTZ Crew Cab MSA, Motorsports Authority, Rigid Industries, Magnaflow, Michigan Metal Works, Raceline, BASF, Street Trucks http://67-72chevytrucks.com/vboard/s...d.php?t=624964 |
09-04-2014, 01:48 PM | #24 |
Still Learning
Killer build! I'm glad I found it. Looking forward to following along.
BTW, I dig the baffles |
09-04-2014, 01:51 PM | #25 |
Thanks mcbassin. Hoping to have my wheels shortly from Travis @properfomrance! New pictures coming soon!
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
