#1 | |
Re: Walter DeWayne...Walt for short
Did you get two small air tanks one for each compressor instead of one large one, from what I have seen that is the better set up. |
![]() Join Date: Jul 2009
Yep. And 2 compressors & the PB mounts.
Following
What Steering column are you using
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
I’m actually using a oe tilt automatic column that I had rebuilt and painted. It’s an absolute beauty. 70ShortFleet did it.
http://67-72chevytrucks.com/vboard/a...1&d=1429143896 |
#5 | |
Hell yeah man it is gonna be sweet!
And I think I'm going to dump the LS idea & go fuel injected BBC and an AOD. Just has more "impact" when you pop the hood.
Hmm how about a LSX 454 them suckers are mean as hell.
#10 | |
![]() Join Date: Apr 2012
Are you copying me?
Chad 1967 Chevy C10 "Project DV8ED" 1994 Nissan 300zx convertible 2004 Chevy 2500HD crew cab 4x4 |
#12 | |
Loves all GMC trucks
![]() Join Date: Jul 2010
Ok... I'm in too!
Mike If your helping someone and expecting something in return... your doing business not kindness! |
love your plans, i will watch this one. Whats up with the front edge of the left front fender? looks like it was eaten or something? Ha
#15 |
Yeah, looks like the ole guy bumped it into something. I'm not going to "fix" it but I am going to try to straighten it out enough to put the trim piece back on it and fix the fender/hood gap.
#16 |
No real update, but instead of using the McGaughy big brake kit that I already have, I bought Wilwood 140-10776-d 6 piston front kit, Wilwood 140-10093-d 4 piston rear kit, CPP modular 2 inch drop spindle. I guess I'll put the McGaughy kits back on my GMC.
I may be able to finally answer Keith's (Lolife99) question about how the track width is affected by different spindles. I will have a set of stock 70 drum spindles, 72 disc spindles, 73 up spindles, McGaughy big brake spindles, 73 up McGaughy HD drop spindles, CPP new style (modular ???) HD drop spindles, and finally the modular drop spindles. I will probably just mock up a jig to do my measurements...damn installing & removing all these different spindles on a truck ![]() |
#17 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
#18 |
Hey Keith,
Any recommendation or insight on which balljoint is the "smaller" shaft upper & lower ball joints so I can throw them in an extra set of control arms that I have, so I can bolt all of the spindles in place on the same BJ. I figure even if they're a little small, it won't affect the measurement as long as it's tightened down...right? Any certain generation control arms that I should use? I probably have them all ![]() |
#19 |
Well just went through all your builds and have to say this is my favorite. In for the build.
Good looking mustang. The pic with all the parts reminds me of when I was living in Indy. My buddy and I swapped cars for the day. He took my coupe and I took his 90 LX. His car had no back seat, was a race car and bright Orange. I had to deliver some product that day for work. I had that car crammed full of home audio gear. The look on the client's face was priceless as I showed up in it and trying to get all the boxes out of the passenger seat, around the roll cage and out from under the nitrous tank.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#20 | |
Thanks ![]() Yeah, I've had a BUNCH of Fox body Mustangs over the course of the last 25 years. I'm confident (sorta, anyway) that this will be my last one though. It's a fun car, just not very practical, and I have plenty of impractical vehicles, so I may take it to a few shows this Spring and see if someone wants it more than me ![]() Here's a couple of gratuitous recent shots ![]() Last edited by nlped; 12-08-2014 at 09:22 AM. |
#21 |
Bought Wilwood 14" 6-piston front & 13" 4-piston rear brakes and a set of CPP modular drop spindles for this one
#22 |
Where did you buy your big brakes?
#23 | |
![]() I actually bought them from the parts board for a deep discount...and they are still brand new ![]() Last edited by nlped; 12-20-2014 at 09:19 PM. |
#24 |
Prestige Worldwide
![]() Join Date: Feb 2001
I will be following this one.... Can't wait to see that shop!
#25 |
Hey Jason,
Cool to have you following... And I'm so ready to get done with the concrete for the shop, but between the freak cold spell and all the d@mn rain, it's going to be at least another week before I can get that done ![]() And, thanks for the info on the PB bent trailing arm proto-type...I'm in for one as soon as Nate's ready to ship ![]() |
