2004 ls swap with 99 z28 cluster
I've been doing research on z28 cluster for my ls swap. My donor 04 Silverado cluster has a white engine speed wire and the 99 z28 cluster doesnt. I'm assuming that the tach signal comes from the serial data, I just wanted to confirm or someone point me in the right direction. I've seen the same combination used.
Re: 2004 ls swap with 99 z28 cluster
Here's what I got...99 z28 cluster
2004 4.8 drive by wire and 4l60e. I sent pcm to Brendan at lt1swap.com
Fabbed my own brackets for motor mounts
Just waiting for ups to deliver my fuel system and pcm. Hopefully I'll have it in this coming weekend or the following weekend.
A quick pic of the patient. ....lol
10" re audio in a down fire box housing the shifter and cup holders
My kick panels
Old member
My harness had the tach off the ECU direct. So yes it should. You may want to call the LS1 guys and make sure though.
Interested in the camaro cluster and how you plan to incorperate it into the dash if you have any pictures. Nice looking ride by the way! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Great looking project.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I'm shooting for this. I'm using another members idea.
http://67-72chevytrucks.com/vboard/s...7&goto=newpost
His gauge pics are on page 1 about half way down. He did an awesome job. |
Old member
Yes he did. Very nice. I like that look. I wonder how he mated it to the metal dash. Did he are you weld some bolts to the back side of the metal dash are what?
I have been thinking about redoing mine and counter sinking the gauges to slant up some to see them better while driving. ![]()
#14 | |
It's anchored to the original gauge housing with L-brackets and has a lexan face. |
#15 |
The members name is imsuchaman55 has been helping me with my wiring questions. He is the member I borrowed this gauge idea from.
#16 |
I've done the same with a 97 z28 cluster.
http://67-72chevytrucks.com/vboard/s...d.php?t=480075 |
#17 |
Here's the tach info if you still need it.
#18 |
93-97 z28 clusters use a tach wire and the 98-02 clusters use the serial data wire to drive the tach...at least that's what another member told me.
#19 |
Sounds right . Brendan's site has all the pinout info .
#20 |
Yeah...I wish someone had all the answers for this ls swap. Brendan has done a lot of good articles on this stuff but he has never used a Silverado or a z28 cluster for a swap. We've been emailing each other on this subject. I'm doing this thread for this reason. Everyone shows the finished product, but never documented the wires used or how they got what to work. I'll do my best to keep this thread going as I figure it out. I came across the resistor idea that you posted on a ls1 site I believe. If I could get all the answers on one thread that'd be great for someone else in the future. Thanks for the reply on what solved your problem.
#21 |
You're right it does from the the class 2 serial but not directly form the PCM . I would try it from the PCM though it might work . Pin 58 or 59 are the ones I'd try on the blue connector.
#22 |
Fuel system for the swap
#23 |
Verrrry interesting.... I wanna see what you come up with!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#24 |
![]() Join Date: Jun 2014
Why did you pick a 4.8 over some of the other LS motors?
Nice looking stepper. Cool idea with the cluster. |
#25 |
![]() Join Date: Nov 2012
I used an 02 Camaro cluster. Works great, I've got a lot of notes and pinouts if you need any info. Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
