08-22-2014, 02:05 PM | #1 |
Easy Does It
Rear end width change??
I thought I remember hearing that in 1970 they widened the rear end 1 1/2" wider than the 67-69 models, anyone know if this is true?? thanks
08-22-2014, 02:11 PM | #2 | |
The Older Generation
Re: Rear end width change??
Yes it is, 3/4" on each side. I think it was '71 though.... Someone will correct me if I'm wrong on the year. LockDoc
08-22-2014, 02:16 PM | #3 |
70 model c10 came wiith both 67-69 and 71-72 length rear ends but they are ALL 6 lug still. I have a long length 70 rear end 6 lug under my trailer
1967custom |
08-22-2014, 02:20 PM | #4 |
Full agreement with LockDoc's comments....it was widened in '71.
I believe the reason for this was that they introduced disc brakes onto the trucks in '71 and this disc brake assembly was wider than the previous front drum brakes. Again, to my understanding....they then made sure the rear track had the same width as the front. Like Lockdoc also said,....someone correct me if I'm wrong on this. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
08-22-2014, 02:26 PM | #5 |
Agree with Michael. I just put a wide 6 lug rear end from a '70 on my '67. I actually think some late '69's got the wide ones too.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
08-22-2014, 06:23 PM | #6 |
Registerd User
My 70 has the wide rear end.
08-22-2014, 06:42 PM | #7 |
i had heard this also. Then it dawned on me that i had had a 71 rear end overhauled for my 68 short step side.Now i think my wheels and tires are going to stick out. Anybody ever shortened the axel tube and then put in shorter inner axels? Is it possible to buy shorter inner axels? I could just put the 68 axel back in but i spent good $$$$$$ to have this one overhauled and turned into a 3.73 posi. many thanks in advance.
08-22-2014, 07:12 PM | #8 | |
08-22-2014, 09:12 PM | #9 |
Roadtrip!
I believe 70 was the change over. Early 70s were narrow.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-23-2014, 11:09 AM | #10 |
Too much stuff; Yes its wider because i measured it against the 68.
NC67Chev: My truck has 71 disc breaks. I cut the 71 frame off just before the vin # underneath the cab and grafted it to my 68 frame. this way i can retain the original vin# of the 68. I would really to use 295/50R/15's out back and still get them inside the fender. shortening the axel is no problem. i just was wondering if i can get shorter inner axels. Tks |
08-23-2014, 11:22 AM | #11 |
Wizo,
Companies like Moser will make axles in any width you need. CCP makes 5 lug axles for the 67-70 width axle housing so you have options.
Eric 68 Anniversary Gold C-20 LWB to C-10 SWB build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637492 It's hard to explain puns to kleptomaniacs because they always take things literally. |
08-23-2014, 12:28 PM | #12 |
Grip; i will google them. tks
08-24-2014, 12:26 PM | #13 |
does anyone have the dimentions of both? axle flange to axle flange
Thanks, Wes |
08-25-2014, 09:01 AM | #14 |
my leaf spring 70 was the wide one...when the ring and pinion went bad,i put in a 76 rear...and the 70 6-lug axles went right in
1970 short step c10 leaf spring 454 |
10-13-2014, 06:26 PM | #15 | |
Mine is 57" from backing plate to backing plate (at the bend in the tape. It's not that obvious in the picture).
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
12-17-2014, 07:12 PM | #16 | |
Reviving an old thread ... I didn't find an answer to this question from Wes. I want to order axles BEFORE I take them out of my 1970 GM corporate 12 bolt. I am preparing for the holidays ... Merry Christmas ... and don't have time to take it apart at the moment. How do I know if I have the shorter or the wider rear end? I will measure mine and post it later. Thanks in advance, Barry |
12-17-2014, 07:54 PM | #17 |
I bought my new dorman axles that have bearings with them for 102.00 an axle free shipping on ebay. outside of flange to end of axle is 31 5/16 . dorman number is 630-128 this is for the wider of the two rear axles.
12-17-2014, 08:11 PM | #18 | |
Looks like my question was not stated correctly (or at least it was stated poorly!). How can I tell if I have the narrow axle HOUSING or the wider axle HOUSING without removing the axle SHAFT and measuring it? Thanks! Barry |
12-17-2014, 08:26 PM | #19 |
Mine is 57" from flange to flange, not counting the width of the flange. I am calling the flange the place where the backing plate attaches.
Barry |
12-18-2014, 09:37 AM | #20 |
axle width is 55.5 wide with 30.5 long axles on the narrow rear end. earlier rear end
axle width is 57 wide with 31 5/16 long axles on the wider rear end. later rear end |
12-18-2014, 12:05 PM | #21 |
12-25-2014, 12:48 AM | #22 |
Where you measuring from..axle flange or backing plate.?
12-25-2014, 11:46 AM | #23 | |
10-11-2023, 02:09 PM | #24 |
Have late build 70 K10, (7-10-70) Janesville Wi. Rear is 1 1/2 inches narrower than front.
10-11-2023, 05:16 PM | #25 |
I found this out when I cannibalized the '67 rear-end from my '67 K/10 Suburban for my '71 GMC K/1500 Jimmy. Both were 3.73.
The shorter '67 rear [w/ Auburn Posi] was shoe-horned onto my '71 Jimmy. Running very nicely since 2010. The wider OEM '71 Eaton Posi rear which ''lunched'' is currently hanging under the '67 Sub, but we were unable to fit it completely on. There's some baling wire involved. Not a problem as the Sub is not a runner. It's a Someday Project. To resurrect the Sub, I would have to get the Eaton Posi rear rebuilt, then trade it out onto the Jimmy, and having pulled the Auburn Posi rear off the Jimmy, ire-nstall it on the Sub. Not happening anytime soon.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-12-2023 at 06:17 PM. |
