Old 09-19-2014, 07:17 PM   #1
JohnKimble
85 White Whale
Couldn't really come up with a catchy project name, but I figured it took so long to find a decent K10 for sale that I would just call it my white whale.
Took me about a year of casually browsing craigslist and the such. Found a 1985 K10, 350 engine, 700R4, maintenance records, automatic...almost exactly what I was looking for.
JohnKimble is offline   Reply With Quote
Old 09-19-2014, 07:19 PM   #2
dfrank
dfrank's Avatar
Re: 85 White Whale
Nice find!
dfrank is offline   Reply With Quote
Old 09-19-2014, 07:19 PM   #3
JohnKimble
Re: 85 White Whale
It did have some rust in the cab corners. After calling around for paint quotes...I realized I would either have to do it myself, or pay a fortune.
Time to buy some tools. Angle grinder, die grinder, 60 gallon compressor, and lots of stripping discs!
Old 09-19-2014, 07:22 PM   #4
JohnKimble
Re: 85 White Whale
I cut out the rust, sprayed it with a rust converter and cut a patch panel to size. I had the welding done locally as my flux core was just too hot.
Old 09-19-2014, 07:25 PM   #5
JohnKimble
Re: 85 White Whale
Cab panels repaired. Tie down holes welded up. Stripping of the truck has began!
Old 09-19-2014, 07:27 PM   #6
JohnKimble
Re: 85 White Whale
The front fender dent was just too big for me to mess with. The local pick and pull had a dent free fender that I grabbed. Took a solid hour to strip though. It must have had 7 layers of paint/primer on it.
New grille arrived too.
Old 09-19-2014, 07:37 PM   #7
JohnKimble
Re: 85 White Whale
Using aircraft remover for the bed, along with a wire wheel and stripping discs. The aircraft remover is messy stuff, but works well.
Old 09-19-2014, 07:40 PM   #8
JohnKimble
Re: 85 White Whale
Pulled the front and rear bumper today, as well as the tailgate. Going to order some new hardware for the tailgate.
Old 09-19-2014, 07:47 PM   #9
JohnKimble
Re: 85 White Whale
I also bought some flush mount reverse lights for the rear bumper. I'm planning on stripping the entire bumper and painting it argent silver (including the lights).
Old 06-13-2016, 11:20 PM   #10
Matt Man
Matt Man's Avatar
Re: 85 White Whale
Any updates? Don't feel bad about the rusty cab corners, I had one fixed as well.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-14-2016, 12:19 AM   #11
JohnKimble
Re: 85 White Whale
I'll update this weekend with pictures. It's literally been sitting in my garage collecting dust for the past 2 years, until today. Pulled it out, put in a new battery and got it running. Pulled both front and rear windows. Pulled the taillights, front and rear bumper, grille, side mirrors and am prepping for Primer.
Hoping to have it in epoxy primer this Saturday.
Old 06-14-2016, 01:23 AM   #12
MTCK
MTCK's Avatar
Re: 85 White Whale
Great revival! Quiet for two years and BAM. I have the exact same backup lights for my crew and plow truck but haven't installed either set yet. Put a pair in my dad's 2500HD and they are BRIGHT. On his truck I have them wired to come on with the backup lights and ability to disable with a switch. I would consider doing this with any install or risk blinding everybody backing out of the grocery store parking spot.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-18-2016, 10:20 PM   #13
JohnKimble
Re: 85 White Whale
So I was able to get the truck into epoxy primer today. Two coats laid down without much issue. I think if my base and clear lay down that well I'll have my work cut out for me.
Old 06-18-2016, 10:32 PM   #14
Greenlee
Greenlee's Avatar
Re: 85 White Whale
Looks good. Nice work!
Greenlee is offline   Reply With Quote
Old 06-19-2016, 04:38 PM   #15
LT7A
Re: 85 White Whale
Sounds like just the thing to discourage tailgaters
JK, the truck and and primer are looking good. Glad you are able to get back to it.
LT7A is online now   Reply With Quote
Old 06-24-2016, 11:40 PM   #16
JohnKimble
Re: 85 White Whale
Onto the body filler...
Old 06-26-2016, 02:20 PM   #17
Matt Man
Matt Man's Avatar
Re: 85 White Whale
Looking good! You going to keep it white?
Old 06-26-2016, 02:24 PM   #18
JohnKimble
Re: 85 White Whale
Yeah I'm going to stick with the factory frost white. Dealing with door jambs is too much for me. Also white will help cover all my bodywork errors.
Old 06-26-2016, 04:40 PM   #19
ironroad9c1
Master Hater
Re: 85 White Whale
Nice work.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 06-27-2016, 01:47 AM   #20
JohnKimble
Re: 85 White Whale
Epoxy primed the door jambs, tailgate, and made the cutouts for the reverse lights.
Old 07-10-2016, 06:52 PM   #21
JohnKimble
Re: 85 White Whale
More body work this weekend. Hoping to have it in high build primer by tomorrow.
Old 07-11-2016, 09:48 PM   #22
JohnKimble
Re: 85 White Whale
More sanding, sanding, and then a little sanding. Followed by two heavy coats of urethane primer.
Old 08-15-2016, 10:05 PM   #23
JohnKimble
Re: 85 White Whale
Painted it today. Went with SPI pure clean white single stage.
Old 08-16-2016, 08:29 AM   #24
Jaysonb
Jaysonb's Avatar
Re: 85 White Whale
Looks good! I bet you're excited to get it put back together.
Jaysonb is offline   Reply With Quote
Old 08-16-2016, 08:51 AM   #25
Sik66
Re: 85 White Whale
Nice job!.....gotta be happy with that!
Sik66 is offline   Reply With Quote
