09-29-2014, 09:23 PM | #1 |
how to bring it back to life?
Ok experts I need advice. I was given a 72 c10 that has been sitting in a garage for almost 20 years. To my knowledge it ran when when parked but hasn't been started since it was parked. My thought are to change oil and coolant, pull plugs and squirt some oil sown in the cylinders. After that turn it over by hand, prime oil system with a drill, add fresh gas, and see if it will start. Outside these steps is there anything I should do to make sure I don't injure this thing. Once I have it started I will put fresh fluid I. The trans, differential, check the brakes and see if it will drive around the block
The truck is a 350ci / th350 |
09-29-2014, 09:29 PM | #2 |
Re: how to bring it back to life?
Congrats! Pics! Don't drive around the block right away. Hundreds of things could be wrong with it. Take it slow. Vehicles that have been sitting may seem tempting to drive but you must be safe. Small trips across the yard - up and down the driveway- an occasional hard stop to make sure the brakes work etc. No traffic driving til your sure it's worthy!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-29-2014, 09:55 PM | #3 |
I'd expand the oil in the cylinder trick a bit. Do it over several days. A little oil (marvel mystery oil works good), turn it a quarter turn, more oil, let sit, repeat over the next 4 days.
Also put new points in it. |
09-29-2014, 09:56 PM | #4 |
Here's what I would do. Others may not.
1) Remove plugs, all fluids, carb, etc. You'll likely need to go through the carb anyway 2) Shoot liquid wrench or your favorite product into each cylinder 3) Wait. Up to a week, but overnight is usually ok. 4) Gently see if you can break it free just a tiny amount. If not, go to (2) 5) Once it moves a little (like the piston less than 1/4"), go to (2) 6) Repeat until you've had each piston up and down the bore like this You might well find that once it's broken free it goes pretty easy, but I'd still take a few intermediate steps because the most rust will be where the rings are, and you need to come back at it from the other direction too, and there are 8 pistons in 4 different spots, so you almost have to go all the way around once like this to cover everything. Drain the fuel tank, clean the lines, all of the other stuff that's pretty common for bringing old cars back.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
09-29-2014, 09:56 PM | #5 |
Sorry, posted at the same time as Geezer. At least it was the same advice. Now if we can get buyin from mechanicalman on the stepped break-free we'll have the trifecta of advice!
09-30-2014, 09:51 AM | #6 | |
Here are pics of my new baby Last edited by bigun911; 09-30-2014 at 09:57 AM. |
09-30-2014, 10:36 AM | #7 |
Vintage 4x4s
wow, you were given a survivor truck !!
I would also siphon out all old gas, install new non oxy with lead substitute, pull line to carb and flush out line. Insp ect and replace rubber fuel lines.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
09-30-2014, 10:42 AM | #8 |
Easy Does It
wow in great shape, nice find ! one thing I would add a few fuel filters one before the pump and one in between the pump and carb. there is sediment in the tank from sitting so long and its hard to clean out unless you get a new gas tank..
09-30-2014, 11:33 AM | #9 |
I'd drain and remove the gas tank (easy job really) and look for flash rust. My tank was full of it after sitting 20 years.
09-30-2014, 12:01 PM | #10 |
I agree with everything said. Something like points doesn't NEED to be changed to get the engine to turn over necessarily, but it is a good idea. It's easy to know if you're getting spark if you pull a plug wire. Draining the tank is a really good idea as well. It's cheap insurance. If you don't want to drain it, put an extra fuel filter or two in it at least or you'll be rebuilding the carb possibly twice if you do it before you start the truck.
If none of that works call Dr. Frankenstein and set up an appointment around the time of the next lightning storm in your area. He'll get it going for you |
09-30-2014, 04:57 PM | #11 |
If you don't speak Transylvanian, get a new battery.
09-30-2014, 06:56 PM | #12 |
Looks like a nice rig. You're a lucky man! 5 lug too! We need some pics of the engine.
09-30-2014, 07:08 PM | #13 | |
AHA you didn't see that coming, did you? LOL I think you guys got it covered. |
09-30-2014, 07:17 PM | #14 |
Very nice gift!
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
09-30-2014, 08:48 PM | #15 |
Try the marine lay-up oil fogging and let that perculate a couple days, API. The oil pump, see if it spins, etc.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
10-01-2014, 09:10 AM | #16 |
Got a chance to look it over a little bit better last night. The paint doesnt look original as there is some pretty bad overspray in some places. I also pulled the dip sticks to get an idea what I was dealing with. Oil looked a little dark but not sludgy, it will still get drained before I attempt to do anything with the motor. The trans fluid was bright red and smelled very clean with no evidence of burning or overheating.
Now another question, will I hurt the transmission by starting the engine with the old fluid still in the trans? here are a few more pics, Engine as requested, and a few more for anyone curious |
10-01-2014, 10:28 AM | #17 |
The dark oil is good. It's supposed to be as it cleans the engine. If you roll it over by hand your transmission front seal will have an opportunity to exercise a little before being spun up. I would plan on changing all the fluids soon, but your tranny should be ok for a while as long as it's full.
Jeff
10-01-2014, 10:37 AM | #18 |
x 2 on the trans it will be fine very nice rig
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
10-01-2014, 01:03 PM | #19 | |
If turning over the engine IS a problem, and it's apparent you will have to work hard to get it to turn free, then change the oil, remove the distributor, and pump up the oil pressure with a sleeve-bodied oil primer device (some parts stores rent or loan them out). I made mine out of my old points distributor leaving only the main shaft in without a gear and welded an old 3/8 socket to the top of the shaft. Seriously, you can pump it up with an air ratchet or speed wrench. If you use just a large screwdriver blade, you have to turn it fast due to pressure leakage and it takes forever to get oil to the top end that way. If turning the engine is NOT a problem you don't need to remove the distributor (as I think it won't be but do lube the rings before you change the oil), after you drain the engine oil, install the oil filter (primed full of oil), with the spark plugs out and the coil wire removed, the pistons moving freely without compression, you should be able to crank it over until the oil light goes out or you can see the oil pressure gauge start to register, and that is good enough. Set the new points with a feeler gauge then after the engine is running engage the trans in forward and reverse, the in park check the fluid but don't add any unless it's over a quart low and then leave it a little low, then set the points with a dwell meter if you have one. After the engine is all the way up to temperature and you have driven it around, top off the transmission. Oh, BTW, expect that cylinder lube to come shooting out leaving an oily mess, some old towels or be linen strategically placed will help immensely. This is a step you DON'T want to forget, if you leave too much liquid in the cylinders you can bend a rod/s. |
10-01-2014, 08:56 PM | #20 | |
My advice...sell it to me
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
10-02-2014, 02:56 AM | #21 |
Jealous. That thing is pretty nice. Not even a torn seat. Any rust?
10-02-2014, 08:34 AM | #22 |
Just by looking at the condition of the rest of the truck I highly doubt you will have any trouble with the engine , Don't rebuild the carb or change the timing no new wires no new plugs don't clean it or anything else start it from where it sits now ! doing repairs first leaves you with no idea where to start looking for problems you may have caused .if it's not broke don't fix it before you know you have a running smoke free engine !
Pull the plugs and use MARVEL MYSTERY OIL in the cylinders overnite, think spray bottle not a funnel and DON"T fill the cylinders !Then turn it by hand , change the oil and filter , and place the largest Magnet you have close to the oil pan drain and 1 on the filter to catch free floating metal/rust from condensation use the old plugs on first start . after you start it and yes there will be some after sitting so long once started don't rev the engine hard to try to keep it running it will smoke like crazy from the cylinder lube but it should run and idle ok enough to let it get warmed and circulate the fresh oil and clear out the lube I would run it for 15-30 minutes watching the temp and pressure gauges then stop the engine and let it sit for an hour to drain back into the pan then pull the magnets and change the oil and filter again , I'm sure you will be fine after that and that first run up will be the indicator of what you have in store in repairs Last edited by Grumpy old man; 10-02-2014 at 08:41 AM. |
10-03-2014, 09:41 AM | #23 | |
Next question, Oiled the cylinders and am working on getting the motor to spin by hand, thought it was gonna be an easy one but was only able to get about a quarter turn out of it before it stopped. I re oiled at the stopped position and hope that works to loosen whatever is stopping engine rotation, but if it doesnt I am trying to determine my next move. It seemed to spin both directions from where it was stopped but only about an eighth turn each direction. Is it possible that a valve or valves is rusted to the seat and preventing rotation? If so could I pull the valve covers and gently tap each valve / rocker to see if I can free them? Please forgive my hesitance to not consult the experts before pushing forward, I have been working on cars for years but never really done anything like this and I don't want to hurt anything worse trying to fix it. |
10-03-2014, 10:03 AM | #24 |
Are you using regular oil to loosen it up ? Oil and Marvel mystery oil are 2 different animals .regular engine oil will do NOTHING to loosen the engine ,yes you can pull the valve covers and again use the Marvel oil to clean and lube them ,i don't suggest you start tapping valves ! Are you using a breaker bar and socket on the crank bolt to try to turn the engine ? Are all the plugs out ? loosen the distributor cap (just the cap not the distributor hold down ) and move it out of the way to see if the rotor is moving when you try to turn the crank .We'll go from there once you try it .
Oil is a lubricant Marvel mystery oil is more of a solvent based fluid 74% mineral oil 24 % stoddard solvent and 1% lard ,Yes that's right LARD ! OLD GUY"S RULE ! |
10-03-2014, 10:16 AM | #25 | |
