07-27-2016, 08:09 PM | #1 | |
SAVING ONE TRUCK AT A TIME
Re: My 1961 crew cab- XRMYCRU
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
07-29-2016, 08:39 AM | #2 |
the roof laid out nice. I like your approach... do a little and walk away from it.
the rocker repair looks very good, nice progress. |
07-27-2016, 12:42 AM | #3 |
1961 crewcab
well today I finally got started on the roof.
this might be a couple week process. I looked at some tips on how to do it, and it seems like I need to put down the spots by all the clamps, then grind the spot, and then put down another right next to it, and so on... I think I will try to do an hour each day after work, that should help keep the heat down and not warp it. today I laid down all the spots, pulled the clamps, and got 1/2 of them ground.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-27-2016, 06:14 AM | #4 |
Check The Champ, Demonstrator
A painstaking task. has to be done.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-27-2016, 03:00 PM | #5 |
I usually start off that way, with good intensions... then I loose patients and weld too much at once. Take your time and it will be much easier.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera |
07-27-2016, 06:45 PM | #6 |
1961 crewcab
me too! that's why I plan to just weld and grind one set of spots a day. hopefully that will keep me from warping it.
07-29-2016, 10:51 AM | #7 |
Did you pre-curve the skin or pull it down into the drip real, clamp it with vice grips?
Looks straight. Looks nice. |
07-29-2016, 06:12 PM | #8 |
1961 crewcab
we ran it through a roller to give it some curve, then I also rolled it over an oxygen bottle to curve it some more and fit a little better.
08-04-2016, 01:44 PM | #9 |
1961 crewcab
got it all welded up!
I had a friend come by today and we did a little bit of work with a pin pull gun and fixed a couple high/low spots. now it is ready for mud!
08-04-2016, 06:05 PM | #10 |
Very nice Jon!
08-04-2016, 09:39 PM | #11 |
So AWESOME!!
CHEVY ONLY |
08-04-2016, 09:48 PM | #12 |
Man really starting to come together.
Have you seen any versions with a panel/suburban roof, you know domed higher at the front?
08-04-2016, 10:35 PM | #13 |
1961 crewcab
yes, a couple, the flatter roof looks better IMO.
08-05-2016, 01:25 AM | #14 |
60-66 Nut
This is good to hear and see
08-05-2016, 11:10 AM | #15 |
Great job, all nice and flat.
08-07-2016, 07:54 PM | #16 |
1961 crewcab
on to making the 60-62 cab compatible with a 63-66 frame:
I cut up some mounts I had laying around from a 65 to see how they were built. under the support washer and floor pan is a brace to keep the floor from collapsing when you torque the cab down. these were all rusted, so I decided to just make some- I got a piece of thick sheet metal 4.5X 1 5/8 , I bent the ends at 90 degrees, then I used the vise a socket and some angle iron to bend it into shape.
08-07-2016, 08:02 PM | #17 |
1961 crewcab
I took some measurements off a 65 using the seat mount holes to triangulate the inboard holes. I drilled all the way through, then made the upper hole bigger to go around the support washer indentation, then used a 5/8 hole saw for the lower hole.
since I couldn't weld the support in the brace like the factory did, I just welded it to the washer , then welded the washer to the floor.
08-07-2016, 10:11 PM | #18 |
Looks good. We Replaced the cab mounts so we were able to weld a piece of pipe in it. Roof looks great. CHIZZLER
08-23-2016, 11:57 PM | #19 |
1961 crewcab
Getting the firewall ready so I can get the cab on the frame.
I had Captain Fab modify one of his 60-62 power brake booster brackets to work with a 63-66 pedal assembly. I had to trim the pedal assembly a bit to fit around the provision for the hydraulic clutch on the firewall. this fire wall (from a 60 series) did not have a provision to mount the steering column at the firewall- on a 60 series there is a bolt on piece to mount the column low, and the upper piece is trimmed off- So I cut up a bolt on piece from a 63-66, and welded the piece in place.
08-24-2016, 01:53 AM | #20 |
Beauty Job! I'm no stranger to the difficulties of the working the firewall around the steering column, my sympathies! Your rig is awesome! I can't wait to put my hands on a 60-63 crew definetly next on the project list, the panel is getting finished first hahaha
08-25-2016, 11:51 PM | #21 |
1961 crewcab
I got the cab on the frame today!
my friend that helped with putting the cab on also brought by a bunch of bodywork supplies, and helped for about 4 hours getting me started on doing the roof.
08-26-2016, 05:13 AM | #22 |
Looking good!
08-26-2016, 06:15 PM | #23 |
Looking great jon. I can't wait to see this thing together. Roof looks good.
08-27-2016, 01:56 AM | #24 |
Looks awesome
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
08-27-2016, 07:36 AM | #25 |
One foot in front of the other
Congrats. Looking good.
