Old 11-15-2014, 01:08 PM   #1
yoshi
yoshi's Avatar
Engine run 1st time for me, now issues
Finally got my engine (sbc350 1977) started today. I have some issues that I'm not sure if related. 1st off the engine gets hot real quick even with fan running & an external industrial fan used for removing welding fumes in confined spaces. We checked the thermostat, pulled it out while still quite hot & it was open & slowly closed while cooling down. It could be as simple as the radiator blocked. Also there is low vacuum pressure about 5 bar. We believe a new mild cam has been fitted. It's a little lumpier than a standard engine would run. What would cause a low vacuum reading?
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 11-15-2014, 02:25 PM   #2
nvrdone
Re: Engine run 1st time for me, now issues
Check your timing. If timing is off it will cause low vacuum and hot running
nvrdone is offline   Reply With Quote
Old 11-15-2014, 02:41 PM   #3
57chevyman
57chevyman's Avatar
I have the same engine . I thought it was running hot, but turned out that the temp gauge wasn't grounded properly. ( I have an aftermarket temp gauge ). Just want to make sure the engine is definitely running hot before fixing it!
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 11-15-2014, 03:02 PM   #4
yoshi
yoshi's Avatar
1949 chevy 3100 truck: 1st run-Our 49 3100 chevy truck: http://youtu.be/S4oyeQrtClA
2nd run-
http://youtu.be/bb4hjT5sBx8 its also breathing
yoshi's 49 project
Old 11-15-2014, 03:12 PM   #5
OrrieG
OrrieG's Avatar
Make sure you do not have an air bubble in the radiator or cooling system too. "lumpier" could be a vacuum leak, not big cam. It takes a pretty radical cam to reduce the vacuum that much.
Make sure all the fittings, hose to booster, trans, etc. are not leaking. Check the carb for uncapped ports and good gasket seal. I would also play with the timing as suggested, in the old days the vacuum gauge was used to set timing. Since it appears to be holding steady in the video probably not valve adjustment, etc.
Old 11-15-2014, 04:05 PM   #6
yoshi
yoshi's Avatar
Yeah I believe some cams are that radical the booster needs a vacuum tank. Valve adjustment was the 1st thing he did before we ran the engine. He thinks that the timing could be 1 tooth out
yoshi's 49 project
Old 11-16-2014, 07:05 AM   #7
yoshi
yoshi's Avatar
Can I check cam timing with engine in place? I'm thinking of removing rad & flushing through.What's the best way to not get air trapped when refilling cooling system?
yoshi's 49 project
Old 11-16-2014, 10:10 AM   #8
Speedbumpauto
Speedbumpauto's Avatar
Remove the heater hose or plug from the intake manifold and fill until the coolant reaches the fitting. Replace the hose/plug and continue filling until full. Don't believe the engine would run or idle that well IF it was a tooth off. Don't think that can be your problem. Sounds lazy, like retarded timing. One thing you can check is TDC #1 with the timing pointer. It's the most important thing where timing is concerned. Make sure the external timing light info you get is accurate.
Speedbumpauto is offline   Reply With Quote
Old 11-17-2014, 10:56 AM   #9
xaircav
xaircav's Avatar
Same thing happened to me with my Omega Kustom gauges. Omega tech told me to add a resistor to the sending unit wire and all was well. The other guys who mentioned timing are correct. If you have a replacement balancer or timing cover the marks may not be accurate.
xaircav is offline   Reply With Quote
Old 11-17-2014, 12:07 PM   #10
mr48chev
mr48chev's Avatar
Running hot HOW?
What temp reading did you have?
Was it puking coolant?
Or did it just feel too hot to the touch?
Some setups are prone to getting air pockets in the engine as Orrie suggested and the rest of his suggestions are well worth following.
Check the timing with a timing light to make sure it is correct. Late timing will cause the engine to overheat. I ran into that big time on my 51 Merc with an Olds 350 in it after we did a points change just before a road trip and didn't put the timing light on it as it started great and sounded great.
If you are running an electric gauge make sure that it is accurate. My buddy"s Model A roadster with a 350 in it would show 265 degrees on the gauge but he was able to pull the radiator cap off without spewing any steam or hot water. The actual Temp in the top of the radiator was right at the rating of the thermostat in the engine when checked with a probe type thermometer.
Also I've seen way too many guys with old rigs with newer engines panic when the gauge gets up to 185 or 190 when a newer engine is just up to operating temp because the reading seems "way high" to them.
My ongoing truck projects:
Old 11-17-2014, 12:29 PM   #11
yoshi
yoshi's Avatar
Hired hand with me had the timing gun setting it up, temp was 220*
yoshi's 49 project
Old 11-17-2014, 01:14 PM   #12
_Ogre
_Ogre's Avatar
yoshi how are you checking the temperature?
our trucks don't have temp readings on them just h and c on the gauges
try an ir thermometer right at the thermostat housing
shop air compressor timer
Old 11-17-2014, 01:26 PM   #13
yoshi
yoshi's Avatar
We used a hand held digital laser thermometer
yoshi's 49 project
Old 11-17-2014, 04:51 PM   #14
OrrieG
OrrieG's Avatar
In the open radiator reading the fluid temp or shooting at the block radiator? I would hook up a known accurate gauge and check it, I'd bet the external engine metal temp is reading hotter than the fluid. I run mine out of the head behind #1 plug which reads 10-15 degrees hotter than the intake maniford water jacket port. Sitting at 220 would not panic me, I have driven SBC across Arizona and Texas at the temperature for hours with no problems. With 50% coolant the boiling temp goes up to about 235-240 when the system is sealed and pressurized.
Old 11-17-2014, 05:03 PM   #15
yoshi
yoshi's Avatar
Ok so if I check the cap & it's a low number I'll replace that, I'm gonna move the fan to the inside of the rad & pull the air through. I'll check everything else. I'll check out all the vapour hoses for leaks & I'll check that plug No.1 is at TDC & where the marker is. 'm not sure when that'll be so be patient. What would cause the heavy breathing?
yoshi's 49 project
Old 11-17-2014, 05:55 PM   #16
Highsider
Highsider's Avatar
My TF with a mild 350, stock brass radiator, 190 thermostat, manual-activated electric fan (so off), if I am moving I get an indicated (SW) temp reading of 190.
Based on Orrie, last spring I stopped worrying when the gauge went up to near 220, when slowing down for traffic. Then I would turn on the fan.
Good luck yoshi. I enjoy your posts.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 11-17-2014, 06:07 PM   #17
yoshi
yoshi's Avatar
Thanks highsider, didn't know anything about these 3100's & sbc's but I'm learning, thanks to these guys
yoshi's 49 project
Old 11-17-2014, 07:06 PM   #18
geezer#99
geezer#99's Avatar
I can't be sure in your pics but it doesn't look like you have a heater core hooked up or a bypass from the intake back to the pump.
Without either you'll keep running hot.
Here's a link on tdc.
You can make a piston stop from an old sparkplug too.
http://www.crankshaftcoalition.com/w...op_dead_center
Old 11-17-2014, 07:11 PM   #19
yoshi
yoshi's Avatar
No heater, where 's this bypass hose go, from water pump to? Thanks
yoshi's 49 project
Old 11-17-2014, 07:17 PM   #20
geezer#99
geezer#99's Avatar
From intake to water pump.
There's a discussion in this thread plus some pics on post #82.
http://67-72chevytrucks.com/vboard/s...=649618&page=4
Old 11-17-2014, 07:21 PM   #21
yoshi
yoshi's Avatar
Ah i see thanks, 3/8 npt both ends?
yoshi's 49 project
Old 11-17-2014, 07:33 PM   #22
geezer#99
geezer#99's Avatar
I think so but don't quote me on that!! LOL!!
You don't need to do it exactly like in the pic. You can loop a longer hose out past the valve cover and back to the water pump.
FWIW it did sound like your timing is retarded too!
Old 11-17-2014, 07:39 PM   #23
yoshi
yoshi's Avatar
What do I need to do to correct that? Thanks
yoshi's 49 project
Old 11-17-2014, 07:48 PM   #24
geezer#99
geezer#99's Avatar
First prove your timing marks are correct. That link I gave you will help.
Then set your timing at 12 initial to start.
Depending on the type of cam you have, you might need even more timing.
Do you know how to set your initial timing?
What are you running for a dizzy?
What other specs on your motor?
Old 11-17-2014, 07:53 PM   #25
yoshi
yoshi's Avatar
That hired hand in the video did all that. Builds/repairs petrol & diesel American engines. All his work is via recommendation/word of mouth, well known round here, knows his stuff. I'll check TDC & let you know
yoshi's 49 project
