Old 03-30-2015, 11:29 AM   #1
WarMonger
WarMonger's Avatar
temp gauge
How can I test my temp gauge to see if it is working? I don't know if its the gauge or sending unit, but it never moves.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 03-30-2015, 12:54 PM   #2
nzc10
nzc10's Avatar
Re: temp gauge
With the key on pull the temp gauge wire off the sender and earth it out on the engine check if the gauge is full over to the hot side on the needle if so the gauge is ok if the needle on the gauge is stuck on cold the gauge could be stuffed as long there's no break in the wiring
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
Old 03-30-2015, 12:56 PM   #3
WarMonger
WarMonger's Avatar
Re: temp gauge
Thank you.
1970 C20
-_--_--_- ______
1972 K5
Old 03-30-2015, 01:18 PM   #4
nzc10
nzc10's Avatar
Re: temp gauge
No worries hope you can sort it out, nice to see you like 2 wheels as well
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
Old 07-21-2015, 04:36 PM   #5
centuryhouse
centuryhouse's Avatar
Re: temp gauge
May I add one question? It seems wasteful to start an entire new thread for this one question...
Can anyone advise on what wires should be connected to the temp gauage? The green one coming from the sender on the block, but what else? Is there anything else that should be plugged in to the back of the temp gauge?
centuryhouse is offline   Reply With Quote
Old 07-21-2015, 04:54 PM   #6
WarMonger
WarMonger's Avatar
Re: temp gauge
Should just be the green wire.
1970 C20
-_--_--_- ______
1972 K5
Old 07-21-2015, 05:12 PM   #7
centuryhouse
Re: temp gauge
No power? Or is the power straight from being connected to the board?
Old 07-21-2015, 05:43 PM   #8
Jurassic-1
Jurassic-1's Avatar
Re: temp gauge
It is a ground wire there is no power at the sender. You can ground it and the gauge will move up.
Jurassic-1 is offline   Reply With Quote
Old 07-21-2015, 05:51 PM   #9
centuryhouse
Re: temp gauge
Sorry, I'm asking about the gauge. If a ground wire goes to it, I assume a power wire must as well. But my gauge has no wires going to it other than the green sender wire.
Old 07-21-2015, 06:56 PM   #10
Sklptrljay
Sklptrljay's Avatar
Re: temp gauge
The gauge is reading resistance between the sender and the ground (engine). That is why when you touch the wire at the sender directly to the engine, the gauge should read full hot, because it has no resistance.
Yes, the gauge itself is wired to the printed circuit. The green wire (gauge terminal) goes to the sender and the other gauge terminal is to 12v.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 07-21-2015, 09:13 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: temp gauge
Here's a dash gauge wiring layout. The purple lines feed the fuel gauge and the temp gauge from terminal 3 on the cluster plug. The wire from the temp sender runs from the sender to the no.6 terminal on the cluster plug. The green line feeds the gauge. There are no wires to the gauges.
Name:  Dash  Layout Final.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-21-2015, 10:06 PM   #12
centuryhouse
Re: temp gauge
Hmm. If there are no wires to the gauge, why are there four posts with nuts on the back of the temp gauge?
Old 07-22-2015, 09:12 AM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: temp gauge
Those are for connecting a resistor between the needle coils inside the gauge to prevent them from burning out by the 12 volts applied.
VetteVet
Old 07-22-2015, 09:48 AM   #14
centuryhouse
Re: temp gauge
But the sending unit wire doesn't connect to anything? Does it connect to the gauge through the circuit board via pin #6?
If so, that's what I've been missing. I was looking for the sender wire to be connecting to the post.
Old 07-22-2015, 10:57 AM   #15
Davidf
Re: temp gauge
Yes, per the wire diagram (post #11) the sending wire connects to the cluster wire connector (pin #6) then to the gauge via the printed circuit "board". Make sure the printed circuit trace is not broken (either or both sending and power).
Davidf is offline   Reply With Quote
Old 07-22-2015, 11:02 AM   #16
centuryhouse
Re: temp gauge
Good info, thanks! All looks good, and I just did the test that was mentioned of touching the sending unit wire to the block - when I did it pegged the Temp gauge needle, so I now know the connections are all good.
Old 07-22-2015, 03:55 PM   #17
moon
moon's Avatar
Re: temp gauge
SO, when I touch my properly grounded test light to the #3 purple feed pin on the connector, the test light should go on.... right? And if so; in what ignition key position ---> ignition on? ... accessory on?... both?.. with engine running on or off?
Both my temp gauge (new) & gas (original) don't work & appear to be "dead" & I've been messing with this for toooo long....
1970 CST long bed Fleetside
moon is offline   Reply With Quote
Old 07-22-2015, 04:00 PM   #18
Davidf
Re: temp gauge
Yes, it seems that #3 would have power with the key in the run position only. But, I would need to check my factory wire diagram which is not handy at the moment. If you don't get 12v at the wire pigtail contact, then this would explain a non function temp and fuel gauge as they both get power from terminal #3.
Old 07-22-2015, 06:57 PM   #19
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: temp gauge
The pink ignition wire from the key switch runs to a junction with three other wires as shown in the first diagram. It is the 5th wire from the top. These diagrams are for the charging light cluster but the pink wire are the same. On the cluster plug for the charging light the pink wire runs to terminal 7.
Name:  Copy of Cab-2-web PANEL LIGHTS 2.jpg
It runs to the fuse panel to power the cluster pnl fuse.
[ATTACH]Name:  Cab-1web 1.JPG
Size:  97.0 KB[/ATTACH]
From the fuse panel it runs to the cluster plug to terminal 3 and becomes hot when the key is turned on.
VetteVet
Old 07-22-2015, 10:27 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
Re: temp gauge
I went through all of the trials and tribulations of trying to get my temp gauge working a while back. Turns out that none of the over the counter parts store sending units have the right resistance. I bought one of these and now it works like a champ.
http://www.ebay.com/itm/NEW-gauge-te...638874&vxp=mtr
WIDESIDE72 is offline   Reply With Quote
Old 07-23-2015, 10:53 AM   #21
centuryhouse
Re: temp gauge
That isn't the connector type my temp sender has. What does the other end of this (the wire end that connects to this sender) look like?
Old 07-23-2015, 11:40 AM   #22
WIDESIDE72
WIDESIDE72's Avatar
Re: temp gauge
The wiring connector is a spade connector. It slides on at a 90 degree andle instead of straight on lie you are probably used to seeing.
Old 07-23-2015, 01:11 PM   #23
centuryhouse
Re: temp gauge
Excellent, thanks. I've been having problems finding an appropriate replacement (with the smaller 3/8" threading) that has a straight tab type like mine. It sounds like I could use this type and just replace the wire end with a 'spade' type connector.
Old 07-23-2015, 04:48 PM   #24
moon
moon's Avatar
Re: temp gauge
Thank you for your help!
I checked the plug terminal (disconnected from the panel) with my test light & do NOT get power at the #3 pin. But I DO get power at the cluster pin, when the headlight switch is pulled on.
I'm having difficulty following the schematics: I'm not seeing the "junction" you mentioned where the pink wire & two others run to. Also a bit confused with pink wire vs purple wire.
I have a '70 C10 CST. The #3 wire in my terminal is pink(ish.) All the wires coming from the ignition switch are bundled/taped together and lead up, over & down to the top of my fuse box, appearing to run down behind it. The pink wire coming out of the connector on the firewall side of the fuse box runs to the starter.
If The pink wire powers the cluster lights (as it should) but is not powering the #3 pin, where should I look to find the break?
Also: I don't know if this is related (doubtful?) but my altimeter reads backwards --> When the headlights are on without the engine running the needles leans right to "C." When I start the engine running, the needle leans left to "D" then after eventually returns to the center line.
Here are some shots of what I'm dealing with:
IMG_0053 by moon, on Flickr
IMG_0051 by moon, on Flickr
IMG_0049 by moon, on Flickr
Old 08-04-2015, 08:31 PM   #25
Phildeez
Phildeez's Avatar
Re: temp gauge
I'm in need of a little help on the subject too. My gauge only rises to the second line of the cold zone and fluctuates down and back up to the same point. I've tested my gauge by grounding it and it goes to hot. I've got a reading of 333 ohms after a it is warm and the gauge is still just off the first cold line. According to a resistance/temp chart it was right around 175-180 degrees. Any help would be appreciated.
Phildeez is offline   Reply With Quote
