Old 04-18-2015, 10:09 PM   #1
65standard
65standard's Avatar
A different approach to a LWB to SWB conversion
Since I needed to pull the bed on my 1970 C20 to do cab corners, I decided to make it a short bed too. My approach is different than the conversions I see most doing on this site. As a metal shaper, we are taught to plan out our cuts and splices to ease fabrication, save time, and avoid frustration later on. So I came up with a better idea to make cuts and seams easier to do and keep the original paint, well most of it. Here is my plan:
Before:
First remove the bed. I just cut all 8 bolts and unplugged the rear harness.
Remove 8" from rear of frame rails and move the slot on top forward too.
Then remove the front most bed mounting bracket.
Then remove the front rivet of the second bracket and swing out of way. Then mark the cut. I went from the front rivet hole of the front bracket to the front rivet hole of the second brackets.
Then I unbolted the trailing arms from the crossmember, removed all rivets from crossmember and slid it forward 12". I welded in place. Then I cut the frame rails.
To be continued...
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 04-18-2015, 11:41 PM   #2
cooperhw
cooperhw's Avatar
Re: A different approach to a LWB to SWB conversion
Interesting.
More than one way to skin a cat.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-18-2015, 11:44 PM   #3
dacavy
I shortened the frame right behind the cab just like you did. The only difference was I put a 2" step notch. Sure makes it easier if you dont want to pull the cab off.
dacavy is offline   Reply With Quote
Old 04-18-2015, 11:53 PM   #4
dacavy
My cut behind the cab
Old 04-19-2015, 08:56 AM   #5
65standard
65standard's Avatar
Then I carefully aligned the rails and tack welded them together.
Next did a full penn weld and ground it down so it could be tested. Then swung the bed mounts back.
Cut the front drive shaft down, exhaust, and brake line.
Then drove it out to take a look and the new profile.
Next comes the bed...
Old 04-19-2015, 09:04 AM   #6
msgross
msgross's Avatar
Nice work... does that frame need any more reinforcement in the weld area? I see a lot of people use a plate behind it.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-19-2015, 09:17 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
95% of the people that read your thread are not going to have a clue what a penn weld is (including me) and what you mean by being "tested". I did a Google search for "penn weld" and not much came up.
Also wondering if you plated the inside of the frame at all.
Just personal preference I guess, but I would never use a straight cut to shorten a frame.
Thanks,
LockDoc
Leon
Old 04-19-2015, 09:38 AM   #8
shawno72
C/10 junkie
shawno72's Avatar
Thanks,
LockDoc
Full penetration weld. Means there is 100% weld joining the 2 piece of metal instead of just butting the 2 pieces together. You can see he has a slight gap between the frame rails, then he adds a small piece of metal to one side and uses weld to join it together. Hope that helps
Great work btw
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-19-2015, 09:40 AM   #9
oldertruckfan
penn weld is a full penetration weld. tested would mean that a certified weld inspector would check the weld for full penetration using some method of testing
oldertruckfan is offline   Reply With Quote
Old 04-19-2015, 09:48 AM   #10
65standard
65standard's Avatar
95% of the people will not like my frame since I am not added any fish plate. A full penetration weld is just that, the weld bead is the full thickness of the material. This is done by beveling the rails and leaving a small gap before welding. Once welded, you will have a raised bead on both sides of the rail.
I then ground down the weld so it could be tested. A machine like an ultrasound and jelly is used to look for and air gaps or disturbances in the metal. Also, grinding the weld smooth avoids any stress spots or sharp edges.
If the weld was not 100%, I would add a brake formed channel to fit inside the rail. This is much better than a fish plate or boxing plate.
Now, off to the bed. I completely disassembled the bed and cut down the floor pan. 12" off the front and 7.5" off the rear.
I drilled new front and rear mounting holes in the pan and bolted it to the frame.
You can see it still looks factory.
For the rear, I saved the rear cross sill and put it back on the frame and under the pan.
Then I started to tip over the 1/2" of floor pan I saved when I cut 7.5" off.
Once fully tipped, I plug welded the pan back down to the cross sill. The floor is now a SWB pan and no splicing like all others I have seen here. I saved over 10' of weld and kept my original paint.
Now off to the bed sides....
Old 04-19-2015, 10:09 AM   #11
bollybib
bollybib's Avatar
Interesting. Looking forward to seeing how you do the bed.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 04-19-2015, 10:29 AM   #12
29od1
What's your plan for the front of the bed floor where the front bed panel attaches? Will you form all the beads flat where the two bolt together?
29od1 is offline   Reply With Quote
Old 04-19-2015, 10:40 AM   #13
65standard
65standard's Avatar
No. I didn't see the need to flatten the pan where the bulk head bolt down. I will just re drill the bolts between the ribs of the pan.
I am aiming to keep as much of the original paint and rust as possible. I do not want two huge weld seam on the sides of the bed. I can't keep the original paint or finish the weld that way. It would surely require bondo and new paint with that cut down method.
Old 04-19-2015, 11:42 AM   #14
tommys72
tommys72's Avatar
I'm pretty much amazed so far. I'm looking forward to the bed work
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 04-19-2015, 12:07 PM   #15
leftybass209
leftybass209's Avatar
How do you plan on shortening the bed sides without weld seams while still retaining a factory short bed appearance?
leftybass209 is offline   Reply With Quote
Old 04-19-2015, 12:51 PM   #16
65standard
65standard's Avatar
For the front of the bed I scribe two lines. My cut line at 11 1/8" and my tipping line at 12". More pictures as I go....
Old 04-19-2015, 01:28 PM   #17
57larry
looks like very nice work. waiting for more pics
57larry is offline   Reply With Quote
Old 04-19-2015, 02:10 PM   #18
aod92
aod92's Avatar
Looks great! You work wonders with metal and it sure is fun to watch.
aod92 is offline   Reply With Quote
Old 04-19-2015, 02:51 PM   #19
shawno72
C/10 junkie
shawno72's Avatar
This is great info for when I shorten mine
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-19-2015, 02:57 PM   #20
67swb72klb
67swb72klb's Avatar
Some good ideas
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-19-2015, 03:54 PM   #21
72_K10_Vegas
72_K10_Vegas's Avatar
Nice
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 04-19-2015, 04:21 PM   #22
treveiger
treveiger's Avatar
Looks great.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-19-2015, 05:52 PM   #23
65standard
65standard's Avatar
The bulkhead will just bolt to the floor pan something like this. I will drill holes on the lows of the pan.
Here are my scribe lines on the front of the bed side. One for cutting and one for tipping over the edge.
I will tip the edge over just like the factory did here.
If I wanted to, I could just weld the bed side back together right at the edge. But I don't want to burn the paint if I don't have to.
Once I cut the extra material off, I started to tip over the inner panel. Again no welding here.
And started to tip over the outer bed skin.
With the inner panel fully tipped, I slid the end cap in place to see my progress.
Test fit is looking good. I just need to complete tipping the outer skin to the end cap, spot weld back together and add the front bed pocket to finish up this corner.
100% of the original paint save and 17' of weld avoided so far.
Old 04-19-2015, 05:59 PM   #24
tommys72
tommys72's Avatar
Damn fine work fella! Nice and original looking
Old 04-19-2015, 06:01 PM   #25
imjeff
imjeff's Avatar
I'm kind of curious how your frame will do without fish plating it. You have two brittle lines running up your frame. Fish plating spreads that stress over multiple areas. It's not a matter of whether the weld is completely penetrated, it's the stress on the toes of the weld. Without heat treating, those toes will be weaker than the weld or the unheated frame.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
