Old 08-24-2015, 11:16 AM   #1
Harpie
Harpie's Avatar
Frustrated! Glass install
Took my 71 to have new front and back glass installed. Guys show up at my Granddads body shop to do it and refuse to touch it when they realized it had the stainless trim. I had specifically called these guys to do it because it had the trim in it. They said they had messed up a guys trim and had to replace it and wouldn't touch another one. Now what am I gonna do?
Harpie is offline   Reply With Quote
Old 08-24-2015, 12:08 PM   #2
Davidf
Re: Frustrated! Glass install
Do it yourself, (with a buddy...your granddad?). read up on it and go slow. Use plenty of soap...I use Windex.
Davidf is offline   Reply With Quote
Old 08-24-2015, 12:11 PM   #3
Harpie
Harpie's Avatar
This is probably what I am going to hafta do. Was trying to save time and have it done. My grandad is 81 and has done several and has an old buddy that was a Chevy mechanic for over 30 years that has done them back in the day so will prolly hafta go that route.
Old 08-24-2015, 12:33 PM   #4
NorCalC20LWB
Have you seen this video?
https://www.youtube.com/watch?v=SOU_0HpS7To
NorCalC20LWB is offline   Reply With Quote
Old 08-24-2015, 12:36 PM   #5
Jason Banks
Jason Banks's Avatar
You can do it. They probably got in in a hurry on the one they messed up.
Jason Banks is offline   Reply With Quote
Old 08-24-2015, 12:51 PM   #6
Harpie
Harpie's Avatar
Yes I have watched it guess I will be doing it myself.
Old 08-24-2015, 01:51 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
Harpie,
My son and I did my front and rear. Start with the rear window, get a little confidence before tackling the front. Take your time and use plenty of soapy water or windex for lube. I bought a piece of 300 paracord to mine. It worked pretty good. It is still very nerve racking... good luck.
Man, I wish I had seen that video before I installed mine. Thanks for sharing that.
Old 08-24-2015, 01:55 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Frustrated! Glass install
My daughter and son helped me. We did both front and back in a couple of hrs. No leaks in 5 years so I guess we did Ok. Just take your time and be easy with it.
I used some plastic knifes to help get the corners in right and cord inside the gasket to pull the gasket through the opening. As stated use plenty of soap.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-24-2015, 02:10 PM   #9
Harpie
Harpie's Avatar
thanks for the advice we are going to give it a try... wish me luck
Old 08-24-2015, 03:28 PM   #10
Davidf
Wow, I watched that video. Most mortals would break the glass trying to get it out as demonstrated. I think that guy came really close to breaking the windshield. I recommend cutting the original rubber seal so the glass almost simply lifts out. And, finally, soap or Windex would have made the install soooo much better. Another tip, might be to ensure you put upward pressure on the windshield while you work the rubber seal over the pinch weld. gravity tends to pull the glass too low...so keep working it upward as you work it in.
Good luck.
Old 08-24-2015, 03:54 PM   #11
BlackedOut67shorty
BlackedOut67shorty's Avatar
Took me and my dad three times till we got one in without breaking it, Its a learning curve for sure lol
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-24-2015, 04:26 PM   #12
Osons
remember: practice makes perfect or you go broke. Either way, there's incentive.
Osons is offline   Reply With Quote
Old 08-24-2015, 05:49 PM   #13
Orange67
Orange67's Avatar
Take your time, use lots of lube. Suction cups help, as you can pull in while pulling the rope out. Honestly, the biggest hurdle you have is make darn sure the trim doesn't pop out as you are installing it. If it does, start over.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 08-24-2015, 08:08 PM   #14
diggerbob
diggerbob's Avatar
the assembly manual also shows that some adhesive (butyl rubber?) should be used at the corners. I haven't seen much discussion on the board about this though.
diggerbob is offline   Reply With Quote
Old 08-24-2015, 08:50 PM   #15
truckster
truckster's Avatar
They came with butyl rubber sealant from the factory because the factory couldn't take the time to check them for leaks and dealers didn't want to have to deal with leaks. You only need it if it leaks. And don't use silicone as a substitute.
I also second (or third) the use of glass cleaner as a lubricant. It's slick enough to work and doesn't leave the mess that dish soap can.
truckster is offline   Reply With Quote
Old 08-24-2015, 09:48 PM   #16
Clavo106
https://youtu.be/i2Xg30Q39Cw I watch this vid..
Clavo106 is offline   Reply With Quote
Old 08-24-2015, 10:12 PM   #17
KRamsey07
Harpie you need help let me know . My numbers 580 380 3101 ill give you a hand anytime you need it brother
KRamsey07 is offline   Reply With Quote
Old 08-24-2015, 10:33 PM   #18
Clavo106
thats team work...
Old 08-24-2015, 10:41 PM   #19
Harpie
Harpie's Avatar
Will do I appreciate it! And thank you everyone for the info and advise. You guys are great.
Old 08-25-2015, 05:07 PM   #20
Kennuck
Kennuck's Avatar
My 2 sons helped me put mine in. We did the back one first to get the hang of it and then did the front. Took all of 15 minutes and the rubber lays flat perfectly.
There are lots of people that will tell you to pull the top in first but we couldn't get it in that way. We pulled the bottom in first and worked each side around a little at a time toward the top. Use a circular motion when you get to the top corner while pulling the rope to help it around the 90 degree corner. I had the boys press on the outside with a flat hand as I pulled on the rope. Use lots of soapy water, I used a couple drops of dish soap in a spray bottle of water and soaked the rubber and pinch weld really good.
Don't be afraid to tackle this on your own. Watch the video and get two helpers and have at it.
Good luck.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 08-26-2015, 02:56 PM   #21
strangestash72
strangestash72's Avatar
I took mine to safelite auto glass . They ordered the rubber and the chrome trim to ensure fit. It cost me $250.00 . I tried it myself the first time ! Ill never do that again. Its way harder then the videos look and what anyone says. You'll probably break the windshield like me. Just call around and make sure you get the rite parts.
strangestash72 is offline   Reply With Quote
Old 08-26-2015, 03:39 PM   #22
Harpie
Harpie's Avatar
I found a company willing to do it for $250 but I hafta haul it to the shop and leave it for a day. But if they break anything they will replace it they said. So looks like that's what I am going to do.
Old 08-26-2015, 04:27 PM   #23
bigmac73
bigmac73's Avatar
I did not realize there were that many Oklahoma peanut farmers on this site??? LOL
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-26-2015, 08:06 PM   #24
KRamsey07
Yeah you best watch us peanut boys !!!!
Old 08-27-2015, 02:16 PM   #25
bigmac73
bigmac73's Avatar
LOL, I had family in Kingston /Madill area
and my dads side are from the mill creek/Tishomingo area
I grew up in Moore,Ok
Mike
