Old 10-11-2015, 08:10 AM   #1
65standard
65standard's Avatar
Front suspension drop failure
I have 2 1/2" drop spindles and cut 2 full coils off the stock C/10 springs. Truck is fully bottomed out with tires resting on the top of the inner fenders. Clearly 2 coils is way too much. Time for new springs.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 10-11-2015, 09:28 AM   #2
sic_F44
Re: Front suspension drop failure
looks good tho id just pull the inners for now lol
sic_F44 is offline   Reply With Quote
Old 10-11-2015, 10:45 AM   #3
Gregski
Gregski's Avatar
You shouldn't be cutting coil springs to begin with.
Gregski is offline   Reply With Quote
Old 10-11-2015, 11:07 AM   #4
kalbert
Nah... Cutting springs is fine. Do it with a sawzall or cutoff wheel, not a torch and you'll be fine. 2 full coils is pretty aggressive, most people do just one and get around 2" of ride height with a moderately stiffer ride. Chopping a coil off and relocating the shackles and hangers is a near zero cost way to get lower.
kalbert is offline   Reply With Quote
Old 10-11-2015, 12:03 PM   #5
Burmanater
You might want to try a smaller size tire. That's the way my truck sits and ive got a 225/70 15 and it still rubs on hard cornering. had a set of 225 75 15s up front and it was about the same but rubbed a tad more(Hercules terra trac) I had 225 75 bfg ta tires that for some reason didn't rub though.
Burmanater is offline   Reply With Quote
Old 10-11-2015, 12:29 PM   #6
SkinnyG
SkinnyG's Avatar
If you're buying springs, buy 1-ton springs. It adds spring rate so you can ride low with less bottoming out --- but only cut a coil or so off (I cut a coil, then kept trimming 2" off the end until it sat at the height I wanted).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-11-2015, 03:18 PM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
MOOG 6452 1/2 ton
Bar Diameter - Inches 0.78
End Type 1 Tangential
End Type 2 Pigtail
Free Height - Inches 13.64
ID - Inches 3.68
Installation Height - Inches 10.00
Load - lbs 3155.00
Spring Rate - lbs per inch 843.00
Spring Type Constant Rate
Alternate/OEM Part Number(s): 328096, 328097, 328150, 328151, 3933259
MOOG 6454 1 ton
Bar Diameter - Inches 0.82
End Type 2 Pigtail
Free Height - Inches 13.61
ID - Inches 3.67
Load - lbs 3841.00
Spring Rate - lbs per inch 1060.00
Alternate/OEM Part Number(s): 328098, 328099, 328100
Rich
1972 K5 Blazer CST Click HERE
Old 10-11-2015, 03:28 PM   #8
muthstryker
muthstryker's Avatar
1 coil on stock springs is a 2" drop. You cut a tad to much lol
Matt
muthstryker is offline   Reply With Quote
Old 10-11-2015, 03:55 PM   #9
Major86
How much drop is 1 coil off drop springs? 2" as well?
Major86 is offline   Reply With Quote
Old 10-11-2015, 04:39 PM   #10
muthstryker
Probably 1", drop springs have more coils with a higher spring rate.
Matt
Old 10-11-2015, 06:02 PM   #11
65standard
65standard's Avatar
Thanks everyone. I just bought the Moog 6454 springs from SummitRacing. Couldn't beat the price, $8.97 a pair plus shipping. Must be a mistake, but I bought them before they see it. The cheapest Moog 6452 springs I found are $69. One-ton springs it is.
Old 10-11-2015, 07:10 PM   #12
mcmlxix
mcmlxix's Avatar
Holy OOPS Batman ... I ordered a set too and I don't even need them right now... I though you had a typo in your post till I checked out the site...
Rich
Old 10-12-2015, 02:14 AM   #13
RUN GMC
RUN GMC's Avatar
In for a set just because........thanks for the heads up.............
RUN GMC is offline   Reply With Quote
Old 10-12-2015, 09:39 AM   #14
school boy
school boy's Avatar
Bought a set myself! $15 shipped is a steal! Glad I looked into this!
school boy is offline   Reply With Quote
Old 10-12-2015, 10:48 AM   #15
Joe69C10
Joe69C10's Avatar
Great deal! I just ordered a set for $14.92 shipped! Im in the process of dropping my truck and was gonna cut the old rusty stockers..
Joe69C10 is offline   Reply With Quote
Old 10-12-2015, 12:28 PM   #16
Domer
Domer's Avatar
all you people ordering them.. now they show ship today, but when you check out, they say back ordered with an estimated ship date of Nov. 5
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Domer is offline   Reply With Quote
Old 10-12-2015, 03:39 PM   #17
65standard
65standard's Avatar
They had 10 pairs available when I ordered mine.
Old 10-12-2015, 03:40 PM   #18
ddr11
ddr11's Avatar
There is a easier and cheaper fix for this. I've been running this set up for a while now. AFCO makes a coil spring spacer/adjuster for the dirt track application. This also works very well when your truck doesn't sit level across the front
ddr11 is offline   Reply With Quote
Old 10-12-2015, 05:31 PM   #19
Tom
driving is in my blood
Tom's Avatar
^ Thats a good find, something to remember for down the road when needed.
Old 10-13-2015, 05:21 AM   #20
mcmlxix
mcmlxix's Avatar
Mine are scheduled to arrive today on the 13th.....
Rich
Old 10-13-2015, 09:10 AM   #21
Shugalou
Shugalou's Avatar
damn they are still there
http://www.summitracing.com/int/parts/mog-6454
I thought about buying but I would prefer a drop spring - damn good price though
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 10-13-2015, 11:42 AM   #22
solidaxel
solidaxel's Avatar
I could not resist!
I need to change one spring, front end is sitting 3/4" lower on the passenger side, so I guess I will change two at that price!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-13-2015, 11:44 AM   #23
solidaxel
solidaxel's Avatar
When you receive them would you check the static height (length), Thanks
LS 3 4L70E
Old 10-13-2015, 07:35 PM   #24
65standard
65standard's Avatar
Mine were delivered today.
Old 10-14-2015, 08:43 AM   #25
gasmn1620
just got some.... don't really need them but you never know when you will, and at 14.92 you can't go wrong.
gasmn1620 is offline   Reply With Quote
