my 65 coming alive
http://67-72chevytrucks.com/vboard/a...1&d=1445787895
I figured I would get a picture out there since its taken 3 years to get to this point Im in the process of reconstructing a truck I've never seen together or driven for that matter except around the yard as of 4 weeks ago after I mounted the cab on the finished frame. I will construct a build sheet as soon as I get time. I will say that this forum and the guys here are the greatest most informed group especially in the 60-66 catagory that is very specific to my build I salute you all for this great wealth of knowledge I will do my best to input responses from what I have learned ![]() |
Re: my 65 coming alive
we need more pixs...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Im going to get a couple more up shortly
http://67-72chevytrucks.com/vboard/a...1&d=1445810710
Motor rebuilt 33,000 miles mounted back on completed frame |
![]() Join Date: Feb 2014
Truck looks great! I see you got the right gas tank from the truck shop.
Sure did Mike. They were pretty quick on switching it out for me
Thanks! |
http://67-72chevytrucks.com/vboard/a...1&d=1445859430
Double layered insulation for sound deadening- road noise. U-seal is used under a product called reflectix. Its 1/3 the cost of the insulating sound mats and great results and user friendly Sorry for the sideway pics but i can't seem to adjust them after loading. |
#14 | |
#15 |
Reflectix can get at home depot or lowes. Lowes has a bigger variety on size. I got a 25' roll i think it was 2' wide. I used an adheisive spray to adhere it to the Useal. Useal is great underneath due to its rubber backing that sticks right to the metal and the top is foil ...it is non butyl so theres no rubber odor
#16 |
Now my preformed carpet will go right over it with perfect fit and it feels great without the carpet
#17 |
![]() Join Date: Mar 2013
Nice truck! Glad to see the 6 banger was saved.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#18 |
Thank you Tj!!
=the motor only has 33,000 i had the upper end seals replaced for acceptace of unleaded gas. |
#19 |
Nice! I kept my 292 and built it for street performance and backed it by a tko600. Always nice to see something different lurking under the hood. lol
#20 |
Tj,
What would be a lowball cost to get my engine set up like yours......only one problem mine is a 250...is it feasible? Nice trucks you have !!! |
#21 |
Who Me?
Nice looking build!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#22 | |
Head work: BBC 1.75 ratio full roller rockers Z/28 valve springs 1.94 intake valves 1.60 exhaust valves Had the bowls opened up as well. .030 shaved off the head. Block work: Zero decked. .040 Ross forged aluminum pistons with an 18 CC dish vs 30 CC stock. Stock rods fitted with ARP studs and bolts. Crank shaft balanced and ground Comp cam 268H 219 @ .050 .499 lift on a 110 lobe center. Clevite bearings Melling oil pump. Smith brother's pushrods. And then the accessories. lol Expected HP is 310 and torque should be around 340 at the flywheel. You could do the exact same head work, flat top pistons, and with .520 lift on the cam make 310 hp and 280 torque and have a 6000 RPM 6 banger. lol! Check out these videos. This is a 250 that Hauls! https://www.youtube.com/watch?v=3NU7n3kOWe8 https://www.youtube.com/watch?v=iXdFLCIz-BA
#23 |
![]() Join Date: Oct 2012
Is this a GMC or Chevrolet? I didn't think GMC's came with a 250-6. Also, you have any more to share about getting it "in a box"? Would love to hear the back story. Love the color scheme also, can't wait to see it finished.
#24 | |
