Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-07-2015, 02:53 PM   #1
Advanced Design
Advanced Design's Avatar
Stand by whole house generator...
We have been talking about having a whole house stand by generator installed for several years now and think we will get that done this fall. Generator will be sized large enough to handle our modest house. The shop is on the same meter loop so it will need to handle lights and the heater fan there.
The system will automatically come on in a power outage and cut off from the utilities. Fuel will be LPG and the brand is likely Briggs and Stratton or GE as that is what the dealer in this area handles.
Any one have personal experience with either brand? Anything to watch out for?
I travel a lot with my job and want a reliable no fuss system.
Thanks guys....
Advanced Design is offline   Reply With Quote
Old 11-08-2015, 04:52 AM   #2
In The Ten Ring
Re: Stand by whole house generator...
That's something I have been thinking about too for about a year now. I'd have to locate mine behind my house since there isn't room elsewhere. I am planning to build a shed on a concrete pad to house it and secure it inside a steel cage that I'll build inside the shed that the bad guys won't be aware of until after they break into the shed.
In The Ten Ring is offline   Reply With Quote
Old 11-08-2015, 09:34 AM   #3
Advanced Design
Sounds like a good plan ten ring. Ours will sit out in the open next to the meter loop and should be ok. We are way out in the sticks and fortunatly rarely have a power outage. Last one was about three days winter before last and I was away from home. Lucky Dad was here to drain water from pipes and save the meat supplies in the freezer.
In the 70's an ice storm took out all the electric poles and we didn't have power for two weeks. We heated with wood then and had a tractor powered generator to run the place. It was a bit of a hassle to get by.
Lotta work to live without electricity.
Anyway, do you have any systems you have been researching?
Old 11-08-2015, 01:34 PM   #4
In The Ten Ring
Thanks man. Drug use has really gotten bad in WV. I no longer take mail at my house (got a PO box) since someone got in there and stole a package last year. Also last year two men very nearly broke in, but a neighbor scared them off. I was working nights then and it scared me so much, I took a week off and would not leave the house if it was dark. For months I would park my car in front as if I was home, leave the usual "at home" lights on, and walk to and from a friend's house where I would park a borrowed car. I finally got expanded metal up over my french door glass and backed that up with double cylinder dead bolts (come in through a window but you can't get out a door), and a huge latch and biggest padlock I could get on those french doors. It looks intimidating from the road and people talk about the house now. It's worked so far.....no one has tried again.
So whatever I build now has to be pretty secure. Had I been home, I am confident I would have terminated bad guy #1 and maybe accounted for the driver. I think they were later arrested and had knocked off dozens of houses.
Let me get this magazine I came across, it had an article. Here it is.
Consumer Reports October 2015. It had a great breakdown of such generators and why certain ones were better. You might can find this at a library, college library, or via an online magazine search. A college library would be best to ask and perhaps calling one will do.
Old 11-08-2015, 02:55 PM   #5
Advanced Design
Thank you ten ring. Will check out the CR article. Sounds like a scary problem there due to the drugs. We don't have any problem with theft around us and feel very fortunate.
Old 11-08-2015, 03:13 PM   #6
_Ogre
_Ogre's Avatar
paying for the price of a whole house generator when you rarely need it?
i have a 5000 watt generator that runs my whole house fine
i just turn off the main breaker and plug it into the welder plug in my shop
i have $400 in the whole setup vs many thousands to have the whole house with transfer panel
we're on a well, have gas heat and hot water; so other than the fridge we don't have a lot running
i bought it after the big power outage that hit the whole north east for 3 days back in 03
they installed a lot of generators for other utilities, so that we no longer lose internet or cell phones
shop air compressor timer
Old 11-08-2015, 04:00 PM   #7
Advanced Design
Yep, paying for piece of mind for when I am away from home. Wife can't hook all that stuff up. Looking out for her and not putting the hassle on friends or family.
We have a large tractor powered generator. Now Dad won't have to shuttle it between our houses when needed.
Old 11-09-2015, 01:26 PM   #8
Willowrun
Willowrun's Avatar
I travel also. I have a Generac whole house generator that runs on natural gas. No issues to speak of and I've had it for about 7 years. It cycles once a week on its own. Yes, they are a lot of money, but my wife deals with enough when I'm gone and I don't need her dealing with no power.
Old 11-09-2015, 02:28 PM   #9
In The Ten Ring
That's great man. Myself, I am purely in a planning phase.
Old 11-09-2015, 02:48 PM   #10
Advanced Design
Thanks Willowrun. I will check into Generac too. Always a bummer when you are far from home, wife calls and says...power's out, getting cold in here.
Old 11-11-2015, 01:58 AM   #11
68c10airstream
68c10airstream's Avatar
I have a new boiler for my house heat and it's sensitive to line voltage issues. I purchased a yamaha portable inverter series square wave generator for camping needs and tested fine for my boiler use as well. I have aladdin kerosene lamps if i get desperate. I don't know if other furnaces/boilers are this way but with all of the electronic controls it's a remote possibility.
68c10airstream is offline   Reply With Quote
Old 11-11-2015, 07:21 AM   #12
Advanced Design
Thanks 68C10airstream. I will check on our furnaces sensitivity to line voltage issues and the generators ability to maintain steady voltage.
Old 11-26-2015, 05:19 PM   #13
aknovaman
Get an Onan 1800 rpm genset from a RV. They last for years compared to hundreds of hours like the screamer 3600 rpm contractor versions. Try craigslist and search for Onan. I have two on big tire mobile carts. You can have an actual conversation standing next to one. For the $$ you spend on a screamer, you can get an Onan that lasts a lifetime. They are larger as the generator head has 4 poles as opposed to the 2 of 3600 rpm units.
I have $250 for my 5kw unit with less than 200 hours on it.
http://youtu.be/q2lVNJkbQs0
My YouTube channel link in my sig block has a couple more vids of how I set mine up.
Here is a forum post that has a huge following.
http://www.smokstak.com/forum/forumdisplay.php?f=1
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 11-26-2015, 05:44 PM   #14
Advanced Design
Thanks aknovaman. Checking it out now. Amazing forum on generators. That one in the video is pretty quiet.
Old 11-26-2015, 05:50 PM   #15
aknovaman
Smile Re: Stand by whole house generator...
Rv park guys dont tolerate a screamer, ever. Mine is even more quiet in person than on video.
A 10 to 15kw will run everything in a house including a huge furnace or ac unit in summer. I see 15kw units for less than $2000.
FMCDH GBU and GBA
Old 12-04-2015, 09:57 AM   #16
drfloyd
I installed a 15KW Coleman(Generac) in my mom's house for peace of mind. The best thing I ever did. Obviously, the most difficult part for most is installing the ATS but that's in my wheelhouse. As far as noise, this one is like most of them, it's enclosed so you barely hear it run.
drfloyd is offline   Reply With Quote
Old 12-04-2015, 09:59 AM   #17
aknovaman
I would be curious as to how many hours of runtime these Generac have.
FMCDH GBU and GBA
Old 12-04-2015, 10:05 AM   #18
drfloyd
I don't really know but unless you are in the backwoods somewhere it shouldn't run that much. I put my mom's in probably 10 years ago. It starts and runs for an hour once a week and has been a life saver(literally) on many occasions. I don't remember what it cost but that money has been recouped several times over and if it crapped the bed today I would go buy a new one and install it. The upside to replacing one is that you wouldn't have to replace the ATS. That's a large part of the expense.
Old 12-04-2015, 10:09 AM   #19
drfloyd
I can tell you this, I'm in the power business and deal with 3600 RPM generators on a daily basis. There's no reason the generator itself should go bad. The engine is a different story.
The majority of the power produced in the US is produced from 3600 RPM, 2 pole generators. As far as I know, with a few exceptions, the only 4 pole generators are on nukes.
Old 12-04-2015, 10:10 AM   #20
aknovaman
Definitely. Couple years ago we had a 2 week long ice storm and one of the old guys i work with had a disabled wife that refused to go to a care facility after the powrr company took forever to fix the lines. Another coworker loaned him a generator and ran it non stop. It was a real life saver. Sometimes its better to do that type of thing rather than totally mess up an old persons personal life by relocating. Yes we used tons of gas but it was worth keeping the peace.
FMCDH GBU and GBA
Old 12-04-2015, 10:21 AM   #21
drfloyd
My advice to anyone looking into a standby is to assess your power needs carefully before you buy one. For instance, my mom's home is heated and cooled with an electric heat pump. She has a gas insert in her fireplace so she can stay warm in an emergency. The standby runs on LP as does her insert. The standby is ample enough to run the compressor portion of the heat pump but not the 10KW heat strips. So if she were in normal winter mode and had a power outage, she would be attempting to run the strips with the standby and would obviously trip a breaker. The ATS has several spare contacts so I wired a lockout contact on her heat strips so when the ATS is in standby mode the strips won't run but the heat pump will. Then she can fire up her insert and stay warm. Things like this need to be thought out or either buy a unit large enough to handle the entire load.
Old 12-04-2015, 10:25 AM   #22
aknovaman
Smart move. Some people think they can just trip the main breaker and plug in a suicide jumper cord. Not a smart move.
FMCDH GBU and GBA
Old 12-04-2015, 04:37 PM   #23
_Ogre
_Ogre's Avatar
works for me
Old 12-17-2015, 08:53 PM   #24
Advanced Design
Guys, thanks for the advice and your experiences.
We went with what our local dealer sells and had them install the Briggs and Stratton 16kw unit. It will handle our house and the shop in winter or summer as long as I don't run the compressors or welder.
I wanted a turn key no hassle solution and I think this is it for us.
Old 12-19-2015, 01:12 AM   #25
OhioChevy
Nice looking unit and should do you a good job. Small price to pay for the peace of mind when you are away on the job.
Ray
OhioChevy is offline   Reply With Quote
