11-12-2015, 11:31 PM | #1 |
Taillight harness retainers/routing
In the process of getting ready to install my tail light harness drone firewall to rear. Just curious if any of you guys have pics of the routing and the retainers you used. I'd like to see how you guys routed yours so I know I've done it correctly.
11-13-2015, 12:11 AM | #2 |
Re: Taillight harness retainers/routing
A few good old zip ties will be good as far as fastening everything down to prevent chafing and keep the harness in place
Sorry I have no photos; but I do know to suggest that you start from the center and route each leg of the rear taillight harness through the provided holes on that rearmost transverse support towards each side's tail light assembly. Because when I replaced mine I didn't do that on one side and was bummed to find I had to pull half of the harness back out again just to loop it back through the holes I doubt that I am making sense here but once you have it in front of you - you will see what I mean.. I would recommend wearing a dust mask and eye protection because a lot of dirt will flake off as you are pushing that harness around under the frame (unless you have one of those frame-off beauties).. The grounds are really important and you really have to look at both surfaces (the body metal where the ground fitting mates) and the fitting itself to be sure they are making a good connection and there is clean metal.. you can spray it with cold galvanizing AFTER assembly so that you have a good connection and then the whole assembly is protected. A little Di-Electric grease is handy too.. The Side Markers ground to the sheet metal and the taillights ground through the screws that attach the tail light housing to the body. so I paid close attention to wire brushing those connections as I put it together and it worked out okay. Otherwise you risk ending up with weakly glowing taillights and the Man pulling you over.. |
11-13-2015, 12:26 AM | #3 |
I wish I had the link, but there are some aftermarket clips you can buy somewhat similar the originals. I haven't dove in under the cab yet, but four are used to mount the harness to the LH frame under my short bed, and there are more, just not sure the total yet................Search this website for the clips, that's where I found them. They're tan in color. I believe rubber coating.
Also look at the assembly manual. I'm sure it covers it. Just a matter of locating the right page, which is usually a pain in the arsch.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-13-2015, 12:38 AM | #4 |
I don't have pics but there are retaining clips running inside the driver side frame channel. When the harness splits off to passenger side wiring, there are clips in the channel just behind the bottom of the tailgate behind your bumper.
White K20 |
11-13-2015, 12:42 AM | #5 |
Here are 2 pictures showing the clips originally used inside the left frame rail of my 69 long bed (3/4 ton). I'll get under the truck tomorrow to count how many there are. I looked a few minutes ago and don't think I'll be able to snap more pictures though.
11-13-2015, 01:02 AM | #6 | |
They look similar to the ones that run on the rear cross sill for the rear light harness under the bed Last edited by jomatt20; 11-13-2015 at 01:14 AM. |
11-13-2015, 01:12 AM | #7 |
One more picture from my file.
11-13-2015, 01:23 AM | #8 | |
11-13-2015, 01:27 AM | #9 |
These look even closer... The originals had a rubber or vinyl coating on the part that contacts the wire. It doesn't look like these do.
http://www.classicparts.com/1947-72-...tinfo/52-905/# Last edited by FirstOwner69; 11-13-2015 at 01:55 AM. |
11-13-2015, 01:41 AM | #10 | |
11-13-2015, 01:43 AM | #11 |
11-13-2015, 01:54 AM | #12 |
If you rinse them with alcohol and soak them in phosphoric acid and/or use gun blue they'll be black like they were when new. Rust resistant too.
11-13-2015, 01:59 AM | #13 | |
http://www.jegs.com/i/Eastwood/352/1...de4aAi8x8P8HAQ
11-13-2015, 02:04 AM | #14 |
Close. I don't see any rubber coating, but they'll definitely work.
11-13-2015, 02:04 AM | #15 | |
11-13-2015, 02:15 AM | #16 | |
I got the cold oxide kit from Caswell too. Will use that for small items like u-nuts, maybe some bolts. I've yet to finish one item. That will come in the spring. Until then, dismantle, prep, and a ton of notes. I also have some black rubber coated clips, which were pulled when my bud and I R&R the engine in 1993. Couldn't tell you what they're for yet, but another seven or so. Might be for the hose from the tank to the vapor canister, which we never put back on. Already have its replacement. Really, two ha!.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-13-2015 at 02:27 AM. |
11-13-2015, 01:47 PM | #17 |
you may want to consider if you will ever tow a trailer with your truck. If you think you ever will, it would be a wise and smart decision to set that wiring up now while you are running all of the wires you need, and it's all very easy to get to. If you know that it will never haul a trailer, than that will make things even easier
11-13-2015, 04:01 PM | #18 |
We routed our tail light harness same as original, and the guys are right. There should be some clips (or empty holes for the clips) on the drivers side frame rail. The mid-harness from under the bed connects to a grommet on the actual tail light harness on a metal support at the very back of the bed.
Maybe this photo helps with the routing. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
11-13-2015, 04:04 PM | #19 | |
11-13-2015, 04:16 PM | #20 |
I just crawled under the truck and took pics. There are 7 clips on the frame rail, 1 on the rear cross member where the taillight harness connects and 3 inside the rear bed sill. I can post the pictures this evening if you still want them. Let me know.
Jim |
11-13-2015, 05:24 PM | #21 |
The more the better, thanks man
11-14-2015, 01:53 AM | #22 |
Pictures starting at front. Some pictures show the factory camper wiring harness running parallel to the lighting harnesses.
11-14-2015, 01:54 AM | #23 |
Page 2... 4th picture is at back of rear cross member. 5th is inside left end of rear bed sill.
11-14-2015, 01:55 AM | #24 |
Page 3... 1st picture is inside rear bed sill at center. 2nd is at right end of rear bed sill. My truck never had a bed to frame ground strap so ignore that in the last picture.
11-14-2015, 09:53 AM | #25 |
Thanks this helps a lot!
