49, bagged, 6.0, patina, the works
Been a long time lurker and figured I would go ahead and start a build thread. I picked this truck up in the car corral at Goodguys two years ago. It was stuffed in a barn in Washington for 30 years, has killer patina, and was all there. I fell in love.
The original frame was rotted so it's getting an S10 chassis. Other plans are air ride, 3 link rear, 6.0LSX/4L80E, nice interior, vintage air, etc. etc. These photos are a timeline from 2 years ago with the most recent being today. I work on the truck a lot more now and have been making progress daily, so stay tuned! Enjoy! ![]() ![]() ![]() Started tearing it apart. ![]() ![]() Couldn't help myself :stickoutt ![]() ![]() ![]() Bought an S10 longed for dirt cheap, yanked the cab and bed to send to scrap. [IMG] ![]() My sick cab removal tool [IMG] ![]() Frame with the motor/trans left. Sold the dropout a few weeks later. [IMG] ![]() Yanked everything from the 49 frame [IMG] ![]() What I ended up with at the end of that night [IMG] ![]() Stripped the frame completely (super fun, not) and began to assemble the swap kit from code504 to land all the 49' components on the s10 frame. Picked up a 4x4 rear end from the yard. The s10 frame is the correct width to fit underneath the cab and bed, but with how large the track width is on the 49', the 4x4 rear end helps fill out the fenders. [IMG] ![]() Rebuilt the front control arms, energy suspension bushings, proforged super travel balljoints, repainted. [IMG] ![]() Fresh front rotors/wheel bearings/ races/seals. [IMG] ![]() Assembled with 2" drop spindles, proforged upper and lower balljoints. [IMG] ![]() And back on the ground again. Dad had some random old radials laying in the basement which were good to get the chassis back on the ground and size up how it will lay. [IMG] ![]() Starting to look like a truck again. [IMG] ![]() 3 Link came in the mail [IMG] ![]() Roller ![]() ![]() ![]() ![]() Cab back on the chassis for a test fit ![]() Support from the pup ![]() Front bags in and finished up. Control arms dehumped, welded, plated, and repainted. Clip on for a test fit ![]() Lays out pretty hard ![]() Found a killer deal on the perfect donor vehicle for the drivetrain. 04 1ton express van with a healthy 6.0 LQ4 and 2WD 4l80e (freshly rebuilt). Had no brakes and the guy wanted out of it. Towed it on home. Pretty sketchy on an 18ft trailer. ![]() Easiest way to pull the motor/trans haha ![]() Frame out, motor out. ![]() Motor back in the shop for tear down ![]() ![]() Next up is making the harness stand alone on a 4 fuse 2 relay setup. Then regasket the whole motor, add the TSP 228r cam, valve train upgrades and into the truck it goes for a test fit. Separated the motor and trans today, removed some things from the motor and got it on the stand for tear down. [IMG] ![]() ![]() ![]() ![]() Had some ****ty luck with the trans so I'll have to go get this tigged by a friend. Mistakes happen I guess. ![]() The motor has definitely fought me with its typical Chevy issues, dipstick rusted to the block and broke off, both front manifold bolts broke inside the heads. Next time i'm at the shop ill be tackling those issues and continue to break the motor down and begin cleaning. |
![]() Join Date: Mar 2011
Re: 49, bagged, 6.0, patina, the works
Welcome to the group, doing some nice work. I'll follow along for the build...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Looks good, following
![]() Join Date: May 2007
nice condensed timeline! I would have jumped on that original truck too
![]() Join Date: Mar 2007
Looks great. I was at Columbus 2 years ago and I remember seeing your truck in the car corral for sale. Nice progress.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Nice looking patina. I had the same manifold bolts go one mine as well.
I like the patina on it gonna be sick with that 6.0 in there. ive kicked the idea of putting one in my build just haven't come across a good deal yet. ill follow along man good luck
big_moss bagged 51 3100 build |
Awesome.....subscribed
Another nice build going on.....
My Build: 57 Chevy Pro-Street |
Sweet score on the van.
When you get to it can you show some more pics/info on the Thorbros three link. I was thinking about going that way too. |
I would like to see pics of the Thorbros kit installed as well. Are you going to notch the frame? What's your plan for mounting the rear bags?
![]() Join Date: Jul 2012
Cool build and love your shop. I will be tagging along.
#13 | |
Thanks everyone else! |
Wicked dude. Yours reminds me a lot of my 49'
#15 |
Harness laid out
![]() Removing unnecessary wiring (Emissions, Rear O2 sensors, A/C, etc. etc.) Began labeling what I will need from the PCM to get +12v ![]() Harness went on a diet ![]() PCM connectors/all wires that will receive switched 12v. All thats left to do now is solder them to their correct fuse/relay locations. I have the relay sockets, just waiting on the fuse block to come in. ![]() Anyone like spaghetti? ![]() That's it for now. Next update will be the finished harness, wrapped and fused, ready for install. |
#16 |
Also, for those wondering more about the 3link. Quality is top notch and heres a few pics of how the lower bars install, the cross member, and the diff bracket. The bolt on solution is nice for simplicity and ease of removal, etc. Ignore the lack of washers on some of the bolts, they're all there now.
![]() ![]() ![]() Last edited by NickL; 11-27-2015 at 06:16 PM. |
#17 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Great work.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#18 |
Looks good man
#19 |
I looked at that truck that weekend. Held out for a 5 window.
Nice project. |
#20 |
![]() Join Date: Mar 2010
Nice job so far. Like where this is going.... Sub'd
#21 |
Hey Y'all!!
Really nice! Will be following your progress...
Just hopin' I live long enough to finish something!!! |
#22 |
Any updates on this?
Do you have any photos of the Code504 LS engine mounts? |
#23 |
like what I'm seeing, I'll be in on it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#24 | |
Just been so busy working, sorry for the lack of updates everyone! |
#25 |
Bit of an update for you guys.
Code 504 LS series mounts. This is the passenger side mount and its components. ![]() Mounted to the block ![]() Getting the drivers side bolted up to the crossmember. (missing third and final bolt in this pic) ![]() Motor/Trans in. ![]() Few more shots. This shot shows how the A/C compressor will need relocated. Common with how far the engine must sit with the S10 swap. ![]() If you look closely in this photo, you'll see one of the issues that needs taken care of. With the trans mount in the only position it could possibly work, the pan of the trans hits the crossmember itself and prevents the mount from making contact with the crossmember. Im going to notch the crossmember/reinforce it and should be good to go. ![]() ![]() ![]() Overall: The mounts are nice. Simple but effective, nice quality. The only other issue other than the A/C and trans crossmember is the truck oil pan has way too much depth to it and is preventing the frame from airing out all the way. F-Body or Holley LSX conversion pan should fix this rather easily and gain some nice clearance for driving low. Unfortunately, I don't have the headers, steering shaft, and the cab isn't currently installed so no pictures of those things. Supposedly these mounts set the back of the heads 1" from the firewall. Should have that all taken care of sooner than later. |
