Old 11-18-2015, 10:25 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
ok what am i doing wrong here ?
ok i bought a new set of wiper arms from truckshop.com and blades and got my wipers working again because the PO broke the wiper linkage under the cowl well all tat is fixed now but . now my wiper arms dont rest down at the bottom of the wind shield like all of yours ive seen when they come to rest after they are turned off they stop at like6 or 7 inches above the bottom of the windshield making a triangle if you will ... i have popped them off and reset them till im blue in the face and nothing fixes it in fact when i set them as close as i can to the bottom of the windshield when they are turned on they go below the rubber at the bottom of the windshield while in action .... what is the fix to this there has to be something lol how can something so easy go so wrong
WOLFMANmike is offline   Reply With Quote
Old 11-18-2015, 10:47 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: ok what am i doing wrong here ?
Strange as it may sound, I had the same problem and gave up on it until I drove it in the rain and made the adjustment to them with a wet windshield. All I know is that is what worked for me.
DPowers is offline   Reply With Quote
Old 11-19-2015, 12:21 AM   #3
WOLFMANmike
but what did you adjust ?
Old 11-19-2015, 01:24 PM   #4
DPowers
DPowers's Avatar
Pulled the arms off the knobs and repositioned them.
Old 11-19-2015, 01:28 PM   #5
WOLFMANmike
I've done that so many times now and it don't fix it . I'm really at a loss here
Old 11-19-2015, 01:34 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
When you turn off the switch, do the wipers park in the down position or do the stop where they are?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-19-2015, 02:15 PM   #7
WOLFMANmike
No they go down but stop mid window to form a point at just under the center of the windshield
Old 11-19-2015, 05:17 PM   #8
WOLFMANmike
Here is what they look like at the come to rest position
Old 11-19-2015, 06:00 PM   #9
blown240
blown240's Avatar
can you take them off and rotate and reinstall them a bit lower? Seems like that would fix it....
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 11-19-2015, 06:13 PM   #10
WOLFMANmike
yea ive tried that and it dont help at all . like i said if i get it close to the bottom where they should be . then turn them on on the down stroke they past the rubber seal and back to the window again this is why im so lost
Old 11-19-2015, 08:20 PM   #11
blown240
blown240's Avatar
When you rebuilt the linkage did anything have to be modified to work again? A change in the geometry can cause issues...
Old 11-20-2015, 12:18 AM   #12
Softpatch
Softpatch's Avatar
I like the linkage suggestion
or your "park" part of the switch is wearing out
could you show which wiper motor is in your truck
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 11-21-2015, 11:34 PM   #13
luvbowties
luvbowties's Avatar
Smile Re: ok what am i doing wrong here ?
X2 on "park" part of the switch.
luvbowties is offline   Reply With Quote
Old 11-22-2015, 08:25 AM   #14
bhc41051
bhc41051's Avatar
Your wiper linkage might be out of time, there were marks on the wiper motor on my 62 K-10 not sure about 64-66 motors. I've sold the truck and all my 60-66 manuals. Maybe someone could check the shop manual.
bhc41051 is offline   Reply With Quote
Old 11-24-2015, 06:36 AM   #15
WOLFMANmike
Just an update on this issue so far not fixed ... I think since I've tried all your guys ideas now I might just have to go with the park part in the switch is bad . And needs a new switch it's really all that's left ty all of you for your help
Old 11-24-2015, 12:15 PM   #16
DPowers
DPowers's Avatar
I believe I have one that I can send you to see if that is the problem. Is it two speed or single speed?
Old 11-24-2015, 01:13 PM   #17
squidley63
I would think that the issue is where the linkage is attached to the motor itself that is the issue not the wipers. My thinking is if they park in the same position every time the park is working you just have to adjust the linkages to agree with where park is with the motor.
squidley63 is offline   Reply With Quote
Old 11-24-2015, 02:58 PM   #18
WOLFMANmike
It's a 1 speed setup that would be great but I'll have to wait till payday brother I'm broke right now so have no money for shipping
Old 11-24-2015, 03:02 PM   #19
WOLFMANmike
I don't see any way to adjust the linkages on it they only fit one way . As they have a slot to only go on that position on the shaft of the wiper motor .
Old 11-24-2015, 06:00 PM   #20
DPowers
DPowers's Avatar
Just PM me an address and consider it "Paying it Forward".
Old 11-24-2015, 06:31 PM   #21
WOLFMANmike
ok i sent ya a pm brother
Old 11-27-2015, 12:11 PM   #22
DPowers
DPowers's Avatar
Switch shipped out this morning. Hope you get everything worked out.
Old 11-27-2015, 01:37 PM   #23
Steve66
I put an aftermarket wiper motor on my 66 and it does the same thing. Turn the switch off and the wipers park a little high. Turn it on and off real quick again and they drop down where they should. There is no way to correct this by moving the wiper blades or fooling with the linkage. The problem is the park switch in the motor isn't in the right position. I chose to just live with it but you can probably fix it if you want to. I think there are instructions for doing that in the GM Shop manual.
Steve66 is offline   Reply With Quote
Old 11-27-2015, 01:49 PM   #24
WOLFMANmike
OK thank you very much DPowers
Old 12-05-2015, 03:51 AM   #25
WOLFMANmike
Hey DPowers thank you so much for sending me that switch its fixed all my issues wipers go all the way down now just wanted you to know they work now and that was really cool of you .... Happy Truckin
