03-14-2016, 06:05 PM | #1 |
Lmc hood braces
Anybody ever used these? Folded my hood tonight. See the pic on the way the truck looks minutes before I did and imagine the pit in my stomach
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
03-14-2016, 06:55 PM | #2 |
Re: Lmc hood braces
I personally wouldn't use them, they turn the hood into a guillotine in a front end collision.
Nate
Current Project: 1990 V3500 CC dually. |
03-14-2016, 07:05 PM | #3 |
driving is in my blood
Re: Lmc hood braces
I just welded some 1/4" thick pieces of metal plate under the hood in those spots.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-14-2016, 07:16 PM | #4 |
Re: Lmc hood braces
Do you know what my options are? One of those things. Once bent once it will bend again
03-14-2016, 07:41 PM | #5 |
Re: Lmc hood braces
03-14-2016, 07:58 PM | #6 |
Re: Lmc hood braces
If it were mine, I'd find a different/new hood and paint it. Also making sure the hinges are free and properly lubricated.
My dad was a tow truck operator for 15 years. He saw many of these trucks that had some sort of brace on the hood in a front end collision the hood would cut the roof off at the A-pillars. So for that reason I'll never use them. Nate
03-14-2016, 08:29 PM | #7 |
Re: Lmc hood braces
Good to know, I never gave that any thought.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
03-14-2016, 09:10 PM | #8 |
Re: Lmc hood braces
What about stressing the braces. Or grind a notch in them at the crumpe zone?
03-14-2016, 09:59 PM | #9 |
Re: Lmc hood braces
It's not that ad. As long as I can baby it for the remainder of its life
03-14-2016, 10:23 PM | #10 |
Re: Lmc hood braces
Lubed the hell out of the hinges and now the hood almost falls closed. Did not realize how temperamental those hinges were
03-14-2016, 10:28 PM | #11 |
Re: Lmc hood braces
I did the same thing right after I painted my 80 k10. Made me sick! It pushed back down fine, and didn't seem to do any damage. Now I make sure to lube up the hinges often, and I did buy the brace kit from lmc. I have not put it in yet, but I will. You just have to remember to duck fast if you crash.
03-14-2016, 11:18 PM | #12 |
Re: Lmc hood braces
Ouch: lubrication in all the pivot areas. To clean the pivot area use WD-40 then work the hood then re-lube them every 8 to 12 months. and this should never happen again.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-15-2016, 04:59 AM | #13 |
Re: Lmc hood braces
The hood is not the problem. It is the hinges. You can put 7 new hoods on and you will still bend them unless you address the hinges.
03-15-2016, 07:23 AM | #14 |
Re: Lmc hood braces
My cousin told me to push the hood down and back, never pull
03-15-2016, 07:24 AM | #15 |
Re: Lmc hood braces
But now I have a bow in it. I would love to get rid of that
03-15-2016, 11:48 AM | #16 |
Re: Lmc hood braces
I used a brace kit on my 79 and it' still there, I just never thought about any potential side effects. I suppose the upside of having your head sliced off is that your Wife can set it up on the shelf next to your balls.
When I bowed mine I used a 2x4 laid across the fenders in front of then bend and applied light pressure on the bends. Once it was straight I used the braces because it was weak. I did pick up a spare hood eventually though and will replace the bent one. I imagine a lot of people use brace kits, I'm not sure how many shelf mounted heads are out there. Like the man above said, if you wreck you better duck quick.
03-15-2016, 12:59 PM | #17 |
Re: Lmc hood braces
another option I could do, that I do not want to. straighten out with the 2x4 as mentioned above, no big deal. But to avoid this from happening again, just remove the springs and use broom stick to hold it up. I think that will look like crap at the shows
03-15-2016, 01:43 PM | #18 | |
Moderator
Re: Lmc hood braces
Get a real hinge lubricant courtesy of modern chemistry. Wurth HHS-2000/HHS-K adhesive lubricant. Get it online. Or. You can probably buy it locally from a BMW, Mercedes, or Porsche dealership. I heard about it from one of my friends that collects Corvettes that heard about it from his Porsche mechanic. It's incredible stuff. It sprays on thin like WD-40 and flows into the deep dark crevices, like hinge pins, using a volatile solvent carrier that flashes off in a few seconds leaving a thick adhesive lube behind. I use Wurth HHS on hood hinges, door hinges, door locks, door latches, glovebox latches, ignition cylinders, and the tailgate latch and hinges. Since it doesn't attract dirt I also use it on battery cable ends, ground stacks, fuse/relay panels, and unsealed electrical connectors like the H4 headlamp plugs. My 2005 VW Jetta electrical panels, battery terminals, and open ground stacks (I treated them a week after I brought it home) look new... no corrosion. Blaster Spray Lithium grease, that you can get from Home Depot, works OK on hinges and latches but it looks like crap, it sits on the surface and doesn't flow into the pins etc, and it collects dirt. I wouldn't use braces unless decapitation in an accident is on your bucket list. The hood really will cut right through the A pillars, I've seen it, extremely unpleasant. Your neck and chest is considerably softer than the A pillars. Not my first choice in a way to check out.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-15-2016 at 02:04 PM. |
03-15-2016, 02:46 PM | #19 |
Re: Lmc hood braces
Is there anything I can do to prolong the life of the hood. You can see from the image above, the damage is very minimal
03-15-2016, 03:10 PM | #20 |
Re: Lmc hood braces
If it were mine, I would consider using a very small brace just across the damaged area...
Lets face it, if we are REALLY that concerned for safety we wouldn't drive 40 year old trucks with no airbags and a fuel tank mounted outside the frame rails! Its a personal choice as to the risk you are willing to accept... but then again, I ride a motorcycle too...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
03-15-2016, 03:35 PM | #21 |
Re: Lmc hood braces
I always use motor oil on hood hinges. It's a little messy but I read it in a GM owners manual years ago. I can see using WD 40 first if they are rusty or very dry. I have never bent a hood but it must take a little bit of force I would think.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
03-15-2016, 03:53 PM | #22 |
Re: Lmc hood braces
Maybe a lower tension hood spring similar to these?
Only downside I've read about is getting thwacked if your under the hood when a breeze comes up.
03-15-2016, 04:29 PM | #23 | |
Moderator
Re: Lmc hood braces
I ride motorcycles at high rates of speed with glasses and a bandanna... So it's a bit of a double standard. OTOH any serious accident on a bike over about 50mph is really not something I want to survive. The brain bucket is the difference between open and closed casket. The saddle gas tank issue? It was BS. NBC had to use a model rocket motor to ignite the tank in their "News" entertainment show crash. They were sued for this colossal LIE by GM and THEY LOST. Several reputable engineering firms have since looked over the available data and came to the conclusion that these GM CK RV trucks actually had a slightly lower, or evenly matched, probability of gasoline immolation in a side impact accident when compared to other light trucks built in that time period... using real accident statistics from the NTSB and IIHS. My 1970 F250 FE390 4x4 has the factory fuel tank mounted behind my seat in the cab. It's covered by a non factory chunk of trunk liner carpet. That's a heckuva lot more dangerous than the saddle tanks on my 1976 K20. Anyone with a 72 or earlier IH, Jeep, GM, or Dodge light truck has the same problem... some of them were mounted in the cab till the late 70's. My 1969 IH Scout 800A had what amounted to two saddle tanks right behind the seats just forward of the wheels and outside the frame.
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-15-2016 at 04:37 PM. |
03-15-2016, 04:59 PM | #24 |
Re: Lmc hood braces
I am looking for just a little extra support. As mentioned above the damage is slight. But don't want it to get worse. I used a lithium spray and the hood wants to fall closed now. Really wished I did this before yesterday. You can see from the first pic there is a slight bow in the hood. This was there before then bend so it was bound to happen. I am thinking of doing the 2x4 trick to straighten it out. I am thinking maybe some thin gauge sheet metal attached with some self tapping screws. Not real heavy duty. Something that will hold things in place but still bend in an accident. Thoughts?
03-15-2016, 06:11 PM | #25 | |
Re: Lmc hood braces
