Old 04-02-2016, 11:20 AM   #1
Dave0
Putting Camaro front in 55 second gen
Hi! I just bought this 55. I have found a late 70s camaro subframe and I need a little direction of setting my ride height... Im looking for fairly low but totally drivable without bags. This will be my first front end swap... I know this site is a wealth of info, looking for some basic steps to setting ride height....
I have also found a 2003 s10 4x4 rear with springs and the mounts. I think I can get that in place with no problems. I have a 5.3 and 460le trans, computer, electrical box, air box, ac, power steering. Its a VERY complete take out, out of a 06 pick up.
Dave0 is offline   Reply With Quote
Old 04-02-2016, 03:05 PM   #2
mr48chev
mr48chev's Avatar
Re: Putting Camaro front in 55 second gen
The best way I have found is to figure what distance the Camaro crossmember sits off the shop floor in a stock Camaro that year ( I slid under a car like my donor and measured from the crossmember center to the floor) and when you are setting the chassis up set the crossmember on blocks so it is at that height and all squared up and then match the truck to the crossmember. I did that on my 51 Merc and came out exactly where I wanted to be on height with no suspension mods to the subframe.
This is one one of my buddies did that is almost too low, the frame rail of the truck is going to end up on the same level as the bottom of the crossmeber rear legs of the Camaro putting the truck super low. Most guys set the trucks frame a bit higher on the subframe than that.
It does show that you want the subframe and truck frame on the same level plane with each other no matter what the height of each is.
I've seen a couple of messed up frames where the builder tried to "build rake or camber" into the frame when he mated one with the other and that doesn't work
One of the best tutorials on doing the swap is the one by Lux Blue on the Hamb.
Read what he writes and says to do an shows and you should be in good shape. It's long winded because of all the comments but he did an excellent job of describing an showing how to do it the right way. http://www.jalopyjournal.com/forum/t...ne-day.148978/
My ongoing truck projects:
Old 04-02-2016, 04:01 PM   #3
Speedbumpauto
Speedbumpauto's Avatar
I did mine exactly that same way. You can judge the ride ht. by the pic. by my name. It's low but very drivable for a toy.
Speedbumpauto is offline   Reply With Quote
Old 04-02-2016, 06:03 PM   #4
Dave0
Thank you guys, I seen that build earlier. I will go back and read it all!
Old 04-04-2016, 09:49 PM   #5
Dave0
Choppy choppy
Old 04-06-2016, 03:29 AM   #6
TINKERDUKE
Check out this install for detailed instructions http://www.jalopyjournal.com/forum/t...ne-day.148978/
It's how I did mine and it drives perfectly.
My Daily driver 55 chevy with 350/th350
TINKERDUKE is offline   Reply With Quote
Old 04-06-2016, 10:07 AM   #7
MARTINSR
MARTINSR's Avatar
Personally, I have only done one of these so I don't have a lot to offer. One of the mistakes people make is thinking that mating it up to the truck frame and how and where it's welded is the most important thing, when really that is the least important. The most important is getting the suspension on that sub frame in proper relation to the truck frame! So getting the frame and the sub frame at ride height, and knowing the wheel base is right and the geometry on the sub is correct is MOST important.
But I ran an "all thread" to replace the shocks on the clip. I then tightened them up to drop frame down until the lower control arms were level, and the distance between the arm and the rubber bumper was the same as when it was on the Camaro. Being the Camaro and the truck are pretty close in weight, this worked out well.
The trucks frame was dropped down to the height I wanted it too, the rear could be done first to be sure.
This way all you have to worry about is getting the wheel base right, everything else is going to happen as needed.
One important thing is check the upper control arm shaft angle with an angle finder while it's on the Camaro so you know what to put it at on the truck.
Tack the frame into place and then install the front sheet metal on the truck to be sure the wheels look perfectly centered in the wheel wells. Then go back and finish welding it in place.
If you do all this, the front will suspension will align exactly as it did on the Camaro. You can tell the alignment shop to ignore what they are looking at and align a Camaro.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-06-2016, 08:12 PM   #8
Dave0
Good info Brian. Thank you, I hope to be setting this up tomorrow...
Old 04-08-2016, 06:14 PM   #9
Dave0
Easy job! Time to spin it around and start on the rear!
Old 04-09-2016, 01:25 PM   #10
Dave0
Im going to try and put a s10 zr2 rear end in with s10 2wd springs and frame brackets...
Old 04-09-2016, 01:31 PM   #11
Valarius_Starchaser
Valarius_Starchaser's Avatar
Nice work I'm going to follow along on this one for sure
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 04-13-2016, 11:10 PM   #12
Dave0
Messin with stuff...
Old 04-13-2016, 11:26 PM   #13
tmoble
hey, front tire is only flat on the bottom.......
tmoble is offline   Reply With Quote
Old 04-17-2016, 02:59 AM   #14
mygirlz55
How long before you get to the point of mounting front bumpers?
That's where I'm at now. I think I've got the steering figured out.
mygirlz55 is offline   Reply With Quote
Old 04-18-2016, 07:49 AM   #15
Dave0
Wont be long, now that I have my rear suspension where I want it. I will put the engine and transmission in before I start making leaf spring mounts...
Something like this, maybe a little bit lower...
Old 04-18-2016, 07:59 AM   #16
northern 85
northern 85's Avatar
Cool rig!!!
northern 85 is offline   Reply With Quote
Old 04-18-2016, 08:44 AM   #17
Dave0
Originally Posted by northern 85 View Post
Cool rig!!!
Thanks!
Old 04-18-2016, 09:10 PM   #18
Dave0
5.3 and 4l60e. I did have to pull the manifolds to get it in...
Old 04-22-2016, 10:27 PM   #19
Dave0
Ford Ranger brackets fit the s10 springs. Saved me a bunch of time making brackets... I did have to put the rears in upside down, to get the ride height I wanted...All tacked in, the truck sits on its own suspension again...
Old 04-24-2016, 08:11 PM   #20
Dave0
Checking stuff...
Old 04-27-2016, 02:56 PM   #21
tinos555
nice build, what kind of engine mounts are you using for the 5.3 set up?
tinos555 is offline   Reply With Quote
Old 04-27-2016, 07:14 PM   #22
Dave0
Right now im waiting on a pair of energy suspenssion mounts. Ls to chevelle to bring it up a bit more. (Chevelle are taller than Camaro) Im going to put them on it and see if everything (A/c steering box) fits. If they are close, I will use them. If not, I will make my own, solid mounts....
The motor is just sitting on 2 by 4 scraps and the transmission cross member is just wedged in there to hold it up.
The steering box is in it and all of the hoses from the ls, fit the camaro box! Im working on hooking up the column while I wait on motor mounts.
Old 04-27-2016, 09:57 PM   #23
Indian113
Indian113's Avatar
Great Job so Far, thanks for the pictures! where did you get the Ford Ranger Spring Hangers?
Indian113 is offline   Reply With Quote
Old 04-27-2016, 10:16 PM   #24
Dave0
Dorman repops them... Amazon, ebay.. I got them from the local auto parts store.
Old 04-28-2016, 01:19 AM   #25
dsraven
if you are going to use cast exhaust manifolds try the camaro style, they fit between the frame rails better.
looks good.
dsraven is online now   Reply With Quote
